I'm hoping someone can give me some clear guidance as to how to configure my software to integrate color management so that what I see on my monitor is comparable to what I print or post on the web. I've read all I can find on-line and looked through a number of books and magazines, but as my reading increases, so does my confusion - too many menus, options, links and connections. I'll describe what I have in terms of hardware and software in as much detail as possible. My hope is that someone can help me figure out how to coordinate color management across all platforms and outputs.
I run an HP desktop with an ASUS IPD monitor. I have ColorMunki and have reguarly conducted their diagnostic, which gives me an updated monitor profile every two weeks - when a new profile is created, it becomes my default under Windows 7 Control Panel Color Management. I print with an Epson Stylus Photo R1900 with Epson paper and ink. I use the printer and paper profiles supplied by Epson for the R1900 and specific papers.
On the other end, I have Nikon photo equipment. I set the color space on my cameras to ProPhoto and I shoot exclusively in Nikon raw format - .NEF. I shoot a D90 and a D7000 with 12M and 16M files respectively. I download directly from the SD card using Windows Explorer and then import into Lightroom 3.
I have Lightroom 3 and Photoshop CS5 Extended. I use Lightroom to import raw files into the catalog and to do basic editing. From there, I publish to Smugmug as .TIFF files - directly from Lightroom. I also export files from Lightroom to Photoshop CS5 Extended and save them as .PSD and .JPEG files. The files that I export to Smugmug look pretty good - similar to what I see on my screen. My real conundrum is with the Epson printer and Lightroom/Photoshop. What I see on my monitor is very different from what prints. From both platforms. As a rule, the shots are too dark and the colors are often very muted. This is especially true with images of people and skin tones. They often come out looking pale gray or blue.
Right now, my solution is to tweak and print until I get something close enough to print, while the image on my monitor looks horrible. Needless to say, this is not a viable solution for the long term - it is too expensive and time consuming. I've tried to read and then adjust adjust both programs, but I'm confused as to what to set where. I've taken to explorting Lightroom files into Photoshop to use the soft-proof capability. it works better but still not great and not consistent. When I do the Photoshop soft-proof, I see signficant portions of most images as "out of gamut>" I also notice that these areas are often the ones with odd colors.
My problem, (well, one of them) is the multitude of menus that have color management inputs - how do I make sure they are all working together and reinforcing each other instead of working at cross purposes? In Lightroom, I have Page Setup and Print Preferences, as well as Color Management options in the Print Module right hand panel. In Photoshop, I have Print and Page setups, as well as Color Management menus. There are also the Proof menus to consider.
In Photoshop, softproofing, I think I ned to select teh printer profile so that Photoshop is showing me how the printer will interpret the color space. I also think I need to be consistent in how I define the workspace - from Nikon to Lightroom to Photoshop to Epson. If I use ProPhoto with my camera do I need to use that in every circumstance? Should I switch to Adobe RGB? I have printer setting color space turned off in both LR and PS.
Can someone walk me through any or all of this? Right now, all of these moving parts is making me dizzy. It's said that a little knowledge is a dangerous thing. This proves the point. Three months ago, I had color management problems but had no idea what such a thing was. Now, I know a lot more about it, but my results are no better - worse in some respects. Anyone who can help will earn major Karma points and hae my undying gratitude for several months. Sorry - that's all the compensation I can offer!
Thanks in advance for any help.
Don't be surprised if this thread blows up into all kinds of chaos, as most color-management threads do.
Basic color-management training, to get you to where you understand how it all works and why you'd want to choose particular settings, is likely beyond the scope of a forum.
You'll find that a number of people will tell you "do this" or "do that", trying to show you one way to achieve what you want. Try not to latch onto suggestions like that - you really do need to try to understand how it works - there's no "one size fits all needs" setting, and their needs are not the same as your needs. In fact, there are very good reasons for the existence of all the settings.
Lastly, there's a lot of MISinformation out there. Try to make sense of what you read, and if it doesn't seem to make sense, question it.
Best of luck!
-Noel
rcheek6 wrote:
…If I use ProPhoto with my camera do I need to use that in every circumstance? Should I switch to Adobe RGB?…
The color space you set in your camera is totally irrelevant for raw images, as the color space applies only to in camera recorded JPEGs, not to raw NEFs. The color space is recorded in metadata, but Adobe Camera Raw ignores it in raw files.
As for color management, please read this:
As Noel says, there is no "perfect" answer for you as your requirements are different from mine, or anyone else. However, I can advise in what I think will help you create a little more consistency based on my own experience.
