Can not resolve a multiname reference unambiguously- OSMF build from scratch
Mar 2, 2012 4:16 AM
Tags: none (add) #osmfHi
I am trying to build OSMF from scratch and I have been following the Building OSMF and OSMF based projects guide - http://osmf.org/dev/osmf/specpdfs/building-osmf.pdf
I've been doing everything by the guide but when I try to compile the project, which is the unmodified trunk from SVN, I get the following error (see below). I did a fair bit of googling but to no avail. Please Help me out!
This is my entire log on compilation-
E:\OSMF\OSMF SVN\trunk>ant
Buildfile: E:\OSMF\OSMF SVN\trunk\build.xml
all:
build:
compile.osmf:
clean-bin:
build:
[delete] Deleting: E:\OSMF\OSMF SVN\trunk\framework\OSMF\OSMF-build-config.tm
p.xml
[copy] Copying 1 file to E:\OSMF\OSMF SVN\trunk\framework\OSMF
[compc] Loading configuration file E:\OSMF\OSMF SVN\trunk\framework\OSMF\OSM
F-build-config.tmp.xml
[compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\M
anifestParser.as: Error: Can not resolve a multiname reference unambiguously. or
g.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\buildtools
\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base 64Decoder)
) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\o
rg\osmf\utils\Base64Decoder.as) are available.
[compc]
[compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\B
ootstrapInfoParser.as: Error: Can not resolve a multiname reference unambiguousl
y. org.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\build
tools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses :Base64Dec
oder)) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\O
SMF\org\osmf\utils\Base64Decoder.as) are available.
[compc]
ediaParser.as: Error: Can not resolve a multiname reference unambiguously. org.o
smf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\buildtools\sd
ks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:Base64D ecoder)) a
nd org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\
[compc]
[compc] E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\elements\f4mClasses\D
RMAdditionalHeaderParser.as: Error: Can not resolve a multiname reference unambi
guously. org.osmf.elements.f4mClasses:Base64Decoder (from E:\OSMF\OSMF SVN\trunk
\buildtools\sdks\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mC lasses:Bas
e64Decoder)) and org.osmf.utils:Base64Decoder (from E:\OSMF\OSMF SVN\trunk\frame
work\OSMF\org\osmf\utils\Base64Decoder.as) are available.
[compc]
[compc]
g.osmf.elements.f4mClasses:DateUtil (from E:\OSMF\OSMF SVN\trunk\buildtools\sdks
\4.5.1\frameworks\libs\osmf.swc(org.osmf.elements.f4mClasses:DateUtil) ) and org.
osmf.utils:DateUtil (from E:\OSMF\OSMF SVN\trunk\framework\OSMF\org\osmf\utils\D
ateUtil.as) are available.
[compc]
[compc]
[compc]
[compc]
anifestParser.as(137): col: 26 Error: Access of undefined property DateUtil.
[compc]
[compc] manifest.startTime = DateUtil.parseW3CDT
F(root.nmsp::startTime.text());
[compc] ^
[compc]
anifestParser.as(680): col: 18 Error: Type was not found or was not a compile-ti
me constant: Base64Decoder.
[compc]
[compc] var decoder:Base64Decoder = new
Base64Decoder();
[compc] ^
[compc]
anifestParser.as(680): col: 38 Error: Call to a possibly undefined method Base64
Decoder.
[compc]
Base64Decoder();
[compc]
[compc]
ootstrapInfoParser.as(92): col: 17 Error: Type was not found or was not a compil
e-time constant: Base64Decoder.
[compc]
[compc] var decoder:Base64Decoder = new Base64De
coder();
[compc] ^
[compc]
ootstrapInfoParser.as(92): col: 37 Error: Call to a possibly undefined method Ba
se64Decoder.
[compc]
coder();
[compc] ^
[compc]
ediaParser.as(67): col: 16 Error: Type was not found or was not a compile-time c
[compc]
[compc] var decoder:Base64Decoder;
[compc] ^
[compc]
ediaParser.as(147): col: 19 Error: Call to a possibly undefined method Base64Dec
oder.
[compc]
[compc] decoder = new Base64Decoder();
[compc] ^
[compc]
ediaParser.as(154): col: 19 Error: Call to a possibly undefined method Base64Dec
oder.
[compc]
[compc] ^
[compc]
ediaParser.as(187): col: 19 Error: Call to a possibly undefined method Base64Dec
oder.
[compc]
[compc] ^
[compc]
RMAdditionalHeaderParser.as(91): col: 17 Error: Type was not found or was not a
compile-time constant: Base64Decoder.
[compc]
coder();
[compc] ^
[compc]
RMAdditionalHeaderParser.as(91): col: 37 Error: Call to a possibly undefined met
hod Base64Decoder.
[compc]
coder();
[compc] ^
[compc]
BUILD FAILED
E:\OSMF\OSMF SVN\trunk\build.xml:15: The following error occurred while executin
g this line:
E:\OSMF\OSMF SVN\trunk\build.xml:22: The following error occurred while executin
g this line:
E:\OSMF\OSMF SVN\trunk\build.xml:53: The following error occurred while executin
g this line:
E:\OSMF\OSMF SVN\trunk\framework\OSMF\build.xml:14: The following error occurred
while executing this line:
E:\OSMF\OSMF SVN\trunk\buildtools\utils.xml:107: compc task failed
Total time: 56 seconds
