rfloresp
How to get notified when InDesign Application hides (Mac)
Feb 2, 2012 9:54 AM
Hi!
I need to modify the behavior of a secondary process  I launch in my plugin when the InDesign app hides (from the dock or using the cmd+h key combination).
I was trying to add an observer and callback using the Notification Center (local) though I can't find a way to get the main or key window to do so.
Anyone has any pointers as how I can do this?
Thanks!
    Feb 2, 2012 12:48 PM   in reply to rfloresp
    I'm not sure what you mean with Notification Center (local).
    Sounds like an OSX specific thing.
    Instead, attach an InDesign IObserver to the kAppBoss, protocol IID_IAPPLICATION.
    You'll receive kApplicationSuspendMsg and kApplicationResumeMsg.
    Hth,
    Dirk
    Feb 3, 2012 8:44 AM   in reply to rfloresp
    As Dirk rightly pointed out, you need to place an observer in the kAppBoss and observe on the IID_IAPPLICATION protocol.
    What you should do is just place an interface as an addin in the kAppBoss and give it an implementation (you don't need to create a observer boss class as you have done).
    In startup call the autoattach of your observer, for ex
      InterfacePtr<IApplication> app(gSession->QueryApplication());
      InterfacePtr<IObserver> iMyObserver(app, IID_IMYOBSERVER);
                        iMyObserver->AutoAttach();
    In the autoattach method of your implementation class, remember to pass your observers interface ID to the attachobsever method of the ISubject
    for ex
    AttachObserver(this, IID_IAPPLICATION, IID_IMYPOBSERVER);
    Then in the update method you will get properly notified of the suspend and resume of application
    This should fix your problem.
    Manan Joshi
    - Efficient InDesign Solutions -
    MetaDesign Solutions
    http://metadesignsolutions.com/services/indesign-development.php