The first thing should be to have the same profile running both your monitor and your photoshop/lightroom programs so that you get a more accurate representation on screen. In my case, I do mostly web work so all my settings are set to sRGB which works well for me. If your printer has a profile, set it as well and keep in mind 'most' desktop printers use the RGB colour space (you can check yours through online or with the user guide). Adobe RGB has a bigger colour gamut than sRGB which might aid in your printed copies, but not necessarily the on screen ones.
The thing to keep in mind is that what you will see on screen will never match exactly what you see when printed, which i'm sure you're aware of - but you can get it pretty close. The difference being the screen colours are light based, whereas the print colours are ink.
The odd times I do send stuff to print via our office laser, the print is fairly accurate to my screen representation, certainly clearer than other peoples in the office who haven't set their systems up in the way I have.
Good luck getting a match that works for you.
Here we go already!
RikRamsay14 wrote:
…have the same profile running both your monitor and your photoshop/lightroom programs…
The monitor profile and the working space profile should never be the same. The monitor profile must be a device-dependent profile (derived from calibration and profiling of each individual monitor). The working space profile must be a device-independent, standard profile such as ProPhoto, Adobe RGB. sRGB, etc. ![]()
Again, see http://www.gballard.net/psd/cmstheory.html
Actually, there are some very well-reasoned circumstances where one might want to use the sRGB profile for the monitor, and there can be distinct advantages to doing so. But I will not be drawn into an argument so I'll leave it at that. Your point of view has merit but stating such things matter-of-factly will just get you into trouble.
The important point is that for everything that's settable, someone will come up with a situation where it is reasonable to set it, so blanket statements of what to do or what not to do are not particularly helpful.
The user MUST be educated to the point where he knows why the various settings exist, what the implications are of setting them, and can make his own reasoned decisons for what to set them to. There seems to be no other good way to approach color-management problems.
So perhaps we can begin to answer specific questions about what each setting does? Rcheek6, what setting would you like to know about first?
-Noel
Please explain why and under what circumstances anyone would want to use a device independent profile as a monitor profile, which should be a device dependent profile.
I say this even though I am currently using a printer profile as my monitor profile. So there, purists.
And is that the hand of God in the picture?
it's hard to argue a valid point (i believe i understand your point)...though it comes across (to me) on the same basic level as setting Photoshop's Working RGB to its custom monitor profile, and trying to "turn color management off" (IMHO)
while they could all be well-reasoned, why, when someone is learning to walk, it might be good to stress the importance of taking a solid first step and then putting one foot in front of the other before trying to run a footrace...
That was a nearly mature tornado forming in Nebraska, and it dissipated at the last moment because at that time the sun went down and the temperature dropped rapidly. I was glad, because I was camping in a travel trailer at the time, and everyone knows trailers attract tornados. ![]()
Here's one example, to answer your specific question:
You have a monitor that provides sRGB performance (e.g., via a specific sRGB setting). You judge (and/or ensure via your own calibration) that it provides satisfactory sRGB color accuracy for your needs, so you set the monitor profile to sRGB, which is accurate in this case.
What does this do for you?
In short, setting up a soup-to-nuts sRGB system means more images match more often across more applications with a system set up this way. If I'm not mistaken, that's about what the original poster is asking about, which is why RikRamsay's response is not unreasonable.
And there are, of course, some specific disadvantages to doing this.
-Noel
'scuse me for a second, just a few remarks for the OP...![]()
rcheek6, this isn't very complicated in principle, but you need to narrow it down. If you can't test on another known good system, you need to isolate the problem.
1. First make sure all your files actually have embedded profiles. Which one isn't urgent for now, that's not the immediate problem.
2. Verify your monitor profile. Make a black to white gradient and look for color casts and sudden steps. Also, just for diagnostic purposes, try to replace it with a standard profile (sRGB or Adobe RGB depending on standard or wide-gamut monitor) and see if it makes a dramatic difference (it shouldn't).
One thing that is frequently overlooked is this: is your monitor too bright? Out of the box most monitors are.
3. Look carefully at the print settings. If Photoshop manages color, make sure printer color management is really off so you don't get double profiling.
The point of all this is to find out which "color management chain" has problems - document > monitor, or document > printer. They are independent.
Which browser you use can have impact on how this appears posted on the web. Leave that out of the equation for now.
Guys, I've come to trust Noel on this - for his purposes. It wouldn't work for me. But don't mistake this for ignorance, Noel knows every nook and cranny of what a monitor profile is and what it does and doesn't. Just wanted to assure you of that.
