For my data-point.
I am running a modest system compared to many described here:
dualcore 2.6GHz, 16gb Ram. OS one one disk, images and Cat on another.
This was all fine on LR 3.x and 4.0.
Most importantly, the user interface experience was consistent - there were no major swings in response time.
Latest version of LR, on a completely rebuilt system (fresh OS) shows a significantly more inconsistent experience.
My biggest issue is when I stack up even a small number of correction activities ( up to 5) - e.g. brush, grad density, spot, the overall responsivness takes a major dive. The cursor is sluggish, sliders start to behave as if they are on an elastic band etc.
I am not seeing spikes in disk or memory activity, but spikes in CPU every time I 'touch' the image after a couple of say, spot corrections.
I could speculate on the cause (like many in this forum, I've been in IT for a long time), but I'll rely on Adobe knowing it's stuff and hopefully another data-point might help.
I hope that Adobe has not gotten itself into a fix with an overly complex image processing pipeline and UI/rendering threading issues
.. damn! I said I wouln't speculate!
Hans
Did you see the post recently where someone with the same sort of problems
solved it completely by updating his Wacom driver? You don't use a Wacom by
any chance?
Bob Frost
I have over 20 years of application, operating system and storage system support and engineering experience for some of the biggest names in the industry I can assure you all this "I'm not seeing it so it's your system at fault" talk is very wide of the mark.
We can all swap stories about our experience in IT - it sometimes seems that there are more current and ex IT professionals on here than there are "just" photographers (yep, me too) and I'm afraid that we're going to have to agree to differ about your "assurance".
A simple counter to your argument is why only LR sees the problem. I have many other apps and the all work well except LR.
The simple answer to this is that Lr is widely acknowledged to be software that really stresses hardware, and it shows up bottlenecks in software/OS configurations too.
And they're local issues all...
Keith, I suspect you're right about IT people in here... I THINK it's because digital photography has such an appeal to our geek nature! I too have many years as a software engineer, database designer, and so on. My wife has always said that digital photography came along at the perfect time for me. It allows me to combine my love of computers and computing with my enjoyment of capturing moments...
UNFORTUNATELY, for those of us who do or did make our careers designing and building mission-critical systems, I suspect it also makes us far less tolerant of software that degrades from version to version. Yes, we sometimes made mistakes and put out softwarse the crashed and burned spectacularly, but I can also remember the company I worked for recalling software and TELLING clients NOT to upgrade because of some problem that had been discovered. And communicating to them that we were DEFINITELY and ABSOLUTELY working our collective fannies off to find and correct the problems. I think the communication part was what clients appreciated most.
BUT, anyhow, back to the problem at hand... In the middle of the night, I woke up with a thought (yes, I know, I desperately need to get a life)... When I was testing yesterday, it APPEARED TO ME that the .dng files responded more slowly (slightly) than did the same files in .nef format. But, that doesn't make sense. The .dng files are smaller, there's no sidecar file to fiddle with, and the .dng is a proprietary (public) format created by Adobe rather than some reverse engineered thing... Shouldn't they have been significantly FASTER to process/display than the .nef files? What am I missing?
I really dont think the file, or file size has any bering on this problem.
Depends which bit of the 'LR is slow' problem you are talking about!! A 10MB
nef takes about 1 sec to render on my PC, a 20MB takes 2 secs, and a 40MB
takes 4 secs. Directly proportional to file size, but of course you a
probably right when talking about slowness in develop steps, sliders, etc.
Bob Frost
Did anyone notice that
scrolling with the mouse in the library gives a very different user experience than scrolling with the arrow keys? One is unbearable no matter how fast the system. Guess which one.
(ii) switching from Library to Develop mode (the modality of it all) takes a long time even if the photo has been loaded into memory several times on a 32GB system?
(iii) upgrading from circa 2008 quadcore with 8GB and 1 hard drive to latest i7 with 32GB, SSD and HDD makes every other program faster, but various aspects of Lightroom are still slow? (see above)
(iv) we keep getting advice to export the catalogue before importing (even though that results in some data fields being lost) and deleting preferences and presets. We're just photographers not software engineers. Shouldn't the advice be directed to the Lightroom engineers to kindly fix their, shall we say "outdated' database system so that it's as robust as can be? They've had 4 shots at it, people, and it's stil a$$-backward.
Unfortunately, Color noise reduction slider has always been at the default, which appears to be 25, on my systems. If this is "significantly faster" I shudder to think what it must be like when it's NOT in this "significantly faster" setting.
As time goes on, and I actually try to WORK on things on LR4.1, the appalling slowness becomes more and more apparent in many areas. Yes, working in develop is just plain SLOW, no matter how many images you load or how many times you load them. The library module is MARGINALLY faster, but it's sure no speed demon. Cetainly significantly slower than V3...
And, it appears that ANOTHER month has gone by, and STILL no information from Adobe that they're AWARE there's a problem, WHAT they're doing, and/or WHEN we're likely to see a version that makes significant improvements. 800 pound gorilla syndrome?
