Style Import Issue?
Feb 14, 2012 10:53 AM
I have a Captivate 5.5  module where all the captions, highlight boxes, click boxes, and so forth are just they way I want them.  I use that project to create a training simulation, but the styles are not inherited from the original module.  So, I export the styles from the original project, record a new training simulation, and import the styles.  However, the newly recorded project does not take on the characteristics of the imported style file.
Any ideas you can lend would be great.
Henry
    Feb 14, 2012 11:43 AM   in reply to hps_5
    Perhaps I'm misunderstanding, but you have to import the Styles before recording a new simulation if you want the Capture Captions taking on the new style.
    Lilybiri
    Feb 14, 2012 12:30 PM   in reply to hps_5
    It's my understanding you need to import that style file before starting the recording.  There are a couple ways around it after the fact, but not necessarily the cleanest result.
    If you saved the ivory styles as the default names, when you import the style file, Cp will prompt if you want to apply the imported styles to the existing objects.
    If you named the styles, when you import the ivory style, you can select an appropriate object (a caption with the 'default caption style' let's say), change it to the ivory style, then click the little arrow below the style drop down.  This will let you apply that ivory style to every object of the object style you choose.
    That used the word 'object' and 'style' a lot.  I hope that makes sense.