EDIT: But RikRamsay14 got it completely wrong. There's a difference.
Thanks for the vote of confidence, Dag. Your support means a lot to me. I didn't actually read RikRamsay's response in great detail; all I picked out was that he was suggesting sRGB for the monitor, and I was really responding to the other posters. My main point is that the settings are all meaningful and useful, and there really are no "just do it this way" answers. I even said that in my first response. ![]()
For those of you "doubting Thomases" who might dispute whether my monitors are accurately rendering sRGB, please understand that they are calibrated to be quite accurate, and they perfectly match one another - this is an sRGB reference system. Note that I clearly described the general difficulty in assuring accuracy near the end of my post above. But it is doable.
But also realize that "close enough for web work" isn't might not a put-down, but in fact could be quantified a real, reasonable requirement. You might imagine that a high quality monitor that with a factory "sRGB" setting could achieve a close enough sRGB rendering, right out of the box, that a web designer could use it to create good web pages.
-Noel
I find posts like this misleading and irrelevant. As such I feel sorry for anyone who happens to come to this thread looking for ideas or solutions to their colour management problems. There is a large number of threads, and posts on this forum about colour management and they all end up the same way (as Noel rightly warned the OP about at the start) but what you, and other people need to realise is that there is a different solution for everyone.
I did not get it "completely wrong". For my current workload this setup works prefectly well for me and has been tested numerous times using various machines/OS/browsers. As I mentioned in my post, my work is web based so having everything in sRGB is very valid for my use and keeps everything I work on consistent - this was the OP's main aim (unless I am mistaken).
I find no real issue with my setup and have not come across a colour problem in the 5 years or so I have used sRGB as the monitor profile - and my main workload used to be print based. As long as you understand the changes you have made to your system, you can run the setup you are most comfortable with for your own requirements.
Rik
Noel Carboni wrote:
...For those of you "doubting Thomases" who might dispute whether my monitors are accurately rendering sRGB, please understand that they are calibrated to be quite accurate, and they perfectly match one another - this is an sRGB reference system.
Sure, if you're going for the lowest-common-denominator and assume an all-web workflow and output, I have no reason to doubt that you'll be "ïn the ballpark" in an all-sRGB environment, provided your monitor is not too seriously out of whack That is evidently setting the bar too low, and in this context one needn't be too concerned with an accurate color management. I had presumed the original poster meant otherwise, otherwise I wouldn't have bothered to comment in the first place.
I did not intend to cast aspersions on anyone or question their credibility. Sorry if I misunderstood.
Then this is at best extremely unfortunate phrasing. No, it is not "the first thing" - it is the very last thing. It does not give you a "more accurate representation", quite the contrary.
Unless you know what you're doing, then your point of attack becomes the monitors themselves. This is what Noel is doing, and he's always careful to emphasize that.
On the face of it, using sRGB as both document and monitor profile accomplishes one thing: it disables monitor color management. It turns Photoshop into Internet Explorer, display-wise. Is that what you want to recommend to people?
i try to keep an open mind and am always interested in learning different ways especially from those who understand what they are doing
for me — with a hardware-profiled monitor — i believe Photoshop is already giving me a highly 'accurate' display of sRGB source images
the problem i see with setting the default monitor profile to a generic, 'uncalibrated' device-independent sRGB profile is Photoshop will no longer give me an 'accurate' display of any source image, including sRGB — because — a hardware profiling routine dials in the 'accuracy' i require in my business to proof my projects on a trustworthy reference monitor
i have published many thousands of images on the web across thousands of web pages, and concluded the best i can do is upload sRGB (and forget about it) so i don't give it much thought these days
it's too bad these threads in this forum always seem to have a negative cloud cast over them, but there are some very basic, hard-fast rules that need to be made clear and understood if we are talking about color management in Photoshop — how Photoshop uses profiles
for me, that includes setting Photoshop up to use the correct source profile, and properly convert to 'accurate' device-dependent profiles (monitor and print spaces)
The first problem, as I hinted at before, seems to be that the realm of color-management is both complex and can/should be tailored for individual needs.
Additional difficulty comes into it because there are some good, nearly "turnkey" solutions in which you can purchase additional hardware and run a program, and have a number of things set up automatically for you. But unfortunately, this doesn't really alleviate the need to understand what's going on.
The only real way to get things right is to understand how things work (or possibly more importantly how certain things don't work), and understand what the various settings all do so as to be able to make intelligent choices with each one. One has to understand what to expect and what not to expect.
