Zoop11
Having trouble with custom warp after skewing or altering perspective
Feb 18, 2012 1:10 PM
Hello, I'm using Photoshop CS3, and the warp tool seems to behave differently after performing the skew or perspective transformations.  If I try to warp after doing one of these two transformations, I am unable to click on any of the points or handles.   The only thing it will let me do is alter the lines, but the points themselves cannot be moved.  What am I missing?
Thank you for your help.  Let me know if additional information is needed.
  • Trevor Dennis
    May 24, 2010
    Feb 18, 2012 1:19 PM   in reply to Zoop11
    Are you doing this in one operation?  i.e.   Starting Free Transform, right clicking and chosing Skew, then after adjusting the selection, right clicking again and chosing Warp?
  • Trevor Dennis
    May 24, 2010
    Feb 18, 2012 3:18 PM   in reply to Zoop11
    Zoop11,  I am sorry but I can't duplicate the problem, although I am using CS5.   Have you tried the usual trick of deleting the preferences file?  I can't link on how to do that without knowing what OS you are using?
  • Trevor Dennis
    May 24, 2010
    Feb 18, 2012 5:50 PM   in reply to Zoop11
    OK.  It's too hard to remember all the small changes from version to version, and I obvioulsy didn't know about the Warp drag handles.  It's surprising how quickly you get used to a new version of Photoshop's additional feature and functionality, and how appallingly bad it feels if you ever have to use an earlier version.
    Apr 3, 2013 11:06 AM   in reply to Zoop11
    This problem occurs all the time, and has been an issue for at least the last 3 Photoshop releases. It's not just an issue with smart objects either, it happens with rasterized layers as well.
    You pull one control arm and it affects the control arm on the opposite side of the object you are warping - or in some cases a control arm stays frozen no matter where you pull.
    You cannot get the desired result through multiple transform operations because the grid no longer conforms to the shape of the object.
    Will this ever be fixed?
