Output folder in Flash Builder 4.6 refuses to be anything but relative
Feb 6, 2012 7:56 PM
I just updated from Flash Builder 4.5 to 4.6. Things seemed to be going ok in terms of importing all my projects etc. (why can't there be a simple upgrade process rather than a complete uninstall/reinstall process?)
But then I got to setting the Output Folder within the Flex Build Path section of the properties of my project.
Now, as our dev environments we run glassfish servers locally on our testing machines and build our apps directly into them so our testing process is very quick. This was working fine in Flash Builder 4.5, I point my app's output folder to a location of the form:
C:\Users\myUserName\glassfish3\glassfish\domains\domain1\eclipseApps\a ppname
And that works fine, set by pasting in from an explorer window or Browsing there via the Browse button next to the field.
Now when I try to do this within Flash Builder 4.6 I get nothing at all appearing if I use the browse button. No error, nothing saying it failed, just an empty field. If I try to paste in anything I get an error from Flash Builder saying '"Paste" did not complete normally."
If I try to just type in the path it fails, it strips the leading C:\ and turns it into a relative path, which is completely useless.
This is getting really annoying!
Log file output after I tries to browse to the folder:
!ENTRY org.eclipse.ui 4 0 2012-02-07 14:54:00.474
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException
    at com.adobe.flashbuilder.launching.multiplatform.contributor.MultiPlatf ormDebugUtilLocalePathVariable.resolvePath(MultiPlatformDebugUtilLocal ePathVariable.java:68)
    at com.adobe.flexbuilder.project.PathVariableResolver.wrapPath(PathVaria bleResolver.java:198)
    at com.adobe.flexbuilder.project.PathVariableResolver.makePathVariableRe lative(PathVariableResolver.java:283)
    at com.adobe.flexbuilder.project.ui.utils.AbstractBuildPathsPropertiesPa ne.makeRelativeOutputPath(AbstractBuildPathsPropertiesPane.java:946)
    at com.adobe.flexbuilder.project.ui.utils.AbstractBuildPathsPropertiesPa ne.makeRelativeOutputPath(AbstractBuildPathsPropertiesPane.java:931)
    at com.adobe.flexbuilder.project.ui.utils.AbstractBuildPathsPropertiesPa ne.browseForOutputFolder(AbstractBuildPathsPropertiesPane.java:910)
    at com.adobe.flexbuilder.project.ui.utils.AbstractBuildPathsPropertiesPa ne$12.widgetSelected(AbstractBuildPathsPropertiesPane.java:805)
    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java: 240)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
    at org.eclipse.jface.window.Window.open(Window.java:801)
    at com.adobe.flexbuilder.editors.derived.ui.navigator.FlexPackageExplore rPropertyDialogAction.run(FlexPackageExplorerPropertyDialogAction.java :41)
    at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
    at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection (ActionContributionItem.java:584)
    at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContri butionItem.java:501)
    at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionC ontributionItem.java:411)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja va:332)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:667)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashB uilderApplication.java:108)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:344)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
    Mar 18, 2012 9:31 AM   in reply to simon.oconnor
    Same problem here! I used your trick but you're right it's really not cool!
    Thx anyways. I hope Adobe will fix this soon.
    Apr 19, 2012 7:10 AM   in reply to simon.oconnor
    Tried reproducing this issue, but no luck. Could you please attach a sample project?
    I will re-open this bug.
    May 17, 2012 7:48 PM   in reply to simon.oconnor
    me too
    !ENTRY org.eclipse.jface 4 0 2012-05-18 10:40:39.212
    !MESSAGE java.lang.NullPointerException
    !STACK 0
              at com.adobe.flexbuilder.project.ui.utils.AbstractBuildPathsPropertiesPa ne.updateOutputFolder(AbstractBuildPathsPropertiesPane.java:1218)
              at com.adobe.flexbuilder.project.ui.properties.BuildPathsPropertyPage.ap plyProjectSettings(BuildPathsPropertyPage.java:444)
              at com.adobe.flexbuilder.project.ui.properties.AbstractFlexProjectProper tyPage.performOk(AbstractFlexProjectPropertyPage.java:117)
              at com.adobe.flexbuilder.project.ui.properties.BuildPathsPropertyPage.pe rformOk(BuildPathsPropertyPage.java:586)
              at org.eclipse.jface.preference.PreferenceDialog$13.run(PreferenceDialog .java:964)
              at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
              at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
              at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
              at org.eclipse.jface.preference.PreferenceDialog.okPressed(PreferenceDia log.java:944)
              at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.okPressed(Fi lteredPreferenceDialog.java:447)
              at org.eclipse.jface.preference.PreferenceDialog.buttonPressed(Preferenc eDialog.java:233)
              at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
    May 22, 2012 7:33 AM   in reply to simon.oconnor
    I get this problem if i set the "locale" setting in the additional compiler arguments to a value other than the default "en_US". E. g. -locale de_DE.
    Jun 4, 2012 7:45 AM   in reply to lgo15
    I can confirm this behavior - I can change output folder only when I remove additional compiler arguments (czech locales in my case)
    Jul 30, 2012 7:45 AM   in reply to kamil.svoboda
    I had the same issue.
    The solution for me is:
    -locale=en_US,hu_HU
    Oct 31, 2012 6:46 AM   in reply to TsigaBiga
    I got the same issue (described here http://forums.adobe.com/thread/1091290?)
    TsigaBiga, your fix doesn't work
    Message was edited by: ADI D Ok, I looked more to TsigaBiga's suggestion – it works! Just notice the "=" sign after -locale.
    May 8, 2013 10:33 AM   in reply to simon.oconnor
    I am having the same issue. I tried editing the .actionscriptproperties file in NotePad and setting both the outputFolderLocation and outPutFolderPath to an absolute path on the C: drive on Windows 7 (64-bit) (and NOT within the applications folders on the C: drive.
    Flash Builder 4.6 is truncating the value and making it relative to the project folder. Absolutely useless!! Adobe needs to fix this!
