ivanvidev
Problem with flashPhone and FMG
Feb 29, 2012 1:26 AM
Hello All,
I have virtual Centos 5.7 with FMS developer and FMG installed.
SElinux is disabled, firewall is down, registry is endabled in Server.xml.
But FMG core.00.log says :
2012-02-29::11:17:33.709    INFO1073742997 RTMP 22662   Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
2012-02-29::11:17:33.710    INFO1073742997 RTMP 22662   Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
2012-02-29::11:17:33.713    DEBUG   1073742997 RTMP 22662   Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
I tried flashPhone with url : rtmp://server-ip/telephony and it says NetConnection.Connect.Success.
But I am always to this screen.
I only can see phone with botton while page is reloading and then again redirected to login screen.
Can some help with this issue.
Regards,
Ivan
    Feb 29, 2012 1:53 AM   in reply to ivanvidev
    The logs indicate that registry core is not really up.
        1) Trivial step, was FMS restarted ?
        2) Process manager on linux should show one FMSCore process after FMS start start even when no application is loaded.
        3) Default conf of FMS 4.5 "already" contains a registry tag at near bottom of file. It should be enabled inplace; which is slightly different that earlier when <registry> tag was needed to be added.
    Feb 29, 2012 2:08 AM   in reply to ivanvidev
    Error is likely to be in FMS:
    Right after restart, do you see one preloaded  fmscore process ?
    Is there an error msg in FMS log files?
