Flash CS5.5 has suddenly started crashing all the time. It's ridiculous.
It's always about 2 seconds after:
- Minimizing/Bringing forward another window.
- Testing a movie
- Opening/closing another fla in CS5.5
This is with any fla file. It's incredibly frustrating.
The window just tints white and I get a "____________ has stopped working", and my only choice is to close program.
I am using Windows 7.
I am really shocked at how progressively unreliable EVERY Flash Pro has been since CS3, despite being an industry standard.
It's been incredibly useful to me since I first started using it in 2004 (MX 2004 that is). However, considering all my other development software, it is clear that it is by far the most unreliable.
It is unacceptable.
Please provide detailed info:
1) your OS bits (32 or 64)
2) your ram value
3) hard drive free space on disk where Flash is running
4) increase virtual memoryso it will me not less than 2048 mb http://windows.microsoft.com/en-US/windows-vista/Change-the-size-of-vi rtual-memory
My stable configuration
HP ProBook 4530S, Windows 7 x64, 8 gb ram, 100 gb hdd free space on c:, virtual memory 1024 (no need more for me with 8 gb ram).
I can open files up to 1024 mb into the memory. Nothing wrong with working.
Try my fix, because half year ago I had similar.
Go to C:\Users\ YOUR USER NAME \AppData\Local\Adobe\Flash CS5.5\
There you will see one folder or few. Like en_US
This folder contain configurations that auto-rewrite if it broken or something like that.
For example try to rename en_US to en_US_backup and run Flash CS5.5 and let me know if this was not helpful
1) reinstall java virtual machine
2) http://kb2.adobe.com/cps/405/kb405257.html try this
I am having a similiar problem with my flash cs5.5. In the middle of working on a video it crashes and says it can not save my file. I wasn't even trying to save it. When I click ok it closes flash. The worst thing is when I try to open my file again it says unexpected file format and I have lost all of my work, even if I was saving as I was going. Also if I had another file open at the same time I've lost that one as well. I get the same message when I try to open it.
I have the latest verison of flash installed
64 bit
4 gb of ram
177 gm of free space
3976 mb virtual memory
I read this comment and will try it.
Adobe is not sucks. issues can be happened with anyone with any software so just reinstall it. In usual computer it works prefectly. may be u installed other soft than blocks normal work of flash - i dont know this. its like half year ago i meet bug when i setup apache web server and run skype. and nothing from that was not working ) i know why - app use same port to working. but they collide to each other ) may be in your case you installed some app that break flash app. if u use cracked app this will provide issues. try to install trial flash and let here all know
17 февраля 2012, 16:29 от tom_wilson <forums@adobe.com>:
tom_wilson http://forums.adobe.com/people/tom_wilson created the discussion
"Re: CS5.5 crashing all the time"
To view the discussion, visit: http://forums.adobe.com/message/4212658#4212658
This answer resolved my issue.. WITH OUT HAVING TO REINSTALL ANY ADOBE PRODUCTS, I would give it a try FIRST (to avoid reinstallation/updates)
The process that screwed up everything, I am ALMOST sure of it is....
I just installed MySQL Workbench and tools package & WAMPserver (APACHIE Server & PHPmyADMIN, SQL Buddy) exc....
It must have corrupted the JAVA VM so reinstallation of JVM and I also decided to go in to the FLASH.exe (CS5.5) "Properties" and clicked on to make the progrm to run as ADMIN and "Run in Compatibility mode" Win Xp SP3 just to cover my bases.
I also jacked up my JVM.ini [C:\Program Files\Adobe\Adobe Flash CS5.5\Common\First Run\ActionScript 3.0]
FROM (-Xmx128m) *default* TO.....
-Xmx256m
In order to do it though Windows wouldn't allow me to just edit/save to the origional directory so I had to copy the JVM.ini file to the desk top/edit then copy it back to the origionating directory
So my current configuration is this:
INTEL P4 Duel core 3.2Ghz
Win 7 (Up to date completely)
4GB RAM
6 HDD's consisteing in 4+/- TB's in space
Adobe CS4^, CS5^*, CS5.5* ([*]Design Premium & [^]Production Premium) [Had to split the difference due to me not having the 64bit processor in my tower]
Just figured I would actually post on here so other users may find my system specs and the resolution helpful if they are having related issues.
Hope it helps somebody, somewhere
Message was edited by: Arcangel66699
North America
Asia Pacific