Add to all this the fact that the game is continually changing - browsers are coming out with more capabilities, new software packages are being released, more file formats are being recognized, profiles get loaded by Windows Update, more different devices are appearing for producing images, color-management dialogs are changing from OS to OS... The list goes on. It's almost a wonder any of us can keep up!
So everyone: Please don't worry, and try to relax. Color-management is important, but not so important to get upset at one another about. ![]()
-Noel
gator soup wrote:
buying a wide-gamut monitor, enabling its sRGB preset (to 'dumb' it down), and then setting the OS default monitor profile to sRGB so it displays the internet 'properly' seems counter productive to "color-managed" Photoshop work flow...
In your environment and with your needs you may well feel that operating with additional gamut gives you an advantage.
But imagine for a moment that other advantages might just outweigh this one for some folks, who have different needs than you do. If there weren't a need for the functionality, do you think the monitor makers would take the time to engineer it in?
Using the term "'dumb' it down" to describe setting a color display's response and gamut to a known standard seems a bit emotionally charged, don't you think? As one who uses such a setup myself, because of the significant advantages it provides me with all the development work I do, and given that I haven't had any problem getting pretty pictures on paper, I don't find such a setup in any way "dumbed down". It's not like an sRGB display puts up nothing but off-gray images!
-Noel
Noel, the words i chose are what they are to most people, i understood what you wrote, no sense keep repeating ourselves
i am talking about Photoshop theory, not Microsoft environments or second guessing how my sRGB might appear on anyone elses web browser
i can tell you the confusion (and flying fur) here begins with posters circumventing Photoshop's color-management chain, Photoshop's ability to display color 'accurately'
setting Photoshop's Working RGB to the OS's default monitor profile is one recomendation that always seems to get a negative response here, but even that doesn't break Photoshop's ability to 'accurately' display a source document like setting sRGB as the default monitor profile
i would expect to see advice like that on Microsoft's forum, not Photoshop's, but that's just my opinion
Thanks for the comments. I had no idea this would bring out so many personality clashes. I understand how complicated and complex this subject is - that's why I was trying to get the input of those who have figured it out - at least to a greater degree I. I also know that the material out there can be conflicting and confusing. I've read most of what I can find on-line, which is a lot. After I read each document, I think I've figured it out, only to find I've just tweaked a system and gotten unexpected results - and the system is so complex that I can't associate cause with effect. I'm sure I included far more information than necessary in my original post - I know that camera color space has no impact on RAW files - but I've learned that when asking for advice on a forum, include as much info as possible, relevant or not. It's always easier to ignore irrelevant data than to ask for unprovided but necessary data. Finally, I appreciate all of the energy and effort expended to try to help me. I'm sure one or more of you is completely right and none of you are completely wrong. As I said, I know just enough about color management to completely "F" it up - which I have done quite well.
Someone asked which variable I want to focus on first. That's actually a good question and I can provide a couple of priorities. Right now, I'm having fair luck in printing non-human subjects - landscapes, wildlife, architecture, etc - from Photoshop CS5 Extended. I send the RAW file to Photoshop from Lightroom and soft proof it. The soft proof image is fairly close to what my Epson R1900 prints. But, with skin tones, it's still not close. It takes me several trial and error prints to get it right - wasteful and time consuming.
Here is a problem or disconnect I'd like to focus on first, if that is acceptable to those trying to help me: If I have a RAW file open in Lightroom 3 and I send it to Photoshop to "Edit as a Smart Object", I get an "Embedded Profile Mismatch" message. It tells me that the RAW file has an embedded color profile (ProPhoto RGB) that does not match the working space profile (the working space profile default is the profile created by ColorMunki for my ASUS monitor - a wide gamut monitor). I have three options - keep the embedded profile (ProPhotoRBC), convert to the current workspace (ColorMunki monitor profile), or discard the embedded profile (don't color manage.) Keep the embedded profile is the default, and that's what I've been doing.
Some questions - is ProPhotoRGB the best color profile? If not, if Adobe RGB is better, how do I change that for my Lightroom RAW files. Should the ColorMunki device-specific profile the right choice for current workspace for Photoshop? If not, which one should I select? If the ColorMunki profile isn't right for Photoshop color workspace, where do I use the monitor profile?
This seems like a good place to start - at least to me. As I said - I'm sure I'm making a dozen mistakes, but I've read so many different things on-line that I can't keep much of it straight.
