• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
FAQ: What are the JDI (Just Do It) features in Photoshop?
Adobe Employee ,
Feb 22, 2012 Feb 22, 2012
What are JDI features?  They're "Just Do It" features: small features that don't take a lot of time to implement or test and seem like an obvious improvement.
JDI list for Photoshop CC
JDI features in Photoshop CS6, by category:
Automation
  • Contact Sheet II has been restored as an Automate option
  • PDF Presentation and Layer Comps to PDF have been restored as Automate options
Brushes
  • Add ability to record brush strokes in actions with "Allow Tool Recording" option
  • Brightness/contrast slider for textures when painting
  • Brush projection for static tips
  • Brush tip cursor reflects brush pose and jitter for round and captured tips
  • HUD brush resize and hardness can now change opacity - [Control] + [Option] + click drag up/down with General>Preferences> "Vary Round Brush Hardness based on HUD vertical movement" unchecked
  • Increase maximum brush size to 5000px
  • Change color dynamics to per stroke instead of per tip (user option for old behavior)
Channels
  • Enable Split Channels for documents with single layer (so you can split simple transparency)
Color Picker
  • allow clipboard paste into hex field with # in contents (i.e. #aabbcc), or 0x (i.e. 0xAABBCC)
  • allow shortcut hex values (i.e. #123)
Eyedropper
  • Add ignore adjustment layers options bar item for the eyedropper
  • New mode for eyedropper to select layers current and below
  • Show the sample size popup for the various eyedropper tools (black point, white point, etc.)
File Formats
  • Allow for reading more bit depths in TIFF files
  • Give the user choices regarding how they want transparency treated in OpenEXR on file open and save
  • Read BIGTIFF format (TIFF files over 4 Gig)
  • Read common stereo image pair formats (JPS, MPO, PNS)
GPU
  • Increased GPU stability by prequalifying GPUs on the fly before use
Grammar
  • Grammar policed throughout app
  • Use consistent grammar style in the title of dialog windows (no commands such as "Choose a color:")
Image Resizing
  • Auto-select the best resample method based on the type of resize (bicubic-automatic)
Importing
  • (Macintosh only) Import images from devices provides ImageKit scanning and camera acquisition support
Layers
  • Add bicubic sharper & bicubic smoother options when free transforming layers (menu in options bar)
  • Add dither options to Layer Styles for Gradient Overlay and Gradient Stroke
  • Allow 00 or Shift 00 to work when setting layer/fill opacity (previously no way to get 0%)
  • Allow changing color labels on multiple layers at once
  • Allow changing of blend modes for multiple layers at once
  • Allow locking of multiple selected layers
  • CMD+J to duplicate selected layers and layer groups (in addition to layers)
  • Layer tooltips to include layer name (if defined)
  • New command to rasterize layer effect into layer, merging the selected layers into themselves (Rasterize Layer Style)
  • Opt+click on toggle arrows (groups and effects)in layer panel should close all targets
  • Reorder effects in the layers palette to match the Z-order style/blend mode (bottom most effects in terms of blending order, drop shadow is below the other effects)
  • Show blend if/Blending Effects badge on layer if they are not default values
  • Show correct opacity and blend mode values for hidden layers
  • Tab goes to next layer on inline layer rename, SHIFT + TAB goes to previous
  • When creating a shape layer, the layer name should not be like "Shape 1" but instead reflect the tool named such as "Rectangle 1"
Liquify
  • Add option to load last mesh
  • Increase maximum Liquify brush size to 15,000
  • Resize Liquify brush with shortcuts: bracket keys [ ] now match same increments in Photoshop
  • ctrl (win) / cmd (mac) switches to magnifying glass
  • alt + right click + drag to change brush size (win)
  • ctrl + alt + left click + drag  to change brush size (mac)
Masks
  • Enable Invert and Threshold adjustments for masks in 32-bit/channel
Plugins
  • Hold SHIFT during startup to disable Optional and 3rd party plugins
Presets
  • Add New Document presets for common devices (e.g. iPhone, iPad, etc.)
  • Add new Gradient Map presets for traditional print toning and split-toning
  • Sticky reorganization of tool presets (changes persist after relaunch)
  • New HDR Pro presets from RC Concepcion and Scott Kelby
Printing
  • Add "Edit" button for the description field in the print dialog
  • Allow print dialog and print preview window to be resized
  • Allow user to change the "preview well" background color in the print dialog
  • Allow user to manually position the printed area on the page
  • Hide color profiles that are inappropriate for currently selected printer when using "Photoshop Manages Color"
  • Reintroduce "Print selected area", allow user to modify selection in print dialog
Save
  • Add warning message that 16-bit images cannot display their file size in the Save as JPEG dialog
SDK
  • Add ability to access tool name associated with the tool preset name via scripting
  • Add the ability to return an array of guides in a document from the scripting SDK
Selections
  • Make the marquee, lasso, and mask panel feather values support decimal places like the feather dialog
  • Remember feather radius when showing dialog for selection from a path
Transform
  • Don't hide smart object icon when transforming a layer
  • Improve dragging of vector curves
  • Rotate 90 with even x odd pixel dimension to not land on a half pixel position
  • Preference to disable auto-rotate on open
Type
  • Add command to insert "lorem ipsum" for type
  • Added Gamma rendering parameter for better text rendering
UI
  • [Windows] New/open document to context click on a document tab (has always been on Mac, now Windows too)
  • Add "Don't show again" checkbox to Purge warnings
  • Remove the app bar and reduce the drag/app bar over 30%
Views
48.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
New Here ,
Nov 17, 2021 Nov 17, 2021
LATEST
With the new masking technology in camera raw, more importantly on LR Mobile, Adobe could either do a major update on Mix or a photoshop mobile for Android devices
Votes
Translate
Translate
Report
Report
