arenol
Getting the global position matrix for each text character
Feb 24, 2012 2:53 AM
Tags: #glyph #coordinates #matrix #ilustrator #ate
This post is a follow up to this related post.
I need to get the position and orientation of the first and the last character in a text frame art, that is, I need its  matrix.
There are a number of functions in the API that is supposed to help you; here's a snippet from the file ATESuites.h
/** Return transformation matrix of this run.
The matrix returned spesify the full transformation of the given run.  You need to transform the origin by IGlyphRun::GetOrigins() and
concat with ITextFrame::GetMatrix() in order to get the location of the glyphs.
ATEErr (*GetMatrix) ( GlyphRunRef glyphrun, ASRealMatrix* ret);
Hence, getting the matrix of the first character or glyph should look something like this:
AIErr
VMGetFirstTextMatrix(  AIArtHandle textArt, AIRealMatrix *matrix)
    ASRealMatrix frameMatrix, glyphMatrix;
    ASRealPoint firstPoint;
    try
        TextFrameRef ateTextRef;
        sAITextFrame->GetATETextFrame( textArt, &ateTextRef);
        ITextFrame textFrame( ateTextRef);
        ITextLinesIterator lnItr = textFrame.GetTextLinesIterator();
        ITextLine txtLine = lnItr.Item();
        IGlyphRunsIterator grItr = txtLine.GetGlyphRunsIterator();
        IGlyphRun glyphRun = grItr.Item();
        IArrayRealPoint pointArray = glyphRun.GetOrigins();
        firstPoint = pointArray.Item(0);   // comes out with wrong values!!!
        frameMatrix = textFrame.GetMatrix();
        glyphMatrix = glyphRun.GetMatrix();
        sMath->AIRealMatrixConcatTranslate( &glyphMatrix,
                        firstPoint.h, firstPoint.v);
        sMath->AIRealMatrixConcat( (AIRealMatrix*) &glyphMatrix,
                   (AIRealMatrix*) &frameMatrix,
                   matrix);
        return kNoErr;
    catch (ATE::Exception e)
        return e.error;
        return kNoErr;
But the coordinates, either returned in frameMatrix (tx and ty) or the firstPoint are obviously wrong. It appears that they an offset which is allmost constant.  The x-values are approx 7664 points too large (give and take a few decimals), and the y-values are approx 7893 too large (also give and take a few decimals).
I'm reall puzzled by this, because I need to get accurate positions...
    Feb 24, 2012 4:11 AM   in reply to arenol
    Like I said in the other thread.... it sounds like you need to convert between hard and soft coordinates.
