I have developed a Hello World Application using AIR Native Extension on Android Emulator and When i try to run the application its crashes. I was able to run same application sometimes back on Android Emulator on Mac. Right now I am using a Windows machine (as i dont have Mac anymore). I tried running same apk file which was compiled and running on Android emulator on Mac but it failed. Also i tried to recompile entire application from same code base but still it is failing. As far as i know Mac or windows should not play a part but still mentioning it out in the discussion. Also i tried running the application on various Android SDK version but with same results.
Following is logcat logs for Android 4.0.3.
D/gralloc_goldfish( 497): Emulator without GPU emulation detected.
I/ActivityManager( 84): Displayed air.com.deloitte.helloWorld/.AppEntry: +4s82
6ms
W/InputManagerService( 84): Starting input on non-focused client com.android.i
nternal.view.IInputMethodClient$Stub$Proxy@413e17e0 (uid=10009 pid=179)
W/ActivityManager( 84): Launch timeout has expired, giving up wake lock!
W/ActivityManager( 84): Activity idle timeout for ActivityRecord{41534258 air.
com.deloitte.helloWorld/.AppEntry}
W/NetworkManagementSocketTagger( 84): setKernelCountSet(10009, 0) failed with
errno -2
E/dalvikvm( 497): JNI ERROR (app bug): attempt to use stale local reference 0x5
d500031
W/dalvikvm( 497): JNI WARNING: 0x5d500031 is not a valid JNI reference
W/dalvikvm( 497): in Lcom/adobe/air/customHandler;.nativeOnTouchCa
llback:(IFFFIFFZ[FI)Z (CallObjectMethodV)
I/dalvikvm( 497): "main" prio=5 tid=1 RUNNABLE
I/dalvikvm( 497): | group="main" sCount=0 dsCount=0 obj=0x409c1460 self=0x128
10
I/dalvikvm( 497): | sysTid=497 nice=0 sched=0/0 cgrp=default handle=107408295
2
I/dalvikvm( 497): | schedstat=( 12139801627 5119955457 1265 ) utm=1128 stm=85
core=0
I/dalvikvm( 497): at com.adobe.air.customHandler.nativeOnTouchCallback(Native
Method)
Method)
I/dalvikvm( 497): at com.adobe.air.customHandler.handleMessage(customHandler.
java:23)
I/dalvikvm( 497): at android.os.Handler.dispatchMessage(Handler.java:99)
I/dalvikvm( 497): at android.os.Looper.loop(Looper.java:137)
I/dalvikvm( 497): at android.app.ActivityThread.main(ActivityThread.java:4424
I/dalvikvm( 497): at java.lang.reflect.Method.invokeNative(Native Method)
I/dalvikvm( 497): at java.lang.reflect.Method.invoke(Method.java:511)
I/dalvikvm( 497): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.r
un(ZygoteInit.java:784)
I/dalvikvm( 497): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:
551)
I/dalvikvm( 497): at dalvik.system.NativeStart.main(Native Method)
I/dalvikvm( 497):
E/dalvikvm( 497): VM aborting
F/libc ( 497): Fatal signal 11 (SIGSEGV) at 0xdeadd00d (code=1)
I/DEBUG ( 34): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *
I/DEBUG ( 34): Build fingerprint: 'generic/sdk/generic:4.0.3/MR1/237985:eng/
test-keys'
I/DEBUG ( 34): pid: 497, tid: 497 >>> air.com.deloitte.helloWorld <<<
I/DEBUG ( 34): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr deadd00
d
I/DEBUG ( 34): r0 00000000 r1 00097bd8 r2 00000000 r3 00000000
I/DEBUG ( 34): r4 deadd00d r5 40872c58 r6 0000020c r7 49622e39
I/DEBUG ( 34): r8 4084ee67 r9 4084e703 10 4084ee73 fp 4084f546
I/DEBUG ( 34): ip 00000000 sp bed6a248 lr 4080bc8f pc 4080bc8e cpsr 600
00030
I/DEBUG ( 34): d0 3f8000003f800000 d1 4b00106845834000
I/DEBUG ( 34): d2 4b0010684b000000 d3 0000000045834000
I/DEBUG ( 34): d4 0000000000000000 d5 0000000000000000
I/DEBUG ( 34): d6 0000000000000000 d7 0000106800000000
I/DEBUG ( 34): d8 3f8000003f800000 d9 0000000000100000
I/DEBUG ( 34): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 34): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 34): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 34): scr 68000012
I/DEBUG ( 34):
I/DEBUG ( 34): #00 pc 00050c8e /system/lib/libdvm.so (dvmAbort)
I/DEBUG ( 34): #01 pc 0004486e /system/lib/libdvm.so
I/DEBUG ( 34): #02 pc 000451b0 /system/lib/libdvm.so
I/DEBUG ( 34): #03 pc 0004c9a0 /system/lib/libdvm.so
I/DEBUG ( 34): #04 pc 000e0e4a /data/data/com.adobe.air/lib/libCo
re.so
I/DEBUG ( 34):
I/DEBUG ( 34): code around pc:
I/DEBUG ( 34): 4080bc6c 34b4f8d3 ec54f7cd 26001e73 2f01f813 ...4..T.s..&...
