Help needed..
I have a sample of coding here, can anyone tell me how do i set the limit of sprite being dragged? I have set the following script to 28 sprites, but now the problem is, how should i freeze the rest of the 26 sprites and stop it from being draggable after dragging 2 sprites into the specified target location?
property spriteNum
property spriteLoc
on mouseDown me
set backingSprites = [:]
sendAllSprites (#IdentifyBackingSprites, backingSprites)
set dragSpriteNum = getaProp (backingSprites, #pickAndDrag)
set orderSpriteNum = getaProp (backingSprites, #changeOrder)
set dropSpriteNum = getaProp (backingSprites, #drop)
if rollover (dragSpriteNum) then
-- Allow this sprite to be dragged anywhere on stage
set spriteLoc = the loc of sprite spriteNum
set delta = spriteLoc - [the mouseH, the mouseV]
repeat while the mouseDown
set the loc of sprite spriteNum = point (the mouseH, the mouseV) + delta
updateStage
end repeat
-- The mouse has been released: where should this sprite go?
if rollover (dropSpriteNum) then
-- Drop sprite (and adjust its position)
set the locV of sprite spriteNum to the bottom of sprite dropSpriteNum
else
-- Return sprite to its original position
set the loc of sprite spriteNum = spriteLoc
end if
end mouseDown
No offense intended, but I am not very fond of that bit code "repeat while the mouseDown...updateStage...". While it may be working for you there are some good reasons not to use that. It also appears that you have not included all of the code in your post to make that work, so it isn't possible to give you specific suggestions on how to modify it. Instead I would like to offer you a different approach. A few assumptions made here (which of course can be changed).
1) The target is actually another sprite (such as a box) and not a screen location
2) Once a sprite is dropped into the target, it can not be moved again.
3) Sprites "snap" to the center of the taget (aligning themselves in a horizontal line).
4) Sprites dropped anywhere other than the target snap back to their original location.
5) Once the maximum number of sprites are dragged into the target, no other sprites can be moved.
Here are two behaviors, one if for the target sprite, and the other is for all drag sprites. The default is to allow no more than two sprites to be dropped on the target, but that can be easily changed through the behaviors parameters window. Also with this code, there is no specific requirement for the target or sprites to appear in a particular order on the score. You might want to create a simple demo movie and try this out.
If you have any questions or problems just reply back. HTH
-- Behavior for all draggable sprites
property spriteNum, pMe, pStartingLoc, pTargetSpriteNum
on beginSprite me
puppetSprite spriteNum, true
pMe = sprite(spriteNum)
pMe.moveableSprite = true
pMe.cursor = 280
pMe.pStartingLoc = pMe.loc
sendAllSprites(#updateDraggableSpriteList, spriteNum)
end
on reportToTarget me, targetSpriteNum
sendSprite(targetSpriteNum, #updateDraggableSpriteList, spriteNum)
end
on setTargetSpriteNum me, targetSpriteNum
pTargetSpriteNum = targetSpriteNum
end
on mouseDown me
if pMe.moveableSprite then pMe.locZ = the lastChannel + 1
end
on mouseUp me
pMe.locZ = spriteNum
sendSprite(pTargetSpriteNum, #spriteDropped, spriteNum)
end if
end
on setMovable me, moveableState
pMe.moveableSprite = moveableState
pMe.cursor = 280
else
pMe.cursor = 0
end if
end
on goBack me
pMe.loc = pStartingLoc
end
-- Behavior for the target sprite
property spriteNum, pMe, pDraggableSpriteList, pDroppedSprites, pMaxDroppedSprites, pCombinedWidth
on beginSprite me
pDraggableSpriteList = []
pDroppedSprites = []
pCombinedWidth = 0
sendAllSprites(#reportToTarget, spriteNum)
end
on updateDraggableSpriteList me, draggableSpriteNum
if not pDraggableSpriteList.findPos(draggableSpriteNum) then
pDraggableSpriteList.add(draggableSpriteNum)
sendSprite(draggableSpriteNum, #setTargetSpriteNum, spriteNum)
end if
end
on spriteDropped me, spriteNumDropped
if sprite(spriteNumDropped).intersects(pMe) then
pDroppedSprites.add(spriteNumDropped)
pCombinedWidth = pCombinedWidth + sprite(spriteNumDropped).width
sendSprite(spriteNumDropped, #setMovable, false)
sprite(spriteNumDropped).locZ = pMe.locZ + 1
newLocH = ((pMe.width - pCombinedWidth) * .5) + pMe.left + (sprite(spriteNumDropped).width * .5)
repeat with droppedSprite in pDroppedSprites
sprite(droppedSprite).locH = newLocH
newLocH = newLocH + sprite(spriteNumDropped).width
sprite(droppedSprite).locV = pMe.locV
end repeat
if pDroppedSprites.count = pMaxDroppedSprites then
repeat with draggableSpriteNum in pDraggableSpriteList
sendSprite(draggableSpriteNum, #setMovable, false)
end repeat
end if
else
sendSprite(spriteNumDropped, #goBack)
end if
end
on getPropertyDescriptionList
description = [:]
addProp description,#pMaxDroppedSprites, [#default:2, #format:#integer, #comment:"Maximum number of sprites that can be dropped on the target"]
return description
end
Thx a lot for yr help...It is better than what i had set to the previous one with few thousand lines of if else on every individual items...It sounds crazy, but it is my first time encounter and I'm have not come accross lingo script :-( And sad to say i need it for my project, it is kinda rush for me as i need to complete it within 6 weeks.
Do you mind if i post you another question about text input? I'm trying to have a simple BMR calculator in my director, and i have no idea how am I suppose to get the value from the text input sprite in order to perform the calculation and generate the result to appear in the intended text message box? Please refer to http://www.womenandweight.com/weight-management/weight-loss/how-many-c alories-per-day/ for the calculation formula.
Full example of similar version of BMR calculator that i wish to create is like http://www.hscripts.com/scripts/JavaScript/calorie-calculator.php
North America
Asia Pacific
