I need to have an image appear slightly above the bottom of my web page and then the user clicks the image the image slides up to reveal all of it, then when the user clicks the image again it slides down.
I did some searching and found an example here
1. The "Toggle" example in the link below seems to be the closest to what I want but I need it to slide "up" whereas in the example it slides "down". How can I do this?
http://labs.adobe.com/technologies/spry/samples/effects/slide_sample.h tml
2. Where do I put the toggle code (below) from the above link and how do I make it work with my image. For example how do I get my image to slide up and then remain up until the user clicks the image and it slides down.
var slide_toggle = new Spry.Effect.Slide('slideItUp2', {toggle:true});
</script>
The following may help you
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Spry sidebar</title>
<style>
.SprySideBar {
left:0px;
position:absolute;
top:140px;
text-align:left;
.SprySideBar a{outline:none;}
.SprySideBarGroup{
background-color:#F3F3F3;
border:1px solid #CCCCCC;
min-height:100px;
float:left;
width:auto;
.SprySideBarContent {
display:none;
height:170px;
overflow:hidden !important;
width:200px;
.SprySideBarMenu h1 {
color:#000;
font:bold 110% arial;
margin:10px;
.SprySideBarMenu ul {
margin:0px;
padding:0px;
.SprySideBarMenu li {
list-style-type:none;
margin:0px 10px 3px;
padding:2px;
width:170px;
.SprySideBarMenu li a:link, .SprySideBarMenu li a:visited {
color:#000;
display:block;
font-family:verdana;
font-size:100%;
text-decoration:none;
.SprySideTab, .SprySideTab a{
float:left;
height:100px;
width:28px;
display:block;
margin-left:-1px;
</style>
</head>
<body>
<div id="example1" class="SprySideBar">
<div class="SprySideBarGroup">
<div class="SprySideBarContent">
<div class="SprySideBarMenu">
<h1>SprySideBar</h1>
<ul>
<li><a href="#">Link 1</a></li>
<li><a href="#">Link 2</a></li>
<li><a href="#">Link 3</a></li>
<li><a href="#">Link 4</a></li>
<li><a href="#">Link 5</a></li>
</ul>
</div>
</div>
</div>
<a href="javascript://" id="sideBarTab" class="SprySideTab"><em class="em">>></em></a>
</div>
<script src="http://labs.adobe.com/technologies/spry/includes_minified/SpryDOMUtils.js"></script>
<script src="http://labs.adobe.com/technologies/spry/includes_minified/SpryEffects.js"></script>
<script>
Spry.Effect.SideBar = function (element, options)
//this will return a message if u arent using the effect correct.
if (!this.notStaticAnimator)
return Spry.Effect.Utils.showInitError('SideBar');
//Start up the clustering
Spry.Effect.Cluster.call(this, options);
//We are goin to create an inline function go gather the children elements for us.
var getChildren = function(element){
//create a array
var children = [];
//get the first child
var child = element.firstChild;
while (child)
//its an element node proceed, this is required because FF counts the #text nodes and IE doesn't.
if (child.nodeType == 1 /* Node.ELEMENT_NODE */){
children.push(child);
if (child.hasChildNodes())
// So, first we check if the object is not empty, if the object has child nodes
var kids = child.childNodes;
for (var i = 0; i < kids.length; i++)
if(kids[i].nodeType == 1 /* Node.ELEMENT_NODE */)
children.push(kids[i]);
child = child.nextSibling;
return children;
//Let Spry effect get the element for us so we know its correct
var element = Spry.Effect.getElement(element);
var content = getChildren(element);
var menu = getChildren(content[1]);
/* Content layout (4 items)
0 DIV : SprySideBarGroup
1 DIV : SprySideBarContent
2 A : SprySideTab SprySideTabClosed
3 EM :
/* Menu layout (4 items)
0 DIV : SprySideBarMenu
1 H1
2 UL
var doFrom = '0%';
var doTo = '100%';
var doDuration = 1000;
var doToggle = false; //toggle false is required to the correct effect direction
var doTransition = Spry.fifthTransition; //default
var isOpenIndc = '>>';
var isCloseIndc = '<<';
if (options)
if (options.duration != null) doDuration = Math.ceil(options.duration/2);
if (options.toggle != null) doToggle = options.toggle;
if (options.to != null) doTo = options.to;
if (options.from != null) doFrom = options.from;
if (options.transition != null) doTransition = options.transition;
if (options.openIndc != null) isOpenIndc = options.openIndc;
if (options.closeIndc != null) isCloseIndc = options.closeIndc;
//lets make it easy for ourselfs and create one options object for both
var effectoptions = {duration:doDuration, toggle:doToggle, from:doFrom, to:doTo, transition:doTransition};
var slide = new Spry.Effect.Squish(content[1],effectoptions);
var fade = new Spry.Effect.Fade(menu[0],effectoptions);
//how do we want to run this effect?
this.addParallelEffect(slide);
this.addParallelEffect(fade);
this.addObserver({
onPreEffect:
function(effect){
if (effect.direction == Spry.forwards)
content[3].innerHTML = isCloseIndc;
else
content[3].innerHTML = isOpenIndc;
//create the constructor
Spry.Effect.SideBar.prototype = new Spry.Effect.Cluster();
Spry.Effect.SideBar.prototype.constructor = Spry.Effect.SideBar;
/* create a simple effect, and add the start to the tab, and your done */
var sidebar = new Spry.Effect.SideBar('example1',{toggle:true,closeIndc:'<<'});
Spry.Utils.addLoadListener(function(){
Spry.Utils.addEventListener("sideBarTab", "click", function(){
sidebar.start()
}, false);
</script>
</body>
</html>
Gramps
North America
Asia Pacific
