CQ5
Amitdstar
HOW TO USE PARSYS IN A TAB?
Mar 6, 2012 5:26 AM
Tags: #navigation #cq5 #tab #parsys
Hi All,
I really need yours help.
i have a multiple tab in my website and while tab navigation i (author) want to add component , for that i want to add a parsys so that author can add multiple component under one tab . please advice me how to do that.
e.g author can add multiple component under Social tab ,and same for other tab also. I am includng parsys under each tab , but that is not working .
please help
  • kasq
    Dec 1, 2011
    Mar 9, 2012 12:03 AM   in reply to Amitdstar
    Hi Amitdstar,
    It depends on your implementations of tabs component.
    One simple solution is to create template (for example: Content Page Tab Template) with parsys inside which will be used to create a content for one separate tab and then in the page in which you want to insert multiple tabs you are creating tabs component in which you only give contributor a possibility to select for each tab a path to page which contains a content created by Content Page Tab Template.
    This main component will use path to retrieve a components included in the parsys and then using  <sling:include> tag will include specific component with content.
    Second solution is to create a for each tab different parsys, for instance:
    <cq:include path="tab1-parsys" resourceType="foundation/components/parsys"/>
    <cq:include path="tab2-parsys" resourceType="foundation/components/parsys"/>
    and then include inside different parsys the same components.
    I hope it is clear,
    kasq
