The "CF10 feature PDF" says:
Server update... The updates can include hot fixes and security hot fixes for ColdFusion 10.
Will traditional "CF updaters" be a separate process apart from hotfix, cumulative hotfix and security update eg ColdFusion 9 Update 1 (9.0.1)?
Will the update type be specific and say-
Update Type: cumulative or hotfix or security?
Previously patch order had a bearing on the wellbeing of CF. For instance one would elect to install say updater1 followed by cumulative hotfix then subsequent security patch eg CF9.0.1, CHF1, APSBxx-xx. Will CF10 updater manage patch order or prerequisites not allowing incorrect update order?
Thanks, Carl.
The CF10 update using HotFix hf-zeus-00001 did not apply for me. How have others gone with applying HotFix hf-zeus-00001 update?
Server Update > Updates says:
UpdatesInstalled
Error Occurred while reading update information - An error occured while Parsing an XML document.
Debugging & Logging > Log Files > update.log says:
Successfully downloaded hotfix_0001.jar at C:\ColdFusion10\cfusion\hf-updates
Tried to apply HotFix hf-zeus-00001 update manually:
CMD
C:\ColdFusion10\cfusion\hf-updates>
C:\ColdFusion10\cfusion\hf-updates>echo %JAVA_HOME%
C:\ColdFusion10\jre
C:\ColdFusion10\cfusion\hf-updates>echo %PATH%
C:\Windows\system32;C:\Windows;etc;C:\ColdFusion10\jre\bin
C:\ColdFusion10\cfusion\hf-updates>java -jar hotfix_0001.jar
Prompts for Where is ColdFusion Zeus located
Offering
C:\ColdFusionZeus
Change that detail to correctly match setup
C:\ColdFusion10
The install seems to complete offering - Install Complete.
Tho upon logging in to CF Server Update > Updates does not show update installed.
Things noticed
-ColdFusion 10 Application Server stops
-ColdFusion 10 Application Server reports as being started
-CFadmin keeps responding:
Service Temporary Unavailable!
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Action taken
-Wait 15 minutes restart ColdFusion 10 Application Server
-Read thru Adobe_ColdFusion_Zeus_HotFix_1_Install_date_time.log seems to indicate success
Thanks again, Carl.
Hi Carl,
Form ColdFusion 10 onwards, all updates will be cumulative. This means that all fixes of previously relased hotfix be included in any new hotfix which comes later.
Also the previous process of deploying jar files in through Server Manager won't be relevant with ColdFusion 10 as now hotfix jar will be full installer(unlike previous hotfixes which required copying them to lib/updates folder in CF server).
Regarding the error with current hotfix, we are in prcess of updating new test hotfix which will be compatible with the beta release. If you have installed he current one, you can unistall it with uninstaller placed under <CF-HOME>/cfusion/hf-updates/<hotfix name> folder or through Admin (under Installed updates tab on updates page).
thanks,
Sandeep Paliwal
Adobe ColdFusion team
Hi Sandeep,
The online help indicates CF10 Server Manager can be used to apply updates?
http://help.adobe.com/en_US/ColdFusion/10.0/Admin/WSfd7453be0f56bba4-2 a6b48f122a6582c7f-7ff6.html
Heading "Apply hot fix"
"You can update multiple ColdFusion Server instances, once they are registered with Server Manager."
Regards, Carl.
Hi Sandeep,
Great that worked!
Server Update > Updates > UpdatesInstalled says:
HotFix hf-10-00001 Fri, 17th Feb 2012
Update Level: 01
Update Type: Cumulative
Install Date: Wed, 22 Feb 2012 17:18:02 +1000
Update Description:
This is ColdFusion 10 Beta cumulative hotfix 1.
This is a test hot fix created to get used to new hotfix installer feature.
Backup Directory: C:\ColdFusion10\cfusion\hf-updates\hf-10-00001
Install Log: C:\ColdFusion10\cfusion\hf-updates\hf-10-00001\hotfix_filelist.log
Server Settings > Settings Summary says:
System Information
Server Details
Server Product ColdFusion
Version ColdFusion 10,281485
Edition Enterprise (Trial)
Operating System Windows 7
OS Version 6.1
Update Level /C:/ColdFusion10/cfusion/lib/updates/chf10000001.jar
Adobe Driver Version 4.1 (Build 0001)
How does one correlate the update level report differences between "Server Update > Updates >
UpdatesInstalled" and "Server Settings > Settings Summary > Update Level"?
Thanks much, Carl.
Hi Sandeep,
Further when I ran remove update from:
The dialog prompted that CF10 would restart. It stopped however did not start. Run SERVICES.MSC and started "ColdFusion 10 Application Server".
Should the dialog be changed or was there a problem and you would expect CF10 to start without intervention after update removal?
North America
Asia Pacific
