Amit Birla
Getting Unknown shape for any Polygon
Feb 16, 2012 6:18 AM
Hi, i have come up with a strange Indesign behaviour.
Iam working on InDesign CS4.Iam using IsSplineShape(const UIDRef& itemUIDRef, PMString& shape) const function for getting the type of shape of the polygon, placed on the page of a document.
code snippet of this function is as follows:
bool16 SUIPanelObserver::IsSplineShape(const UIDRef& itemUIDRef, PMString& shape) const
    bool16 result = kFalse;
    InterfacePtr<IPathGeometry> pathGeometry(itemUIDRef,UseDefaultIID());
    if (pathGeometry != nil)
        result = kTrue;
        PMPageItemType pathType = Utils<IPathUtils>()->WhichKindOfPageItem(pathGeometry);
        switch (pathType)
        case kIsLine:
            shape = "Line";
            break;
        case kIsRectangle:
            shape = "Rectangle";
            break;
        case kIsCircle:
            shape = "Circle";
            break;
        case kIsOval:
            shape = "Oval";
            break;
        case kIsRegularPoly:
            shape = "RegularPoly";
            break;
        case kIsIrregularPoly:
            shape = "IrregularPoly";
            break;
        case kIsSquare:
            shape = "Square";
            break;
        default:
            shape = "Unknown";
            break;
    return result;
The problem is that, inspite of returning shape of a polygon as RegularPoly or IrregularPoly, it is actually returning  Unknown shape.
Also,i have tried both functions:
                                   Utils<IPathUtils>()->IsIrregularPolygon(pathGeometry);
                                   Utils<IPathUtils>()->IsRegularPolygon(pathGeometry);
In each case it returns me kFalse, means,the shape in neither a RegularPolygon nor a IrregularPolygon.
Is that because of multiple closed path in the shape? because any polygon is drawn under a bound box and hence we will not get single closed path.
Any Idea??
    Feb 16, 2012 3:12 PM   in reply to Amit Birla
    Are your test objects always combined paths? It might be very simple: two paths in one object is neither "a regular polygon" nor "an irregular polygon", because there are *two* shapes in that object. Looking at the list of available tests, neither one of them mentions the object can have more than a single path.
    Try it on singular path objects and see if it works correct.