I/DEBUG ( 34): 4080bc7c 42abb152 d0074416 4798e7f8 f7ff4c0a R..B.D.....G.L.
I/DEBUG ( 34): 4080bc8c 7026ffa7 ec4af7cd 2006490c 44794a0c ..&p..J..I. .Jy
D
I/DEBUG ( 34): 4080bc9c f7cd447a 2000eb00 ebc2f7cd 58e54b05 zD..... .....K.
X
I/DEBUG ( 34): 4080bcac 2b006c6b e7e9d1e9 deadd00d 0006234c kl.+........L#.
I/DEBUG ( 34):
I/DEBUG ( 34): code around lr:
D
X
I/DEBUG ( 34):
I/DEBUG ( 34): memory map around addr deadd00d:
I/DEBUG ( 34): bed23000-bed71000 [stack]
I/DEBUG ( 34): (no map for address)
I/DEBUG ( 34): (no map above)
I/DEBUG ( 34):
I/DEBUG ( 34): stack:
I/DEBUG ( 34): bed6a208 00000000
I/DEBUG ( 34): bed6a20c 4001df19 /system/lib/libc.so
I/DEBUG ( 34): bed6a210 4004770c /system/lib/libc.so
I/DEBUG ( 34): bed6a214 4004c85c
I/DEBUG ( 34): bed6a218 00000000
I/DEBUG ( 34): bed6a21c 4001f121 /system/lib/libc.so
I/DEBUG ( 34): bed6a220 4004755c /system/lib/libc.so
I/DEBUG ( 34): bed6a224 00000000
I/DEBUG ( 34): bed6a228 0000020c
I/DEBUG ( 34): bed6a22c 49622e39 /data/data/com.adobe.air/lib/libCore.
so
I/DEBUG ( 34): bed6a230 4084ee67 /system/lib/libdvm.so
I/DEBUG ( 34): bed6a234 4001df37 /system/lib/libc.so
I/DEBUG ( 34): bed6a238 4086df90 /system/lib/libdvm.so
I/DEBUG ( 34): bed6a23c bed6a44b [stack]
I/DEBUG ( 34): bed6a240 df0027ad
I/DEBUG ( 34): bed6a244 00000000
I/DEBUG ( 34): #00 bed6a248 00000038
I/DEBUG ( 34): bed6a24c 6c756e28
I/DEBUG ( 34): bed6a250 0000296c
I/DEBUG ( 34): bed6a254 00000000
I/DEBUG ( 34): bed6a258 00000000
I/DEBUG ( 34): bed6a25c 00000000
I/DEBUG ( 34): bed6a260 00000000
I/DEBUG ( 34): bed6a264 00000000
I/DEBUG ( 34): bed6a268 00000000
I/DEBUG ( 34): bed6a26c 00000000
I/DEBUG ( 34): bed6a270 00000000
I/DEBUG ( 34): bed6a274 00000000
I/DEBUG ( 34): bed6a278 00000000
I/DEBUG ( 34): bed6a27c 00000000
I/DEBUG ( 34): bed6a280 00000000
I/DEBUG ( 34): bed6a284 00000000
I/DEBUG ( 34): bed6a288 00000000
I/DEBUG ( 34): bed6a28c 00000000
I/DEBUG ( 34): bed6a290 00000000
I/DEBUG ( 34): bed6a294 00000000
I/DEBUG ( 34): bed6a298 00000000
I/DEBUG ( 34): bed6a29c 00000000
I/DEBUG ( 34): bed6a2a0 00000000
I/DEBUG ( 34): bed6a2a4 00000000
I/DEBUG ( 34): bed6a2a8 00000000
I/DEBUG ( 34): bed6a2ac 00000000
I/DEBUG ( 34): bed6a2b0 00000000
I/DEBUG ( 34): bed6a2b4 00000000
I/DEBUG ( 34): bed6a2b8 00000000
I/DEBUG ( 34): bed6a2bc 00000000
I/DEBUG ( 34): bed6a2c0 00000000
I/DEBUG ( 34): bed6a2c4 00000000
I/DEBUG ( 34): bed6a2c8 00000000
I/DEBUG ( 34): bed6a2cc 00000000
I/DEBUG ( 34): bed6a2d0 00000000
I/DEBUG ( 34): bed6a2d4 00000000
I/DEBUG ( 34): bed6a2d8 00000000
I/DEBUG ( 34): bed6a2dc 00000000
I/DEBUG ( 34): bed6a2e0 00000000
I/DEBUG ( 34): bed6a2e4 00000000
