I have some interesting foundings when studying the "XXXX.achacks.as" files. It seems that Alchemy v0.5 already has build-in (simple) GL and GDB support.
Some code copied here:
For GL:
Alchemy::NoShell {
public var gvglbmd:BitmapData;
public var gvglbm:Bitmap;
public var gvglpixels:int;
} // Alchemy::NoShell
public function vgl_lock():void
// nop
public function vgl_unlock():void
Alchemy::NoShell {
// blit!
if(gvglbmd && gvglpixels)
gstate.ds.position = gvglpixels;
gvglbmd.setPixels(gvglbmd.rect, gstate.ds);
public function vgl_end(dummy:int):int
Alchemy::NoShell {
var pixels:int = gvglpixels;
gvglpixels = 0;
return pixels;
return 0;
public var vglKeys:Array = [];
public var vglKeyFirst:Boolean = true;
public var vglKeyUEL:*;
// mode...
// 1: VGL_RAWKEYS
// 2: VGL_CODEKEYS
// 3: VGL_XLATEKEYS
public var vglKeyMode:int;
public function vgl_keyinit(mode:int):int
trace("vgl_keymode: " + mode);
vglKeyMode = mode;
return 0;
public function vgl_keych():int
if(vglKeys.length)
return vglKeys.shift();
return 0;
public function vgl_init(width:int, height:int, pixels:int):int
Alchemy::NoShell {
var stage:Stage = gsprite.stage;
trace("vgl_init: " + width + " / " + height + " : " + pixels);
if(vglKeyFirst)
// windows VK_ (keyCode) => scan code
var vk2scan:Array = [
0, 0, 0, 70, 0, 0, 0, 0, 14, 15, 0, 0, 76, 28, 0, 0,
42, 29, 56, 0, 58, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0,
57, 73, 81, 79, 71, 75, 72, 77, 80, 0, 0, 0, 84, 82, 83, 99,
11, 2, 3, 4, 5, 6, 7, 8, 9, 10, 0, 0, 0, 0, 0, 0,
and for GDB:
Alchemy::NoShell
public class GDBMIDebugger
Alchemy::NoDebugger {
public function GDBMIDEbugger(dbge:Debuggee) {}
Alchemy::Debugger {
var sock:Socket;
var debuggee:Debuggee;
public function GDBMIDebugger(dbge:Debuggee)
sock = new Socket();
debuggee = dbge;
sock.addEventListener(flash.events.Event.CONNECT, sockConnect);
sock.addEventListener(flash.events.ProgressEvent.SOCKET_DATA, sockData);
sock.addEventListener(flash.events.IOErrorEvent.IO_ERROR, sockError);
sock.addEventListener(flash.events.SecurityErrorEvent.SECURITY_ERROR,
sockError);
debuggee.suspend();
try
sock.connect("localhost", 5678);
catch(e:*)
sockError(e);
Also, in "alchemy\avm2-libc\include\" folder, you can find a header file "vgl.h", full file copied below:
#ifndef _VGL_H_
#define _VGL_H_
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <machine/cpufunc.h>
typedef unsigned char byte;
typedef struct {
byte Type;
int Xsize, Ysize;
int VXsize, VYsize;
int Xorigin, Yorigin;
byte *Bitmap;
int PixelBytes;
} VGLBitmap;
#define VGLBITMAP_INITIALIZER(t, x, y, bits) \
{ (t), (x), (y), (x), (y), 0, 0, (bits) }
* Defined Type's
#define MEMBUF 0
#define VIDBUF4 1
#define VIDBUF8 2
#define VIDBUF8X 3
#define VIDBUF8S 4
#define VIDBUF4S 5
#define VIDBUF16 6 /* Direct Color linear buffer */
#define VIDBUF24 7 /* Direct Color linear buffer */
#define VIDBUF32 8 /* Direct Color linear buffer */
#define VIDBUF16S 9 /* Direct Color segmented buffer */
#define VIDBUF24S 10 /* Direct Color segmented buffer */
#define VIDBUF32S 11 /* Direct Color segmented buffer */
