Chaining select lists
Feb 20, 2012 2:45 AM
  Latest reply: BKBK, Mar 6, 2012 5:40 AM
    Mar 6, 2012 12:56 AM   in reply to biene22
    So long as we understand that what we now have is experimental. It goes against the whole point of binding, which is to enable you to separate business code (like queries) from presentation code.
    Mar 6, 2012 5:01 AM   in reply to biene22
    What do you mean by 'binding doesn't work anymore'. If you get the select lists, then binding is working.
    I've just run a quick test. It works, at least on my system. What's your ColdFusion version?
    Mar 6, 2012 5:40 AM   in reply to biene22
    biene22 wrote:
    When I change  the department, values of selectlist "employee" are always the same. They does not depend on the selected value of department.
    ColdFusion 9 is as up to date as you can be. You could have experimented a bit with the above code. Binding to department is just a minor variation. For example,
    selectEmployee.cfm
    <!--- The employee ID (emp_id) is expected to come in as a URL parameter. The bind requires it when the page loads, so a default emp_id, 7, is set. --->
    <cfparam name="url.emp_id" default="6">
    <cfquery name = "select_user" dataSource = "cfdocexamples">
        SELECT department, FirstName || ' ' || LastName as emp_name
        FROM employees
        WHERE emp_id = #url.emp_id#
    </cfquery>
    <cfform name="empForm">
    Department: <cfselect  name="dept" bind="cfc:Employee.getDepartments()" bindonload="true" selected="#select_user.department#"></cfselect>
    <br>
    Employee:   <cfselect  name="employee" bind="cfc:Employee.getEmployees({dept})" bindonload="true" selected="#select_user.emp_name#" ></cfselect>
    <br><br>
    <cfinput name="sbmt" type="submit" value="Submit">
    </cfform>
    Employee.cfc
    <cfcomponent>
    <cffunction name="getDepartments" access="remote" output="false" returntype="array">
    <cfset var departments = queryNew("","")>
    <cfset var arr = arrayNew(2)>
    <cfquery name = "getDept" dataSource = "cfdocexamples">
        SELECT distinct(department)
        FROM employees
    </cfquery>
    <cfloop query="getDept">
    <cfset arr[currentrow][1]=department><!---option values in the select list--->
    <cfset arr[currentrow][2]=department><!---displayed values in the select list --->
    </cfloop>
    <cfreturn arr>
    </cffunction>
    <cffunction name="getEmployees" access="remote" output="false" returntype="any">
    <cfargument name="dept" type="string" required="true">
    <cfset var employees = queryNew("","")>
    <cfquery name = "employees" dataSource = "cfdocexamples">
        SELECT emp_id,  FirstName || ' ' || LastName as emp_name
        FROM Employees
       WHERE department = <cfqueryparam cfsqltype="cf_sql_varchar" value="#arguments.dept#">
    </cfquery>
    <cfloop query="employees">
    <cfset arr[currentrow][1]=emp_id><!---option values in the select list--->
    <cfset arr[currentrow][2]=emp_name><!---displayed values in the select list --->
    </cfloop>
    <cfreturn arr>
    </cffunction>
    </cfcomponent>
