Right now I'm trying to find out by examining all methods and comparing to other engines like box2D how to get information about colliding objects.
I thought I could use i.E. the "checkCollideWith" method of the btRigidBody instance, but it always returns true.
Then, there are several interesting methods in the collisionDispatcher class, but also they don't yield any satisfying results.
I could set a "nearCallbackFunction", but then, the collision wasn't handeled internally anymore.
Has anyone found out how to get reliable information about colliding objects?
Also the Pellet-Engine looks really "ported from C++", not like a typical AS3 project. I could imagine that Adobe would refactor the whole thing at a given time to make it fit more into their AS3 environment. Then, there would also be "real" events for things like that.
Well I answered it myself. I should have noticed that "Pellet" sounds familiar. Like the physics engine used in Blender3D, "Bullet".
And when I looked at the wiki, I found out that Pellet was a clone of Bullet so I could easily port these lines of code to AS3:
// inside onAnimate method of BasicScene
var numManifolds:int = _dynamicsWorld.getDispatcher().getNumManifolds();
for (i = 0; i < numManifolds; i++) {
var contactManifold:btPersistentManifold = _dynamicsWorld.getDispatcher().getManifoldByIndexInternal(i);
var obA:btCollisionObject = contactManifold.getBody0();
var obB:btCollisionObject = contactManifold.getBody1();
var numContacts:int = contactManifold.getNumContacts();
var j:int;
for (j = 0; j < numContacts; j++) {
var pt:btManifoldPoint = contactManifold.getContactPoint(j);
if (pt.getDistance() < 0) {
// const btVector3& ptA = pt.getPositionWorldOnA();
// const btVector3& ptB = pt.getPositionWorldOnB();
// const btVector3& normalOnB = pt.m_normalWorldOnB;
trace ("yay, dingdingding! => " + obA + ", " + obB+ " collided!");
I just used the code described here:
http://www.bulletphysics.org/mediawiki-1.5.8/index.php/Collision_Callb acks_and_Triggers
You can get the full documentation here:
http://www.bulletphysics.org/mediawiki-1.5.8/index.php?title=Documenta tion
Probably everything will also work in Pellet this way, you've just port the code to AS3, no need to even change variable or method names, it seems to be all the same in Pellet. ![]()
North America
Asia Pacific
