Is there a way to get Premiere to display the pixel type for a clip? RGB or YUV, 8u or 32f?
Thanks!
When using Premiere, I would like it to display the pixel format for a clip. I recall once seeing a way to display debug info including the pixel type overlayed on the image, but I can't remember how to get Premiere into that mode. If you know how to programmatically query the native pixel format for a clip, that would be useful as well ![]()
you need to make a filter and use the Clip Render Suite..
It's then up to you to render some text burn-in on the screen ( or make a standalone window that dynamically updates a textbox printout etc).
Look in PrSDKClipRenderSuite.h
** Given a specific clip, find out the number of pixel formats natively supported
** by this clip.
** @param inClipID The ClipID of the clip.
** @param outNumPixelFormats The number of pixel formats.
prSuiteError (*GetNumPixelFormats)(
PrClipID inClipID,
csSDK_int32* outNumPixelFormats);
** Given a specific clip get a native pixel format. The pixel formats will be returned
** in index order based on preference. The maximum index can be determined by using
** GetNumPixelFormats().
** @param inIndex The pixel format index.
** @param outPixelFormat The pixel format.
prSuiteError (*GetPixelFormat)(
PrClipID inClipID,
csSDK_int32 inIndex,
PrPixelFormat* outPixelFormat);
Annabella, it sounds like you're referring to the "Dog Ears" overlay mode. In the SDK Guide pdf, check out chapter 1 > "Debugging Plug-ins" > "Dog Ears". Or you can just search on "Dog Ears" in the SDK pdf.
The pixel format reported here isn't necessarily one of the formats natively supported by the clip, since there can be multiple source clips per frame. Instead, it shows the pixel format used for the render of all the clips / effects / transitions for that particular frame.
North America
Asia Pacific
