Feb 28, 2012 12:34 AM
Changing Capture Time on Multiple Images
Like (0)
The problem I have is that my cameras internal clock drifted out and I need to adjust the capture time of a number of images by an odd amount i.e not an integer number of hours.
Can anyone suggest how this can be done? That is alter the capture time on multiple images by an amount such as -1h 25m 35s and they are RAW image files.
Thxs
Colin
Colin,
In Library, Grid View, filter on the images neeeding adjustment (i.e. by using a Metadata Filter) and select all images needing adjustments. Make sure the image you know what time stamp it should carry is selected as the most selected image.
Then choose Metadata -> Edit Capture Time, "Adjust to a specified date and time" and enter the time the most selected image should carry. The most selected image will be adjusted to what you enter, and all other selected images will be adjusted by the same amount as the most selected image.
Beat
Beat.....
Many thanks for the reply.
I did another search shortly after posting this and found your answer in another thread.
Once again, thanks
Colin
North America
Asia Pacific
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
