Determine ICC output profile (name) in PDF/X output intent
Feb 10, 2012 2:10 AM
Hi all,
I have a PDF of which I need to determine the ICC output profile (name) of the PDF/X output intent. This is what I have in the 'content stream':
<</Metadata 6 0 R/OutputIntents[<</DestOutputProfile 7 0 R/Info(OFCOM. ISO 12647-2:2004 / Amd 1, Offset commercial and specialty printing according to ISO 12647-2, paper type 1 or 2 \(gloss or matte coated offset, 115 g/m2\), screen frequency 60/cm.)/OutputConditionIdentifier(FOGRA39)/RegistryName(http://www.color.org)/S/GTS_PDFX/Type/OutputIntent>>]
How can I, based on this information, determine what the name of the ICC profile in the PDF/X output intent is? Adobe Acrobat's output preview tells me that is should say / find ''ISO Coated v2 300% (ECI)'.
Thanks in advance.
Didier
    Feb 10, 2012 4:44 AM   in reply to Didier H.
    You would need to extract the ICC profile data stream and then parse it according to the file format for ICC profiles.
    Feb 10, 2012 5:17 AM   in reply to Didier H.
    You can use the Acrobat SDK to extract the data from the stream.  Then I recommend SampleICC, the open source reference implementation from the ICC itself, for reading the profile.
