• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Encore CS5.1, Issue burning onto 8.5GB DL DVD using WIndows 7, 64bit
Community Beginner ,
Feb 29, 2012 Feb 29, 2012
Is anyone familiar with the inability of Encore CS5.1 to burn 8.5GB dual layer disc using Windows 7, 64bit.  After many failed attempts, it turns out that you need to set Encore as Windows XP compatability in order to get the disc to burn.  Is this just a glitch with Windows 7 + Adobe Encore CS5.1?
The problem with changes the compatability on Encore is that you lose the dynamic link with Premiere Pro CS5.5.
Any other suggestions on being able to burn without changing the compatability of Encore?
btw, 4.7GB DVDs work fine.
Gianni (JohnQ)
Views
56.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Mar 01, 2012 Mar 01, 2012
Right click the Encore icon on your desktop
Select Properties
Shortcut tab
Select Advanced
Click the Run as Admin option
Click OK
Click OK
Votes
Translate
Translate
Community Expert ,
To burn dual layer you MUST right click the Encore icon and select Run as Administrator from the popup window... this is NOT the same as using an Administrator account
I think you can select to "always" Run as Administrator from that popup window
Votes
Translate
Translate
Report
Report
Guest
John is right. The dual layer DVD burning requires to Run the Encore as Admin even when you are logged in as admin.
-Ramesh.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 29, 2017 Nov 29, 2017
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Are you looking for this thread?
Adobe Encore - will not burn dual layer DVD
Votes
Translate
Translate
Report
Report
Community Expert ,
Select Properties
Shortcut tab
Select Advanced
Click OK
Click OK
Votes
Translate
Translate
Report
Report
Mar 02, 2012 Mar 02, 2012
Thanks guys, it worked!!!  Thank you!!
Votes
Translate
Translate
Report
Report
New Here ,
Apr 17, 2012 Apr 17, 2012
Thank you!!  I had the same issues.
Votes
Translate
Translate
Report
Report
Participant ,
Oct 22, 2015 Oct 22, 2015
Excuse me ..but what is the encore icon ... where do I find it ?   I am not good at this ... especially not in english !
Votes
Translate
Translate
Report
Report
New Here ,
Oct 29, 2014 Oct 29, 2014
Sir, I had this problem with a nearly 3 hour wedding I was building for a DVD+R DL and this info was
a life saver! Thank you!!
Votes
Translate
Translate
Report
Report
New Here ,
Sep 14, 2015 Sep 14, 2015
It worked. Thank you very much.
Votes
Translate
Translate
Report
Report
New Here ,
Votes
Translate
Translate
Report
Report
Guest
Jul 31, 2016 Jul 31, 2016
correct
Votes
Translate
Translate
Report
Report
New Here ,
Jan 24, 2017 Jan 24, 2017
I don't have an Encore icon, just the new ASdobe
Votes
Translate
Translate
Report
Report
Community Expert ,
Open it from the program folder location; then add a shortcut to your desktop. Is that what you are asking? What OS?
Votes
Translate
Translate
Report
Report
