tomSperlinger
Set 'transparency flattener presets' to [High Resolution]
Feb 23, 2012 8:32 AM
http://help.adobe.com/en_US/illustrator/cs/using/WS9327D15E-A9FF-4698- BDA5-8791A891D061.html
I am editing thousands of images that need to be exported as High Res .eps's.
Is there a way to make [High Resolution] the default rather than [Medium Resolution] ?
    Feb 23, 2012 9:31 AM   in reply to tomSperlinger
    edit this file
    user/(yourname)/library/preferences/adobe Ilustrator 4 settings/en us/Transparency Flattener Presets
    Collection 2 is your default so I edited those values to match the screenshot below hope I got them right. Replace the code with below (keep a backup of original just in case)
    /collection3 {
    /attributes {
    /AI9\ Mesh\ Rasterization\ Resolution 144.0
    /AI9\ Output\ Rasterization\ Resolution 288.0
    /AI10\ flattener\ raster-vector\ balance 75
    /AI10\ flattener\ clip\ complex\ regions 0
    /AI10\ flattener\ outline\ strokes 1
    /AI10\ flattener\ outline\ text 0
    /collectionName [ 16
    5b4c6f77205265736f6c7574696f6e5d
    /canEdit 0
    /canDelete 0
    /collection2 {
    /attributes {
    /AI9\ Mesh\ Rasterization\ Resolution 300.0
    /AI9\ Output\ Rasterization\ Resolution 1200.0
    /AI10\ flattener\ raster-vector\ balance 100
    /AI10\ flattener\ clip\ complex\ regions 1
    /AI10\ flattener\ outline\ strokes 0
    /collectionName [ 19
    5b4d656469756d205265736f6c7574696f6e5d
    /canEdit 0
    /canDelete 0
    /collection1 {
    /attributes {
    /collectionName [ 17
    5b48696768205265736f6c7574696f6e5d
    /canEdit 0
    /canDelete 0
    /Sketch {
    /Version 1
    /Description (Flattener catalog for AI11)
    /Owner (AI11 Flattener Catalog Manager)
    /NumberOfCollections 3
    /CatalogName (AI11 Flattener Presets)
    A different version I made with the help of Carlso Canto, worked for me to slide the vector balance to bitmapped . So hope the code above works for you.
    Nov 5, 2012 3:11 AM   in reply to tomSperlinger
    I Have the exact same issue. The default is medium resolution, and even with the setting edits above illustrator opens with the custom settings equivalent to medium resolution. If I delete medium resolution altogether it causes issues saving.
    I need to change it as the 'convert strokes to outlines' setting causes trouble with double cutting on our large format plotter. I have to manually change every file in the attempt to stop the issues.
    Is there no way to effectively change the default transparency setting? Seems a little odd?
    Thanks.
    Dec 17, 2012 5:30 PM   in reply to BottyZ
    I am having the same issue with CS6. I need Illustrator to default to High Resoultion. ? Thank you!
    Jan 22, 2014 6:38 AM   in reply to BottyZ
    My workaround was to create a Flatten Transparency preset (at the bottom of dialogue box) after changing resolution to High. Now it defaults to this setting each time.