I/DEBUG ( 34): bed6a2e8 00000000
I/DEBUG ( 34): bed6a2ec 00000000
I/DEBUG ( 34): bed6a2f0 00000000
I/DEBUG ( 34): bed6a2f4 00000000
I/DEBUG ( 34): bed6a2f8 00000000
I/DEBUG ( 34): bed6a2fc 00000000
I/DEBUG ( 34): bed6a300 00000000
I/DEBUG ( 34): bed6a304 00000000
I/DEBUG ( 34): bed6a308 00000000
I/DEBUG ( 34): bed6a30c 00000000
I/DEBUG ( 34): bed6a310 00000000
I/DEBUG ( 34): bed6a314 00000000
I/DEBUG ( 34): bed6a318 00000000
I/DEBUG ( 34): bed6a31c 00000000
I/DEBUG ( 34): bed6a320 00000000
I/DEBUG ( 34): bed6a324 00000000
I/DEBUG ( 34): bed6a328 00000000
I/DEBUG ( 34): bed6a32c 00000000
I/DEBUG ( 34): bed6a330 00000000
I/DEBUG ( 34): bed6a334 00000000
I/DEBUG ( 34): bed6a338 00000000
I/DEBUG ( 34): bed6a33c 00000000
I/DEBUG ( 34): bed6a340 00000000
I/DEBUG ( 34): bed6a344 00000000
I/DEBUG ( 34): bed6a348 00000000
I/DEBUG ( 34): bed6a34c 00000000
I/DEBUG ( 34): bed6a350 00000000
I/DEBUG ( 34): bed6a354 00000000
I/DEBUG ( 34): bed6a358 00000000
I/DEBUG ( 34): bed6a35c 00000000
I/DEBUG ( 34): bed6a360 00000000
I/DEBUG ( 34): bed6a364 00000000
I/DEBUG ( 34): bed6a368 00000000
I/DEBUG ( 34): bed6a36c 00000000
I/DEBUG ( 34): bed6a370 00000000
I/DEBUG ( 34): bed6a374 00000000
I/DEBUG ( 34): bed6a378 00000000
I/DEBUG ( 34): bed6a37c 00000000
I/DEBUG ( 34): bed6a380 00000000
I/DEBUG ( 34): bed6a384 00000000
I/DEBUG ( 34): bed6a388 00000000
I/DEBUG ( 34): bed6a38c 00000000
I/DEBUG ( 34): bed6a390 00000000
I/DEBUG ( 34): bed6a394 00000000
I/DEBUG ( 34): bed6a398 00000000
I/DEBUG ( 34): bed6a39c 00000000
I/DEBUG ( 34): bed6a3a0 00000000
I/DEBUG ( 34): bed6a3a4 00000000
I/DEBUG ( 34): bed6a3a8 00000000
I/DEBUG ( 34): bed6a3ac 00000000
I/DEBUG ( 34): bed6a3b0 00000000
I/DEBUG ( 34): bed6a3b4 00000000
I/DEBUG ( 34): bed6a3b8 00000000
I/DEBUG ( 34): bed6a3bc 00000000
I/DEBUG ( 34): bed6a3c0 00000000
I/DEBUG ( 34): bed6a3c4 00000000
I/DEBUG ( 34): bed6a3c8 00000000
I/DEBUG ( 34): bed6a3cc 00000000
I/DEBUG ( 34): bed6a3d0 00000000
I/DEBUG ( 34): bed6a3d4 00000000
I/DEBUG ( 34): bed6a3d8 00000000
I/DEBUG ( 34): bed6a3dc 00000000
I/DEBUG ( 34): bed6a3e0 00000000
I/DEBUG ( 34): bed6a3e4 00000000
I/DEBUG ( 34): bed6a3e8 00000000
I/DEBUG ( 34): bed6a3ec 00000000
I/DEBUG ( 34): bed6a3f0 00000000
I/DEBUG ( 34): bed6a3f4 00000000
I/DEBUG ( 34): bed6a3f8 00000000
I/DEBUG ( 34): bed6a3fc 00000000
I/DEBUG ( 34): bed6a400 00000000
I/DEBUG ( 34): bed6a404 00000000
I/DEBUG ( 34): bed6a408 00000000
I/DEBUG ( 34): bed6a40c 00000000
I/DEBUG ( 34): bed6a410 00000000
I/DEBUG ( 34): bed6a414 00000000
I/DEBUG ( 34): bed6a418 00000000
I/DEBUG ( 34): bed6a41c 00000000
I/DEBUG ( 34): bed6a420 00000000
