Fresier
Decoder Error when importing asset into encore (.wmv file)
Feb 15, 2012 4:14 PM
Tags: #error #import #codec #transcode
Hey i keep getting the following error when trying to import a video.
"The software that's used to decode the media is not available on this system.  Installing the correct decoders for the files you are working with may help to correct the problem."
I've checked which codec was used for the file and its VC-1 WMV3 i think?
Any idea where i can get hold of this?! ASAP please! I dont mind having to convert it, i tried to convert it to avi but it lost alot of quality.
    Feb 15, 2012 5:12 PM   in reply to Fresier
    Well, thinking you know the codec is not the same as knowing the codec... read below
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainfo.massanti.com/
    Feb 15, 2012 5:27 PM   in reply to Fresier
    I am assuming you are CS5 or CS5.x; is that correct?
    Yes, convert it first. To address the quality issue look at  your original with mediainfo or similar and try to understand why you are getting a quality hit.
    Or, import into Premiere, drag a clip to the new icon (creates a matching sequence). What are the sequence settings it created.
    Export as short clip (1 minute is probably enough) as MPEG2-DVD, no multiplexing (creates an m2v and wav or a3c). How does that look played on your PC? Bring that into Encore. How does it look there?
    Feb 16, 2012 4:58 PM   in reply to Fresier
    My comment re MPEG2-DVD was based on the assumption you are making a DVD, not a bluray. Is that correct?
    Your file is 1440x1080, so a DVD is going to be a downrez.
    Feb 17, 2012 3:13 PM   in reply to Fresier
    The wmv file size does not matter; wmv is not  DVD compliant, so Encore is going to have to transcode it. That is where the size will matter.
    See post one in this thread: http://forums.adobe.com/message/3537337#3537337
    As he says, with CS5, just export as MPEG2-DVD with maximum render quality. However, you also have to look at the bitrate to maximize the bitrate. Remember that you are downrezing, - DVD is 720x480 (NTSC). With going bluray you are going to loose resolution.
