USPTOGeorge
Robohelp 9 not working with Word 2010 on Windows 7
Feb 14, 2012 9:13 AM
I have installed Robohelp 9 on my Windows 7 machine that has MS Office 2010 already installed on it.
I have installed the Robohelp 9.0.2 update. I start Robohelp 9 for Word and create a new Winhelp 4 project.
I give it a name and click Finish. I get an error message that says "Robohelp can not open docx files in the current word version"
I click OK and it launches the template in word and gives me a macro error that saya "Compile error in hidden module AutoOpen. This error commonly occurs when code is incompatible with the version, platform, architecture of this application"
When I close the Word document, I get an error about hidden module AutoClose. It's like there is something wrong with the template.
NOTE: I previously had Robohelp 8 installed, but uninstalled and made sure that every occurence of robohelp.dot was gone.
Shouldn't Robohelp 9 be creating a .dotx for Office 2010?
Am I doing something wrong?
Thanks for any help,
George
    Feb 14, 2012 10:50 AM   in reply to USPTOGeorge
    Look in Tools > Options to see which version of Word is set there.
    @petergrainge
    Feb 14, 2012 11:37 AM   in reply to USPTOGeorge
    It looks like the install has not worked, based on your first post and that dropdown being empty. My inclination would be to uninstall and then try again.
    Is your Normal.dot Word template on your hard drive? If your IT have it on a network drive that might cause problems.
    @petergrainge
    Feb 15, 2012 12:28 AM   in reply to USPTOGeorge
    There should be a .DOT file as well as the .DOTM. If you do not have a .DOT file I wonder if that is why RoboHelp is not picking up the Word installation.
    I believe Jeff Coatsworth has pointed out in other posts that you can get free support for installation issues from Adobe Tech Support.
    @petergrainge
    Feb 15, 2012 7:31 AM   in reply to USPTOGeorge
    Where you phone will depend on what country you are in.
    Start here. http://www.adobe.com/support/contact/
    @petergrainge
    Feb 18, 2012 7:50 PM   in reply to USPTOGeorge
    Hi George,
    I note the line in your original post :-
    "NOTE: I previously had Robohelp 8 installed, but uninstalled and made sure that every occurence of robohelp.dot was gone."
    I think that is your problem.  You have deleted the Robohelp.DOT from the templates directory.  Although you are using Office 2010 or 2007  Robohelp still insists on using an Office 2003 or earlier format template in *.DOT format.  You need to have a Robohelp.dOT template for the program to work.  May I syggest a re-install, leave the robohelp.DOT in place as it is instaled and see what happens ?
    I posted an issue  A couple of weeks ago questioning why Robohelp does not use DOTX or DOTM format templates as per Office 2010 and Peter Grainge has asked adobe on my behalf... yet to see a reply.
    My issue related to potemntial incosistency in bult output (Corruption) and question whether that was caused bt the different formats of the template ie:- a 2003 format templat in documents saved in 2010 or 2007 format. As others have stated in the past word starts up in 'Compatribility' mode when using the *.DOT format template that I have found may be linked to some output and build issues ?
    Good luck.
    Bryan Holman
    Feb 20, 2012 2:13 AM   in reply to bjh955
    Bryan
    If I didn't already suggest it, I think you should report all your woes to Adobe by way of a bug report.
    Better still, join us all over on RoboHelp HTML.
    @petergrainge
    Feb 21, 2012 12:35 PM   in reply to USPTOGeorge
    My understanding is that WebHelp should work just fine in that environment. Can someone confirm?
    George: Prompt me if no one responds and you cannot find anything in RoboHelp's own help. I'll see what I can find out.
    @petergrainge
    Feb 22, 2012 7:25 AM   in reply to USPTOGeorge
    Are you saying that your help desk is stipulating that the Adobe person must have some specific certification? If so, good luck with that one. Do your helpdesk not know of Adobe? Their name alone should be sufficient.
    @petergrainge
