advice - From PDF
Mar 6, 2012 6:41 AM
Looking for some advice.  Besides the obvious that I should have had a Backup
I created a Listings Directory, in 3 sections.  Each page was set in 4 columns. I generated a PDF for proofing.
Hard drive crash and I lost my ID file.
So, all I have to work from is the PDF.  I need to recreate the Indesign Document from this PDF.
Any suggestions are appreciated.
    Mar 6, 2012 6:52 AM   in reply to Karl B Cartwright
    The only thing that will currently open a PDF for editing in ID is the PDF2ID plugin from Recosoft: http://www.recosoft.com/products/pdf2id
    Keep in mind athat PDF is a final format, and you will not recover things like styles, anchored object settings or probably text threading, so even with the text in front of you you may have a lot of work still to do, and you might not be any further along than if you just save the text and export the images out of Acrobat.
    Mar 6, 2012 7:14 AM   in reply to Karl B Cartwright
    From Acrobat, you can save the PDF as text or rich text. If the document was well-styled, import the rtf into a new ID document that matched the layout and format of the original.
    Mar 29, 2012 9:00 AM   in reply to Peter Spier
    http://markzware.com is actually coming out with a conversion plugin that works with InDesign. From what I have tested and seen, the conversion is quite accurate and fast.
    If you are interested in doing a beta test, there is actually one going on right now:
    http://markzware.com/pdf2dtp-beta/
    Was very nice to test out this product and compare it to what is currently available in the market.
Bookmarked By (1)