Thanks in advance for any guidance, and please - try not to injure each other on my account.
I find colormanagementinfo.com to be a good starting point, well-written and understandable. The colour management settings in LR are not user-editable, so no need to worry about them.
Well, I think color management discussions have improved tremendously lately. In the past it happened way too often that people would just read out the textbook answers blindly - without even understanding them - and shoot those who didn't immediately join the fold on the spot.
Gator, I do it the way you do. It's the only way that works for me. But over time I've come to realize that Noel in fact knows this stuff inside out, and if he still chooses to do it the way he does, he must have good reasons. (I didn't always think so BTW). That's not to say his approach would work for others.
The main thing is that people should know what they're doing, and understand the implications. Of course you can't expect everyone to fully understand every aspect of color management. That's why everything is set up by default to "just work" without any user intervention, and beyond that there are guidelines for "safe practices".
One of these is to calibrate and profile your monitor. If you do that, you simply can't go wrong, if you just take a few precautions. This is why it is the right thing to tell newcomers who can't get their colors right, or don't understand why they're inconsistent between Photoshop and other apps.
But when you've been in this business for some time, you realize that calibrating and profiling is not written in stone. You choose your parameters based on the final output. You realize that you will in any case have to translate what you see on screen to how it will appear in print. It's not a 1:1 ratio.
I've calibrated a fair number of monitors up through the years. Getting two to match is almost impossible, even if you use the same sensor, the same software, and tweak the settings and parameters until they scream for mercy. They just won't look exactly the same.
We all make categorical statements based on an incomplete or faulty understanding, yours truly as much as anyone else. The trick is to try not to be too defensive or confrontational. I know, easier said than done. My reply to RikRamsay14 above could have been phrased better. But I stand by what I said, because that post was based on a lack of understanding.
EDIT: wow, about 15 new posts in the time it took me to write this...
Photoshop's "Working Space" settings are your way to let it know what DOCUMENT color profile you PREFER to work in. You would generally NOT want to set the working space to a device-specific profile such as that produced by a profiling device.
Let that sink in a moment...
When Photoshop warns you, it's just telling you that the image you're about to start editing as a document does not have the color space that you have told it you prefer to work in.
As for why you might choose to prefer a particular color space, well that gets a bit subjective, but one way to start might be to think about the color space you'll need for your work products. And you'll want that color space to be a standard, device-independent one, suitable for documents.
So, if for example, you plan to create high quality prints on a printer that can reproduce colors beyond the sRGB gamut but perhaps within the wider Adobe RGB gamut, then maybe you want to consider making Adobe RGB your preferred working space. That your monitor can reproduce this working space substantially adds to that decision.
On the other hand, if compatibiility with several printers (local and/or online) is important to you, and at least some of these printers use sRGB, then maybe you might want to choose the sRGB profile for your preferred working space.
Believe it or not, the working space choice can also be influenced by whether you tend to work in 8 or 16 bits/channel. Knowing that some functions and filters don't work on deeper 16 bit data, some folks choose to work at the lower depth, and at a lower depth a wide gamut profile tends to expose posterization more. I mention this because given the above, thoughts might tend toward "well, why not just work in the widest gamut space around?"
So, assuming I didn't misunderstand you and that you've set your preferred Photoshop working space to a profile you made for your monitor, let's try to get your working space setting in Photoshop right first. What are your specific goals for images you process?
-Noel
Well, he did say it is calibrated first and that it conforms to sRGB. Therefore, there is some interchangeability. However, to avoid any possibility of error, if the monitor displays sRGB or any other space you care to use, then set sRGB in Color Settings.
Of course, if all you ever use is sRGB or the Adobe RGB, then using it as a monitor profile might make some sense. But all my training and experience with calibration rails against such a procedure. Reason? It stops chasing one's tail when looking for errors even very slight errors (or should I say especially!). Having a fixed position independent of other profiles entered during processing, is always, always the stable position. For me, that stable position is leaving the monitor profile as is, which is determined with the cal/profile system, in the case of the OP, Color Munki.
rcheek6, it sounds similar to when I have accidentally double profiled the printer. Be sure you have the entire sequence configured correctly. I have very similar system lineup, substituting the Epson 3800 for yours. It runs very smoothly in general. When it doesn't, I know where to look, and if I ask for help, I can factor that into the whole much easier and with a significant degree of replication.
Finally, I believe Color Munki is a part of X-Rite's color management offerings. X-Rite offers training to deal with these sorts of problems.
Good luck!