I/DEBUG ( 34): bed6a424 00000000
I/DEBUG ( 34): bed6a428 00000000
I/DEBUG ( 34): bed6a42c 00000000
I/DEBUG ( 34): bed6a430 00000000
I/DEBUG ( 34): bed6a434 00000000
I/DEBUG ( 34): bed6a438 00000000
I/DEBUG ( 34): bed6a43c 00000000
I/DEBUG ( 34): bed6a440 00000000
I/DEBUG ( 34): bed6a444 00000000
I/DEBUG ( 34): bed6a448 00000000
I/DEBUG ( 34): bed6a44c 342b19f5
I/DEBUG ( 34): bed6a450 00000000
I/DEBUG ( 34): bed6a454 4086df90 /system/lib/libdvm.so
I/DEBUG ( 34): bed6a458 5d500031
I/DEBUG ( 34): bed6a45c 407ff873 /system/lib/libdvm.so
I/DEBUG ( 34): #01 bed6a460 bed6a54c [stack]
I/DEBUG ( 34): bed6a464 408001b5 /system/lib/libdvm.so
D/Zygote ( 37): Process 497 terminated by signal (11)
I/WindowManager( 84): WIN DEATH: Window{41462cb0 SurfaceView paused=false}
I/ActivityManager( 84): Process air.com.deloitte.helloWorld (pid 497) has died
W/ActivityManager( 84): Force removing ActivityRecord{41534258 air.com.deloitt
e.helloWorld/.AppEntry}: app died, no saved state
W/NetworkManagementSocketTagger( 84): setKernelCountSet(10041, 0) failed with
errno -2
I/WindowManager( 84): WIN DEATH: Window{41590db8 SurfaceView paused=false}
I/WindowManager( 84): WIN DEATH: Window{4158b920 air.com.deloitte.helloWorld/a
ir.com.deloitte.helloWorld.AppEntry paused=false}
I/BootReceiver( 84): Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_
TOMBSTONE)
E/InputDispatcher( 84): Received spurious receive callback for unknown input c
hannel. fd=209, events=0x8
D/dalvikvm( 84): GC_FOR_ALLOC freed 928K, 13% free 11284K/12871K, paused 84ms
W/NetworkManagementSocketTagger( 84): setKernelCountSet(10009, 1) failed with
errno -2
D/dalvikvm( 84): GC_CONCURRENT freed 141K, 10% free 11601K/12871K, paused 6ms+
14ms
D/dalvikvm( 84): GC_FOR_ALLOC freed 177K, 11% free 11552K/12871K, paused 128ms
D/dalvikvm( 84): GC_FOR_ALLOC freed 128K, 10% free 11616K/12871K, paused 84ms
D/dalvikvm( 84): GC_FOR_ALLOC freed 427K, 12% free 11445K/12871K, paused 79ms
W/InputManagerService( 84): Got RemoteException sending setActive(false) notif
ication to pid 497 uid 10041
D/dalvikvm( 136): GC_FOR_ALLOC freed 5544K, 37% free 9812K/15495K, paused 47ms
D/dalvikvm( 179): GC_FOR_ALLOC freed 2416K, 21% free 17911K/22535K, paused 77ms
D/dalvikvm( 179): GC_FOR_ALLOC freed 659K, 17% free 18828K/22535K, paused 100ms
D/dalvikvm( 179): GC_CONCURRENT freed 941K, 12% free 19900K/22535K, paused 6ms+
20ms
D/dalvikvm( 179): GC_CONCURRENT freed 3259K, 18% free 18684K/22535K, paused 12m
s+23ms
I am not able to solve this yet. Is anybody else facing this this problem.
Bump -- what is this "Fatal signal 11" exactly?
