amorri40
Alchemy array of structure error
Feb 4, 2012 7:05 AM
Tags: #flash #alchemy #cpp
I use an array of structures in my project which works fine in gcc, however the alchemy version always gives 0 for values initialised in the array, but initialising a single struct in alchemy works fine, its only if it is initialised as part of the array. Here is an example which highlights my problem:
#include <string>
using namespace std;
struct inst {
    int id,obj,x,y;
struct tile {
    int id,bckid,bgx,bgy,depth,height,width,roomX,roomY;
struct viewstruct
    int start_vis;
    int area_x,area_y,area_w,area_h;
    int port_x,port_y,port_w,port_h;
    int object2follow;
    int hborder,vborder,hspd,vspd;
struct backstruct {
    int visible;
    int foreground;
    int background;
    int area_x, area_y, horSpeed, verSpeed;
    int tileHor, tileVert;
    int stretch;
struct roomstruct
    int id;
    int order;
    string name;
    string cap;
    int backcolor;
    bool drawbackcolor;
    void(*createcode)();
    int width, height, spd;
    int views_enabled;
    viewstruct views[8];
    backstruct backs[8];
    int instancecount;
    inst *instances;
    int tilecount;
    tile *tiles;
    void gotome(bool=false);
 room1 initialises correctly
roomstruct room1 =  { 0, 0, "rm_0",  "mycaption",
    0xc0c0c0, -1, NULL,
    640, 480, 30,  false, {
        { 0,   0, 0, 640, 480,   0, 0, 640, 480,   -1,   32, 32,   -1, -1 },
    }, {      { false,   false,   -1,   0,   0,   0,   0,   true,   true,   false },
    },      0, NULL      ,0, NULL    };
 grd_rooms does not initialise correctly
roomstruct grd_rooms[2] = {
    //Room 0
        0xc0c0c0, -1, NULL,
        },      0, NULL      ,0, NULL    },
    //Room 1
    { 1, 1, "rm_1",  "",
        0xc0c0c0, -1, NULL,
        740, 480, 30,  false, {
int main(int argc, char* argv[])
    printf("room1 width: %d \n",room1.width); //gives correct value
    printf("grd_rooms[0] width: %d \n",grd_rooms[0].width); //wrong value
    grd_rooms[0]=room1;
    printf("grd_rooms[0] width: %d \n",grd_rooms[0].width); //now it has the correct value
Gives the correct output with normal gcc:
room1 width: 640
grd_rooms[0] width: 640
But not with alchemy:
room1 width: 640
grd_rooms[0] width: 0
This is what I use to compile the file:
g++ HelloFlash.cpp -O0 -Wall -DOSX -swc -o helloflash.swc
If you comment out the two strings in roomstruct it will give the correct output in alchemy, I have also rebuilt stl ( thanks to http://stackoverflow.com/questions/7421832/using-stl-with-alchemy/7421 834 ) and the string_test from that works.
Any information about this would be greatly appreciated.
    Feb 7, 2012 9:10 AM   in reply to amorri40
    Globals/statics that invoke malloc/new don't work in Alchemy and will silently fail.  See this SO post and this forum thread.
    What's getting you are the std::string constructors.  This isn't a failing of std::string, but the fact that the constructor won't run "before" main runs.
    Some workarounds:
    • Use char arrays (or char*) in your structs, rather than std::string.
    • Initialize your globals as NULL and populate them with data in main().
