What browser are you using? When you go to the following page, does it tell you which version you have installed?
http://kb2.adobe.com/cps/155/tn_15507.html
Chris
Hilary,
What version of Flash Player do you have installed?
http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
Chris
Does your computer use a proxy server to connect to the internet? If so, this might be the problem. In this case, tinychat needs to implement RTMPT, they might be using just RTMP instead which does not support proxy settings.
To verify your microphone is working in Flash player, we'll need to do a local test through the Flash settings dialog. You can access the Flash settings dialog by right clicking on most Flash content. For example, right click on the Global Privacy Settings panel and click the Settings menu item.
Then click the microphone tab and you should see the volume level move as you start talking. If this works, then Flash should be able to use your mic properly given the proper network connections.
Chris, I was able to see the mic work in flash, but when I test my mic in flash it is choppy and weird sounding: distorted. When I test my mic in windows test, it sounds smooth and responsive. So I have no idea what the HELL is going on... I also have another bug with adobe flash in youtube.... Smh..
Chris, no. When I tested my mic in adobe flash on my computer when beginning a video, it was choppy and broken.
As far as youtube is concerned, when I full screen mode a playlist, the player plays only every other video and not videos in synchronized order the way I set my playlist up. However, when I take it out of fullscreen, it then plays correctly. Someone needs to fix that problem ASAP.
Chrome, Windows. When user open my application (this app used p2p) and click Allow on this Peer-Assisted popap (select "remember") http://screencast.com/t/zCAcuafni9 this site(flashstudio.com.ua) doesnt added on Global Settings to this list http://screencast.com/t/zCAcuafni9 so user need click every time Allow... (another app with p2p worked fine)
Chrome was updated to version 21.0.1180.75m today.
To update, please go to Chrome's tool menu and select "About Google Chrome". Wait until the update has completed and then restart the browser. You can verify that you are using the latest Flash Player for Chrome by going to the following URL and verifying that Flash is at 11.3.31.225.
http://www.adobe.com/software/flash/about/
Please let us know if this helps. If you continue to have problems, please create a new bug report here: http://code.google.com/p/chromium/issues/entry
Out of curiosity, do you notice any difference if you try the following steps?
Chris
Thanks Chris.
I'm not user, i'm developer. So it's no good idea send to any users this instruction...
Now I try to explain what happened.
First:I have Video Chat you can look here http://flashstudio.com.ua/hzhz/ChatterbayWebConnection.html . When you load this page, flash player ask you about access (http://screencast.com/t/o90BwPLZFK) Select Remember and click Allow. Refresh page... and you will see same popup. (You doesnt find flashtudio.com.ua in this list) http://my.jetscreenshot.com/8273/20120809-b8f4-137kb
Next: try open another app http://flashstudio.com.ua/hz/P2PChat.html same popup, but if you select Remember and click Allow and you will not see this popup again.
I use Flex sdk 4.6 for both apps (but first is pure AS3, and second FLEX project) and use same way for embedding...
And what very intresting: if you click remember and allow in first app and after just open second app in next tab it will not ask access permission and you can find flashstudio.com.ua in this popup http://my.jetscreenshot.com/8273/20120809-b8f4-137kb.
steps for main problem:
-open http://flashstudio.com.ua/hzhz/ChatterbayWebConnection.html select remember and click Allow.
-refresh Tab and you will see same popup, and can't find flashstudio.com.ua in global settings http://my.jetscreenshot.com/8273/20120809-b8f4-137kb
-open http://flashstudio.com.ua/hz/P2PChat.html and you will not see this popup, and can find flashstudio.com.ua in Global settings in this list http://my.jetscreenshot.com/8273/20120809-b8f4-137kb
-Remove flashstudio.com.ua from Global Settings in this list http://my.jetscreenshot.com/8273/20120809-b8f4-137kb and try open this app http://flashstudio.com.ua/hz/P2PChat.html, select remember and click Allow and you will see immediatly flashstudio.com.ua in Global settings in Peer-Assisted panel... so it work fine.
Chrome, i tested 11.3.31.225 and 11.3.31.222. in version 11.3.31.300 it worked fine for both applications (but I can't make Express Install in Chrome(installation problem - http://screencast.com/t/AxZdbIxVyp) , and it's no good way to ask users to install new version by himself)
Thanks for any ideas.
Thanks for the detailed explanation and steps. I'd like to recommend you open a bug report at bugbase.adobe.com. I'm not sure what's happening with the popups, but I did see the same behavior as you. The express install issue is known, and I unfortunately don't have a great work around other thank providing a link to the Flash Player installer page (http://get.adobe.com/flashplayer/otherversions/)
I find some trick: after investigation difference between this apps I find - second app Init p2p connection immediately after app has main class init, but my app do this after some time(init http server, make some GUI and after few seconds). So I make fake connection to Cirrus immediately when Main Class is init, and this resolve problem...
i have the updated version of adobe flash player downloaded on my PC but i am having trouble with video stuttering and audio not in sync. i've tried the enable hardware back and forth and also moving the available room bar all the way to unlimited space. still not working right. I just started having issues 2 months ago, before this there was no problem at all. not sure what happened to change things. if anybody has a troubleshooting solution to my problem or any suggestions, please let me know. THX
Please start a new topic directly in the forum http://forums.adobe.com/community/flashplayer/installing_flashplayer
Specify your operating system & browser details, as well as the meaning of "not working right".
@ttruther - What version of Flash Player is reported installed when you visit this page?
@XxbryamxX - Try troubleshooting using the steps in the following FAQ. If it doesn't help, we'll need you to report the problem to us using the details described.
How do I troubleshoot and report problems with Flash Player Video?
North America
Asia Pacific
