Mark5145
Unwanted blank pages inserted when creating pdf from scanner
Feb 14, 2012 12:29 PM
Tags: #acrobat #x #adobe #pro #scanner #document #pages #extra #professional #blank #scanning #wanted #scanned
Hello, when creating a pdf from a document scanned via Adobe Acrobat X Pro, the program inserts an unwanted blank page in between each page  being scanned.  So, if scanning 50 pages, we get 100, etc.  How do we remediate this problem?  We have worked with the default settings, to no avail.  We're using a Fujitsu fi-5530c2 scanner.  We would appreciate any input to help resolve this issue!  Thanks Mark
    Feb 27, 2012 1:24 AM   in reply to Mark5145
    Hi Mark,
    This might be because you have selected "Both Sides" in Sides dropdown. I would like to inform you that some Fujitsu scanners can scan both the sides of the page simunltaneously. Thus, when you Scan with this setting, you will get 2 pages for 1 scanned document.
    Can you try with "Front Side" scanning once. You will find this option in the Custom Scan dialog. In case, you are using Presets, go to Configure Presets and set the option in the Configure Presets dialog and click button "Save".
    -Ankit
  • JR_Boulay
    Nov 23, 2008
    Feb 27, 2012 5:37 AM   in reply to Mark5145
    you can automaticaly fix previously made documents using the Preflight tool.
    Dec 17, 2013 10:12 AM   in reply to Mark5145
    I'm having the same problem, but I had already changed the configuration settings - it still scans front and back.  Any other solutions?  Thanks!
Bookmarked By (1)
