NhimYeu
Can use another software (not FMLE) to publish stream to FMS?
Mar 6, 2012 12:21 AM
Hi all,
I have a question:
I ask this question because I want to use Authentication add-in to prevent user publish stream to FMS. This add-in only affect with FMLE, so, if user use another encoder software, they still can publish stream to my FMS
    Mar 7, 2012 6:46 AM   in reply to NhimYeu
    You can use any encoder to publish to FMS - you can write you own add-in to restrict any publisher - but you are right that FMLE add-in will work only for FMLE.
    Actually i am not clear with your questions - Are you concerned that other publishers apart from FMLE would publish or you want add-in for other encoders - meaning do you plan to use another encoder?
    If its first problem - you can do simple thing - turn SWF verification on - make exception for FMLE and have FMLE add-in - in this case only valid clients would be able to connect - even other encoders wont be able to connect - so if someone cant connect there is no way they can publish.
    Mar 5, 2013 10:20 PM   in reply to SE_0208
    Is there any possiblity to publish the multible bitrate stream(MBR) from web application like using add-in or FMLE is the one and only option for the MBR to FMS
