Sorry for my english, I’m from Russia – I have a problem – I have a mobile phone (Android or iPhone), which is the access point, and he gives Wi-fi. To it is attached computer, but I can not get the result you want – I can not establish a connection between them, through Wi-Fi router everything is working fine, thank you
most likely your phone's access point doesn't do NAT hair-pin, where a device inside the NAT (your computer) sending a packet to your phone's public IP address isn't routed inside the phone correctly.
if you are doing groups communication (multicast NetStream or NetGroup), you can use IP multicast peer discovery (GroupSpecifier.ipMulticastMemberUpdatesEnabled=true and add an IP multicast address) to work around this issue. otherwise, 1:1 direct connections may not be possible in your configuration.
I use
var groupSpec:GroupSpecifier = new GroupSpecifier(any name);
groupSpec.postingEnabled = true;
groupSpec.routingEnabled = true;
groupSpec.ipMulticastMemberUpdatesEnabled = true;
groupSpec.addIPMulticastAddress("225.225.0.1:30303");
var groupSpecString:String = groupSpec.groupspecWithAuthorizations();
And this do not work!
Generally p2p works over tethering?
North America
Asia Pacific
