I just noticed that you silently updated the AIR SDK 3.1 to 3.1.4880.
Comparing the files you can see 23 files were updated in January 9th, 2012.
The original 3.1 SDK was from November 7th, 2011.
Why don't you include a "what's new" file inside the ZIP?
I suppose this new build is just a bugfix release, but you could still tell what's been fixed.
So, what's the difference between this newer 3.1 SDK (build 4880) and the older 3.1?
Regards,
OMA
Thanks for your answer. According to that page, version 3.1.4880 adds "ICS(IceCream Sandwich) support for AIR Android".
One would think that adding support for a whole new version of Android would warrant at least a minor version bump, not just the build.
Anyway, even if this 4880 update build is supposed to be only about ICS, I've found a weird bug in iOS that only happens with 3.1.4880 and not with the original 3.1 from November 2011:
I'm looking for links to the older versions...
http://kb2.adobe.com/cps/853/cpsid_85304.html does not have the link.
@BDindeblender: Are you having the same issue? If you can't find the original 3.1 version I can try uploading it somewhere, but I think it's Adobe the one that should be providing the archived versions, even if it's just a different build of the "same version" (3.1).
Or, even better, please fix this regression. In the original 3.1 SDK, splash screens worked fine in iOS (tested today with both versions; old version works correctly, new one doesn't).
Edit: I've noticed there's a dropdown option in BugBase that suggests there's a new build: 3.1.5560
Where can we download that version?
These little updates where version number doesn't change (only build number) are pretty confusing, specially when a bug is inadvertently introduced and you can't download the old version because you don't provide it anymore from Adobe's site.
@OMA2k Same issue, calling Adobe now/ Been on hold for 7 min.
I need the Mac version...
He's going to look into it...
I did too, and edited the links I found here: http://kb2.adobe.com/cps/853/cpsid_85304.html
Not the previous 3.1 version, but at least something between 3.1 and 2.7...
Did Adobe finally provide you with the original AIR 3.1?
BTW, I've seen AIR 3.2 is in Release Candidate stage:
http://labs.adobe.com/technologies/flashplatformruntimes/air3-2/
I hope this bug wasn't carried over to that version!
Nope...
They said they would call me back the same day (Thursday 23rd) but haven't heard anything since.
The Air twitter account doesn't respond to questions, so it appears. adobe_care said it was looking into it...
Kind of bizarre how such a big company deals with paying customers...
Hopefully I didn't drop the ball here and not get back in touch with you. I've been monitoring this conversation and I did request last week that we update our Archive page with the 3.0 build but it looks like this hasn't been done yet. I don't recall a 3.1 build being released in November, maybe you were referring to the 3.0.0.4080 build? I was out on vacation that month though, so maybe I missed something. Please email me directly and I'll get you the 3.0.0.4080 build asap.
Chris
Hello Chris.
Thanks for your reply. As far as I know, AIR 3.1 SDK was first released in November 2011, wasn't it?
You can even see that all files inside the original 3.1 ZIP have a 7th of November date.
I already have the original 3.1 SDK for Windows, because I already downloaded it when it was released,
but BDindeblender is asking for the original 3.1 SDK for Mac, which unfortunately I don't have,
because I usually work in a Windows environment (except when I have to upload to Apple's App Store).
The version currently available at Adobe's SDK page is 3.1.0.4880 which was released in January, 2012
(until it gets replaced with the 3.2 SDK when the Release Candidate becomes Final)
http://www.adobe.com/devnet/air/air-sdk-download.html
The problem with this updated "4880" build is it has a bug that the original 3.1 didn't have, described here:
https://bugbase.adobe.com/index.cfm?event=bug&id=3121219
I hope this bug isn't carried over to the new 3.2 SDK. I still haven't tried it, so I can't comment on that yet.
Regards.
I spoke to Emre Dogan, left a message with @air and @adobe_care.
Got a reply from Emre after almost a week instead of the same day, he sent me the public/standard 3.1 SDK link wich i allready have... ![]()
@Adobe_care said the were looking into it but still no answer.
Anyhow, if you could post the links here then everybody benefits, thanks in advance.
Hi BDindeblender, Chris said "Email me and I'll give you a link" so try writing him a private message:
http://forums.adobe.com/pm-post!input.jspa?to=661067
Also, AIR 3.2 Release Candidate is out, so in the meantime, you could maybe try and see
if the new version has this bug fixed:
Regards.
Hi again. I've seen that Abhayjit Singh has replied in the BugBase page (why doesn't the BugBase system send me an e-mail so I know when somebody has replied, like this forum does?)
He suggests that this is happening because this is a "known issue" that happens when using the iOS 5 SDK to compile, triggered by using the -sdkplatform switch, which I never used.
I've looked for documentation about the -sdkplatform switch of the ADT tool and I haven't found any mention of changing the iOS SDK used.
I didn't even know I could do that! ![]()
Anyway, I always use ADT to compile (not Flash Builder), and I had never used that switch before, so since I'm not specifying anywhere the iOS 5 SDK, I'm thinking that maybe it's a Native Extension the one that's triggering the usage of the iOS 5 SDK. The extension I'm using is DoNotBackup by JamPot.ie, and since it uses an API available since iOS 5.0.1, maybe that extension is automatically triggering the iOS 5 SDK instead of the old one.
@BDindeblender: Are you using a Native Extension of some sort?
Anyway, even if that's the case, this should be fixed when using the iOS5 SDK, since it's the latest one, and this didn't happen anyway then using the original AIR 3.1, no matter if I used native extensions or not.
I've sent a PM to BDindeblender with a link. I've hosted it on my dropbox account so it's just a temporary link. I'll see what I can do about getting this on our archive page, but given the identical build numbers it might be problematic.
I've also talked with the iOS team and was told that this should be resolved in the 3.2 SDK which should be released in the next few weeks.
Chris
North America
Asia Pacific
