Defects when burning CS4 MPEG-2 to Blu-Ray
Feb 27, 2012 7:47 AM
I made a 1440 x 1080 video which contains some effects such as:   one single frame repeated many times to give a still,  a short sequence (about 10 frames) repeated in reverse, then forward, then reverse, etc to give a movement going to and fro.  This plays fine in the Pro timeline, and also in an MPEG-2 exported file, but when I burn it to Blu-Ray in MPEG-2, and play the disc, these effects play in a very inferior fashion, ( the "still" is very low definition, the movement is very jerky) though the rest of the video plays OK.   What is going on?  The Blu-Ray player is SAMSUNG BD-D5500 and is specified as being able to play MPEG-2.
    Feb 27, 2012 8:41 AM   in reply to Tim Flippance
    Copy the m2ts from the stream of the BD and see how it plays on the pc?
    Feb 27, 2012 1:02 PM   in reply to Tim Flippance
    Change the single frame to a still and make that into 10 frames.
    When reversing a clip set it to Always deinterlace in the Field Options
    Try that and see how that looks.
    Feb 28, 2012 3:18 AM   in reply to Tim Flippance
    The disk might not be fully compatible with the player, or the player with the disk. Depends on how you look at it.
    Feb 28, 2012 10:43 AM   in reply to Tim Flippance
    We had these same problems when DVD was just on the market.
    We changed brand or lowered the bitrate or lowered the burning speed.
    If that did not help the player went out the door and bought another brand. Lots of trial and error.
    I have an el cheapo BD player and use Verbatim disks and even the BD-RE's play fine.