But how do you actually DO what you say. It isn't possible to just plunk
device independent profiles into dependent devices, as gator has
pointed out. As I mentioned before, I have an Epson RGB gamma 1.8
profile in my monitor now, BECAUSE I WANT TO and not for any other
reason . I'm going to try some prints and then put it back to where it
was. You seem to be saying that any sRGB is as good as any other.
Why are you using a device dependent profile as a working space? That
breaks the rules right there. RAW is linear gamma and all the
information is in the high brightness end. Pro Photo is a 1.8 gamma
space with good yellows. Adobe RGB as a working space is whatever you
want it to be gamma wise. You can use ProPhoto as your working space but
you have to be careful making big adjustments.
Camera working space to Photoshop working space to rendering intent to
monitor with its own device dependent profile, then print to printer
with its profile and paper settings.
Working space= device independent space. Devices=device dependent space.
Lundberg, I would be happy to answer your question but I'm sorry to say I don't understand it. Surely you can't just be asking about the mechanics of associating a particular profile with a monitor - it sounds as if you've figured that out, and it would be different on a Windows system than on a Mac anyway. Perhaps, since the general goal here is to help rcheek6 out, would you be willing to start a new thread to ask the question in a clearer way?
-Noel
All he needs to do is to stay with the profile Color Munki provides, and not change anything in that part. Once he has his basic problem solved ( poor match from the print to the monitor) then he might want to play.
I still think he is double profiling. But I would need to look at his profile, starting with the monitor and following through his process. That large of an error should be easy to spot. The road there can be daunting, however.
Thanks again for all of the energy in trying to help me - it is very much appreciated. I'm at work now, but will check back on these issues this evening. I do have a monitor specific profile, but I'm not sure where it is registered - at least not from memory. I can find that out this evening. Most of my output is in two places - Smugmug and my own Epson Printer. I don't use other printers, unless I want something wider than 13 inches,l which I don't. If I understand you all correctly, I would be best served by adopting the Adobe RGB working space as opposed to the ProPhoto?
This evening, I can map out all of my settings. It would help me if I could find a reference as to where I will find all of th relevant settings. Part of my problem is, this process has so many component parts and overlapping menus in different places that I can't be sure I've found everything to deconflict.
You haven't really said what you do with your images most, nor how you prefer to work, so it's difficult to answer that.
Do you often / usually work with 16 bits/channel documents, and prepare images for print on wide-gamut devices? If so, then it's possible that ProPhoto RGB (which has a very wide gamut) could serve you well.
But if you publish to the web, where it makes a lot of sense to publish with the sRGB profile, if you make ProPhoto RGB your preferred working space, you'll always have to remember to either do File - Save for Web & Devices and choose the options to convert to sRGB, or do Edit - Convert to Profile, sRGB before File - Save As - JPEG.
If this extra color space conversion step gets forgotten, non-color-managed browsers will display your image with muted, anemic color. You could argue this is not THAT big a deal today because most modern browsers DO read the document profile, and that's a good thing. But keep in mind that an 8 bits/channel image (such as a JPEG) might show more posterization if published in other than sRGB, so it might appear to be of slightly lower quality than the same image published with the sRGB profile.
For the reason of making things more convenient (i.e., avoiding the need to convert to sRGB) some web designers choose to make sRGB their working space.
Think of Adobe RGB 1998 as a compromise between the two extremes. It can be a good one.
-Noel
i will add: choose the Photoshop working space that you understand...a lot of pros work exclusively in sRGB and it is the safest color space for any number of reasons
though, i mostly work in 16-bit ProPhotoRGB and AdobeRGB because I like a big space for editing color (and can't remember the last time i forget to Convert to 8-bit sRGB for the Web)
Photoshop is super easy to configure, here is a one-click setup (Edit> Color Settings) "North American Prepress 2"
what it does is PRESERVE Embedded Profiles, and notify you of any profile mismatches so it is harder to make opening profiling mistakes
if you want different Working Spaces, just select them here
that takes care of the Source Profile-to-Monitor Profile side of Photoshop
ON THE PRINT SIDE (Source Profile-to-Print Profile)
on the Epson, I use and recommend "Photoshop Manages Colors" & "Color Mode: Off (No Color Management)" work flow outlined here:
gballard.net/photoshop/epson/cs5/
i don't use Lightroom, but if you test with ProPhotoRGB (or WhackedRGB) reference images it should be easy to spot any broken areas of your workflow
not a Windows user, but I believe this is how to configure Windows to work with Photoshop
North America
Asia Pacific