#define NOBUF 255
typedef struct VGLText {
byte Width, Height;
byte *BitmapArray;
} VGLText;
typedef struct VGLObject {
int Id;
int Type;
int Status;
int Xpos, Ypos;
int Xhot, Yhot;
VGLBitmap *Image;
VGLBitmap *Mask;
int (*CallBackFunction)();
} VGLObject;
#define MOUSE_IMG_SIZE 16
#define VGL_MOUSEHIDE 0
#define VGL_MOUSESHOW 1
#define VGL_MOUSEFREEZE 0
#define VGL_MOUSEUNFREEZE 1
#define VGL_DIR_RIGHT 0
#define VGL_DIR_UP 1
#define VGL_DIR_LEFT 2
#define VGL_DIR_DOWN 3
#define VGL_RAWKEYS 1
#define VGL_CODEKEYS 2
#define VGL_XLATEKEYS 3
extern video_adapter_info_t VGLAdpInfo;
extern video_info_t VGLModeInfo;
extern VGLBitmap *VGLDisplay;
extern byte *VGLBuf;
* Prototypes
/* bitmap.c */
int __VGLBitmapCopy(VGLBitmap *src, int srcx, int srcy, VGLBitmap *dst, int dstx, int dsty, int width, int hight);
int VGLBitmapCopy(VGLBitmap *src, int srcx, int srcy, VGLBitmap *dst, int dstx, int dsty, int width, int hight);
VGLBitmap *VGLBitmapCreate(int type, int xsize, int ysize, byte *bits);
void VGLBitmapDestroy(VGLBitmap *object);
int VGLBitmapAllocateBits(VGLBitmap *object);
/* keyboard.c */
int VGLKeyboardInit(int mode);
void VGLKeyboardEnd(void);
int VGLKeyboardGetCh(void);
/* main.c */
void VGLEnd(void);
int VGLInit(int mode);
void VGLCheckSwitch(void);
int VGLSetVScreenSize(VGLBitmap *object, int VXsize, int VYsize);
int VGLPanScreen(VGLBitmap *object, int x, int y);
int VGLSetSegment(unsigned int offset);
/* mouse.c */
void VGLMousePointerShow(void);
void VGLMousePointerHide(void);
void VGLMouseMode(int mode);
void VGLMouseAction(int dummy);
void VGLMouseSetImage(VGLBitmap *AndMask, VGLBitmap *OrMask);
void VGLMouseSetStdImage(void);
int VGLMouseInit(int mode);
int VGLMouseStatus(int *x, int *y, char *buttons);
int VGLMouseFreeze(int x, int y, int width, int hight, byte color);
void VGLMouseUnFreeze(void);
/* simple.c */
void VGLSetXY(VGLBitmap *object, int x, int y, u_long color);
u_long VGLGetXY(VGLBitmap *object, int x, int y);
void VGLLine(VGLBitmap *object, int x1, int y1, int x2, int y2, u_long color);
void VGLBox(VGLBitmap *object, int x1, int y1, int x2, int y2, u_long color);
void VGLFilledBox(VGLBitmap *object, int x1, int y1, int x2, int y2, u_long color);
void VGLEllipse(VGLBitmap *object, int xc, int yc, int a, int b, u_long color);
void VGLFilledEllipse(VGLBitmap *object, int xc, int yc, int a, int b, u_long color);
void VGLClear(VGLBitmap *object, u_long color);
void VGLRestorePalette(void);
void VGLSavePalette(void);
void VGLSetPalette(byte *red, byte *green, byte *blue);
void VGLSetPaletteIndex(byte color, byte red, byte green, byte blue);
void VGLSetBorder(byte color);
void VGLBlankDisplay(int blank);
/* text.c */
int VGLTextSetFontFile(char *filename);
void VGLBitmapPutChar(VGLBitmap *Object, int x, int y, byte ch, byte fgcol, byte bgcol, int fill, int dir);
void VGLBitmapString(VGLBitmap *Object, int x, int y, char *str, byte fgcol, byte bgcol, int fill, int dir);
#endif /* !_VGL_H_ */
So is there any document for them, or anyone has ever figured out how to use the VGL apis in alchmey?
