GoosePoop
SWFLoader @Embed isse
Apr 9, 2008 10:46 AM
Hi.
I have some code that uses an extended SWFLoader to load flash swf content.
I have some methods that are called on init and complete to make assignments.
I can then call methods in the loaded content via MovieClip(this.content).myMehtod(); etc..
However.. when I move to embed the source, I can no longer get init or complete events to get called and when I access the content it says the methods are not accessable.
Does the @Embed add an additional layer in there or something?
Works with this:
Quote:
<ns1:IMAPSSWFLoader x="35" y="454" width="112" height="31" id="test" source="mc/test.swf" scaleContent="false"/>
Breaks when I embed:
Quote:
<ns1:IMAPSSWFLoader x="35" y="454" width="112" height="31" id="test" source="@Embed('mc/test.swf')" scaleContent="false"/>
Accessor:
Quote:
* loadedMC contains an instance of the loaded MovieClip
* @param value:MovieClip
* @return MovieClip;
public function get loadedMC():MovieClip
{ if (_loadedMC == null)
_loadedMC = MovieClip(this.content);
return _loadedMC;
I have searched and found nothing on google on this.
Any pointers in the right direction would be helpful.
    Apr 10, 2008 7:52 AM   in reply to GoosePoop
    I've had similar issue with embedded swf. When I dynamically loaded the swf with swfloader, it worked fine, i could access the movieclip content, however, when the swf was embedded, i cannot access the methods or properties of the swf. This is infact stated in the help document.
    As a solution, I resorted to making the swf into a SWC as a custom component using the Flex Component Kit for Flash CS3. Everything works fine now.
    Hope it helps.
    Nov 20, 2012 8:50 AM   in reply to GoosePoop
        <mx:SWFLoader id="swfObj"
                  width="100%" height="100%"
                  complete="swfObj_completeHandler(event)"/>
        <fx:Script>
                  <![CDATA[
                            [Bindable]
                            [Embed(source="assets/soundbar.swf")]
                            private static var swfClass:Class;
                            private var swfSoundBar : MovieClip;
                            [Bindable] private var mp3Player:MP3Player = MP3Player.getInstance();
                            protected function init(event:FlexEvent):void
                                      swfSoundBar = new swfClass();
                                      var byteArray:ByteArray = swfSoundBar.movieClipData;
                                      var loaderContext: LoaderContext = new LoaderContext();
                                      loaderContext.allowLoadBytesCodeExecution = true;
                                      swfObj.loaderContext = loaderContext;
                                      swfObj.source = byteArray;
                            protected function swfObj_completeHandler(event:Event):void
                                      swfSoundBar = SWFLoader(event.target).content as MovieClip;
                                      swfSoundBar.width = 32;
                                      swfSoundBar.height = 14;
                                      swfSoundBarShowHide();
                            protected function swfSoundBarShowHide():void
                                      if (swfSoundBar){
                                                if (mp3Player.isPlaying){
                                                          swfSoundBar.gotoAndStop(0);
                                                          swfSoundBar.stop();
                                                } else {
                                                          swfSoundBar.gotoAndPlay(0);
        </fx:Script>