I have just been using LR4.1 and happened to be printingfrom my Firefox browser as well. It locked up LR for several seconds. I mention this as it might be a clue as to what is going on. Memory leak maybe, with the printer driver over-writing some memory address LR was trying to use? The developers need all the info they can get I'd guess.
Intel i5, 16Gb RAM, Win 7 64 on one SSD, another SSD for cache/catalog, Images on SATA mechanical.
After weeks of absolutely nasty performance with LR4.1 I today tried the trick someone posted here a while ago. I started LR via a batch file:
start "lightroom" /high /affinity 15 "c:\Program Files\Adobe\Adobe Photoshop Lightroom 4.1\lightroom.exe"
And to my surprise it WAAAAAAAY faster! I know that developing multithreaded apps is quite demanding but what Adobe's dev delivered until now is just CRAP!
My machine: i7-3930 hexacore, up-to-date chipset X79 and two fast SSDs and 16 GB RAM - more than fast enough you would think...
Did you try setting affinity and priority for the LR application through the Task Manager first? I am just curious about that verses via a batch file?
You go tmy attention. LR has been giving me fits! I am reloading it daily and Adobe support has no clue what they are doing. I was thinking I needed to completely remove LR and start over but would like to give this solution a try.
Could you explain how to create a batch from your code.
I tried pasting it into the apple script editor but it wont run.
Thanks for the adivce!
Troy
Sacha_'s script is Windows-only.
Note: I start Lightroom at below-normal priority, so multiple simultaneous exports don't influence video watching etc, and it does not affect Lr performance.
I recommend checking whether it's the priority or the affinity that is helping the most.
If it's the former, then perhaps some other app or service is competing for CPU, if it's the latter, then you've been bit by a bug that's keeping Lr from using all cores as it should - dunno what the origin of such a bug would be...
Rob
When I was developing/troubleshooting this bat I found that the affinity was most important. On my system I have 4 acutal cores and 4 hyperthread. If I use ANY hyperthread performance dies. If I use all 4 main cores performance slows. By setting it to use only 3 main core and then setting the priority to high windows does a nice job of leaving LR alone and running most everything else on the remaining main and Hyper cores. My results were undenyable that LR has issues with hyperthreading at least on my intel chip and asus motherboard.
Up to 74 pages on just this thread, and no real solutions from Adobe. My biggest issue is the lag switching between modules after first starting LR4.1. Specifically, it takes upwards of 25 seconds for the Book module to load the first time (this, on a 2010 MBP with a 7500 rpm drive and 8gigs of RAM).
When Mountain Lion comes out next week, LR4.1 will most likely be replace by Aperture.
I hope you have forwarded this information to the Lightroom team. I'm on a MacBook Pro and haven't yet found the tools to disable specific cores or hyper-threading.
Agree!!!!!
Only think that KILLS me is that there is only one tool keeping me in LR over Capture One and that is the brush masking.... There are many other ways to do use this but I use this A LOT and no other process seems as seamless. Unfortunatly on PC there isnt another Raw app that does this as well. However the final results are better with the free Raw Therapy and Capture One.
I hear ya. My ASUS+AMD board has no such problems (M4A89GTD): all cores shoot through the roof when doing something that warrants multiple cores. - mostly speedy too (some things are slow due to Lr s/w design...).
I've never heard of any other problems with AMD chips, but maybe that's because so few people seem to be running them.
My Advice: Get an AMD chip!!!
Rob
Really? Lr only loads modules upon first use - it's a design thing. But 25 seconds sounds abnormally long. (I just checked, Book module takes several seconds to load (first time only), but not anywhere near 25). Anybody have any idea why it's taking "BigC"'s system so long to load Book module? - disk is healthy?
Rob
Rob
I know exactly why it's taking so long. Comptetition. There isn't any. LR needs to have more comptetition.
I know you're miffed. But, seriously: why 25 seconds to load the Book module - that sounds abnormal to me.
I mean, if Lr were performing abnormally for me, I'd be miffed too. - it's one thing to be disappointed with a normally functioning Lr, and another entirely if your perception of Lr is being influenced by abnormal performance issues.
Believe me, I have my gripes too, but Lr is mostly fast in develop mode, once loaded, and mostly fast in library mode, once previews are available. So I am mostly happy with Lr performance. I have my complaints, but it's *far* from "unusable" or "molasses in winter"...
Rob
There's no real reason for the length of time it takes for the modules to load.
I wouldn't be so sure. I mean, it sounds like you're on the "Lr4 is pure yuck" track, but you may be seeing it through yuck colored glasses...
Book module took about 8 seconds to load (the very first time ever). But now after Lr restart it comes up in about 1 second, first time (subsequent times are instantaneous).
Just measuring bit-throughput, it is slow. But how many templates have to be loaded (many files take longer than one file) and what has to be done with them? It is 300 mb of data read from disk in descrete chunks.
In the other thread I reported 8 seconds for the first load of Book.
After killing Lightroom and letting memory relax, Book takes 2 seconds to load on a subsequent load of LR
in the same session going to develop and back to book takes less than a second.
8 Seconds VS 25 on similar RPM disks (yet different data buses) is a breeze. I would be cheesed at 25 seconds but I don't notice 8.
North America
Asia Pacific
