DirtySnipe007
Need help with linking buttons
Mar 5, 2012 2:14 AM
Tags: #problem #button #xml #actionscript3
Can anyone help me with this problem I have.
I have a gfx which I have created 6 shapes and converted them into simple buttons. I have urls sat inside an xml file. How can I get the buttons to use the urls set from within the xml file?
Also how can I change the current external photo that is being loaded to load the url from a setting in the same xml file.
I hope you arnt as confused as I am right now.
I have packaged up the flash file which includeds the xml aswell.
If anyone could help me out with this I would be very greatful.
Thanks All
http://www.onlineaddicts.co.uk/menu.rar
    Mar 5, 2012 3:35 AM   in reply to DirtySnipe007
    Remove the code from all btns, as below paste it on main timeline
    Also no need to load xml twice as dome in image container...
    give an instance name to the outer container of btns - menumv
    use following method to openURL, use same for all the btns..
    import flash.events.Event;
    import flash.events.MouseEvent;
    import flash.net.URLLoader;
    import flash.net.URLRequest;
    var myXML:XML;
    var myLoader:URLLoader = new URLLoader();
    myLoader.load(new URLRequest("links.xml"));
    myLoader.addEventListener(Event.COMPLETE, processXML);
    function processXML(e:Event):void
    myXML = new XML(e.target.data);
    trace(myXML);
    menumv.carbtn.addEventListener(MouseEvent.CLICK, openURL);
    function openURL(e:MouseEvent):void
    navigateToURL(new URLRequest(myXML.car.url));
    http://www.darshanrane.com
    Mar 5, 2012 5:06 AM   in reply to DirtySnipe007
    You need to update the files, you are linking your local links...
    http://www.onlineaddicts.co.uk/test/links.xml
    Also you need to replicate this line for all your btn
    And this function as well
    Not an optimized solution as you need to right 5 functions, but should work.
    Mar 6, 2012 12:44 AM   in reply to DirtySnipe007
    Dont know whether apache will block the page request, it should not. Check out if there is some explict settings...
    Just as a QC, try a simple one btn click opens a html file in a separate file and test whether your setup works on apache...
