This discussion is locked
Invoking Photoshop CS5 from Lightroom 4 asks for Camera Raw Plug-in 7.0
Mar 6, 2012 1:28 AM
Tags: #raw #camera #plug-in #lr4 #cs51
  Latest reply: Decio Yokota, Jun 6, 2012 6:28 AM
Replies 1 2 3 4 3 Previous Next
    Apr 13, 2012 11:51 AM   in reply to Lou Dina
    so in order for you to take advantage of the NEW LR Camera Raw the short answer is YES!!?
    Apr 13, 2012 12:35 PM   in reply to mikeobe
    mikeobe,
    Perhaps I am misunderstanding what you are saying, but I disagree with what I think you are saying. I can take advantage of ALL of LR4's functions, including RAW processing, even if I am using Photoshop CS4 or CS5. Rendering the RAW image using LightRoom 4 uses the very latest raw processing engine, which is built into LR. You don't NEED a current version of Photoshop CS6 or Camera RAW to do this—just Render Using LR and you ARE using the latest version of Camera RAW.
    For whatever reason, Adobe chose not to allow older versions of Photoshop use the latest Camera RAW module (probably to encourage more sales of Photoshop). That is specifically why I am using LR to render my images. I don't want to pay the extra money to upgrade PS.
    Apr 13, 2012 1:13 PM   in reply to mikeobe
    Well, it gets so complicated that let's make sure we agree the question!  Assuming the version of LR is 4 (or greater) and you want to "Edit in" Photoshop:
    1. If the installed version of Photoshop is CS5 with ACR 6.6 (or earlier), then choose "Render using Lightroom".  Choosing "Open anyway" will cause problems.
    2. If using CS5, but with ACR6.7, currently in Release Candidate, it will still ask the question, but Adobe say it's safe to choose "Open anyway", as I understand it.
    3. If using CS6, which will have ACR7, then it won't ask the question - it will assume it's compatible and take the "Open anyway" route without asking.
    If in case 1 or 2 it doesn't ask, it's probably because you've suppressed the question.  Go to (in Lightroom) Edit menu, Preferences.. General Tab and click "Reset all warning dialogs".
    If you choose "Open anyway" (or it does it automatically) then LR passes the raw file to PS, PS processes it behind the scenes in ACR, and if and when you save the file in PS - and only if and when - it creates a new image (e.g. TIF or PSD) which is stacked with the original in LR.
    If you choose "Render using Lightroom", then LR creates a TIF there and then, stacks it with the original, and passes the TIF to PS.  This is how it behaves always with any editor except PS.  The only disadvantage is if you edit in PS and decide not to save.  You will already have the TIF, and if you don't want it, you have to delete it in LR.
    Apr 13, 2012 1:50 PM   in reply to CSS Simon
    "then LR creates a TIF there and then," this is the part I'm referring too!
    Apr 13, 2012 2:13 PM   in reply to mikeobe
    True. But, it you were to open a raw file using PSCS6 and Camera RAW, you would eventually save the image as a PSD, TIF, JPG or some other format, right? If that were not the case, why would you even bother to open the file in PS? Assuming you do plan on saving the file from PS after editing, then edit the image and just click SAVE. That will overwrite the TIF file that LR created and update the preview in LR.
    If you don't want TIF format, then change the edit preferences in LR. You can select PSD or TIF, 8 or 16 bit, sRGB, Adobe RGB, ProPhotoRGB, and you can  set the resolution in PPI. If you want JPG or another color profile, then you will have to do that another way.
    The above is not a compatibility issue. If you don't want the TIF or PSD file, then you can save as a different format directly from PS after editing, or export the TIF file to another file format from LR. Of course, you can choose to delete the TIF afterward if you choose, and perhaps this is an extra step you don't want. Seems like a minor point to me. If that extra step is not acceptable, then spend the money on PSCS6 and the latest version of Camera Raw.
    Apr 14, 2012 6:26 AM   in reply to Lou Dina
    K, thanks for your patience,  I think I finally get it! Sheesh!
    Apr 20, 2012 11:32 PM   in reply to CSS Simon
    I am using LR 4.1rc and ACR 6.7rc and i can no longer get the warning about rendering in LR and the reset warnings button is greyed out. Tried trashing preferences and restarting LR, but no success.
    Apr 21, 2012 5:04 AM   in reply to David MMMM
    The warning should no longer be needed if you are using ACR 6.7rc, since it uses the same raw processing algorithm as LR 4.1rc. The warning that offers you the option of rendering in LR is there ONLY if you have an older version of ACR. That is as it should be. Now that both ACR and LR have the same exact raw processing modules and formulas, you don't have to worry about getting different results, regardless of which one you use.
    Jun 6, 2012 6:28 AM   in reply to dmiller62
    dmiller62 wrote:
    There is nothing here going on that should be a mystery. The bottom line is this:
    - PV2012 requires Camera RAW 7.0.
    if the only RAW 7.0 plugin tha's released is for CS6, then anyone who wants a fully bridged/compatible workflow between LR4 and Photoshop will need to upgrade to CS6.
    I'm testing Bridge CS6, and LR4 adjustments still don't show in bridge although it uses camera raw 7. Shouldn't it?
    If I adjust in LR4, it won't show in Bridge CS6 (it even maintains the settings I previously applied in ACR 7). While if I adjust it in ACR 7, back in LR 4, it will show up as it should (even warning if the settings was changed in another app, and show I keep that setting or the one I'm changing in LR4).
Actions
