.swf converting to .ipa for ipad using adt
Feb 27, 2012 11:32 PM
Tags: #adt
Hi Respected,
My goal is converting .swf file for mobile version .ipa. (I have .swf file with me which is some third person developed).
For this i got info from adobe is , adt jar will help to do it. So for trying that utility i created simple desktop application using adobe flash builder 4.5 .Its simle app i have taken out .swf file and .xml file from it and i have provisional files and .p12 file also.
I have following run.bat to use adt:
set JAVA="C:\Program Files\Java\jre6\bin\java"
set ADT="C:\Program Files\Adobe\Adobe Flash Builder 4.5\sdks\4.5.1\lib\adt.jar"
set TARGET=ipa-test
set PROV_FILE="C:\Documents and Settings\swapnil.wadaganve\Desktop\certificate\cert\Distribution_prof ile_mACT_23OCT.mobileprovision"
set CERT_FILE="C:\Documents and Settings\swapnil.wadaganve\Desktop\certificate\cert\Certificates_mACT .p12"
set PASSWORD=rahul
set OUTPUT_IPA=TestSWF.ipa
set APP_DESC_FILE=TestSWF-app.xml
set SCR_FILES="C:\Documents and Settings\swapnil.wadaganve\Desktop\swf-ipa\TestSWF.swf"
%JAVA% -jar %ADT% -package -target ipa-test -provisioning-profile %PROV_FILE% -storetype pkcs12 -keystore %CERT_FILE%-storepass %PASSWORD% %OUTPUT_IPA% %APP_DESC_FILE% %SRC_FILES%
But it is not converting .ipa file it is saying TestSWF-app.xml is not valid airi or air file.
My .xml file is simple as ,
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<application xmlns="http://ns.adobe.com/air/application/2.6">
          <id>com.hcl.mact</id>
          <filename>TestSWF</filename>
          <name>TestSWF</name>
          <versionNumber>0.0.0</versionNumber>
          <initialWindow>
                    <content>[This value will be overwritten by Flash Builder in the output app.xml]</content>
                    <autoOrients>false</autoOrients>
        <fullScreen>false</fullScreen>
        <visible>false</visible>
    </initialWindow>
</application>
MAdhu
