Of course we cannot delete our existing catalogs and start new ones. That is not a fix.
terry275's fixes are Windows-specific, fwiw: I use a Mac.
This is a major drag, literally. Fortunately I still have LR3 installed, and only one or two catalogs 'upgraded' to LR4 slowness.
AndyYau,
I`ve watched your video, especially between 0:46 and 1:03, where you adjust the exposure slider. Would you call that smooth? Screen redraw looks very jerky. Or is it just your video recording? Is what you see in that video what you see on screen in this situation?
If yes, it`s as jerky as on my PC. The means, you pull the slider, but what you see on screen is an update maybe two or three times a second.
Steven,
You are right. Just compared with LR3 again and again. LR3 slider is faster and smoother. LR4 is slightly jerky if compared with LR3.
But LR4 is now several times faster than when I just installed it. I almost cannot work with it as any adjustment takes 1-3 seconds for screen to update!!
@AndyYau
Thank you very much for the work, that you uploaded that video. I had a look at it in several quality settings. I can see clearly how your mouse mooves and how the picture updates. This is laggy as hell....sorry. Yes, maybe it is in your case as fast als LR3.6, but in my case lr3.6 works completely fluid....and my lr4 works exactly like i saw it in your video.
So this is not fast......this is slow as it can be. not useable!
King regards Frank!
Frankc1978 : What I don't understand is that some people like AndyYau or me find the same results with both LR3 and LR4. Indeed, this is much slower that what you describe on your high end machine but there is no difference between the 2 versions. I would think that LR 4 would worse on LR 3 on all machines (not just on the high end ones). So , there might be an other reason.
Now confirmed you can load old catalogs in LR4 after virgin start up and they do convert but run sluggish which is what adobe have identified and presumably are working a fix. When you revert to the virgin catalog in LR4 and work on new imports via LR4 the software performs to LR3 speeds.
Hi Frank,
Fast and slow is relative and this is why I upload a video for us to compare.
I think we have to seperate two cases:a
1. When LR4 is normal (now on my Mac), it may be not as smooth as LR3. But the different is small. And I agree LR3 is a little bit faster.
2. When LR4 is abnormal, it is serveral times slower than the speed shown in the video. (For example, when I move a slider, my computer CPU load is almost 100% for all 8-cores, and I need to wait 2-3 second for the screen to refresh for just ONE mouse action). The speed different is huge.
It is pity that I do have have a video to show case 2. After Copy AS DNG, it seems problem of case 2
is solved. But the inherent probelm of LR4 in case 1 is still there.
So I think we are talking two different issues of LR4.
@correspondanc & @ andyyau!
You both are completely right. in your 2 cases maybe you are used to a slower speed even out of lr3. maybe lr3 always was a little bit slower, but as i said, in lr3 were people capable of investing money in good hardwere on so they got a really, really realtime and fluid workflow, like i have in lr 3.6. in this case you guys got a slower pc and a slower lr 3.6 and do/can not see a difference between lr 3.6 and 4.0. thats completely ok. but you must understand guys like me who are used to work on a realtime lr 3.6 and now work with this, that is just like got my 5 year older computer back. not even high end machines are able to make a fluid and real time workflow and that is my real problem. yesterday a saw lr4 on the most powerfull mac pro you can get for money. doing most profesional videocutting on it and very high complex renderings using the most expensive quadro fx card. lr4 was not slower or faster than on my machines. it is like tehre is a door in lr4 that is closed for fast machines. as i allready said on my 12 core (24 threads) machine i do not have more than 8% cpu usage so lr4 (x64) does not take the whole power a computer can deliver! working in lr 3,6 my cpu usage rises to about 36%. i will try the trick terry275 wrote above and see if it will bring any difference!
king regards frank!
Frankc1978 : I think we do not understand each other.
I totally agree with you. When used to fluid workflow on your machine, going slower is not acceptable.
What I don't understand is why on your machine you go slower (a lot from you say), and , on smaller machines, there is no difference (I calculated as I stll run with both). It does not make sense ! LR4 just also run at a slower speed on my machine too.
My conclusion is that there is something different : graphic card, the way LR4 uses dfiferently some CPUs from some others. I don't know what it is but it is a combination of LR4 and the hardware.
After two days struggling I have an LR4 running as fast as my LR3 (or if there is a difference I can't notice it).
Struggling because I did not know you could not load the paid copy over the beta test copy. It was unuseable in that mode.
If you have LR4 beta you need to uninstall it with Windows. You need to reboot. You need to remove all relevant .ldata and .lcat files and any LR4 catalogue folder. I also removed all the entries in the ...roaming/adobe/lightroom folder.
If you re-install you need to build a new catalogue of course.
If anyone around here from Adobe wants to claim my method is overkill then maybe the next person with problems will not to take such desparate measures - lucky them!
I should have spotted the clue. I loaded my paid for version of LR4 on two machines yesterday. One worked a treat. One worked like treacle. The first had not been used for the beta test and the second had...
All in the cause of progress. But at least my LR4 is fun to use again.
Happy days.
Tony
Yes, thanks,
I see the same thing here.
Starting a new catalogue (no re-install) and doing a new import of the same pictures makes LR4 much more responsive.
Activity monitor shows a much better balanced and overall lower load on the CPU cores when manipulating sliders in the develop module.
While before the load on all CPUs would brickwall to the max when doing adjustments resulting in jerky slider movements, now all the cores have some headroom and slider movement is reasonably smooth. Pretty close to old LR3 behavior even with the new process.
It seems like Adobe has to look at how to "upgrade" old catalogues without the speed penalty. Recreating the catalogues from scratch is obviously not an option for people with thousands of pics organized through LR.
I haven't done any scientific test regarding this, but I have a dual screen setup and disabling the second monitor makes a very big difference. With both screens being used by LR4 any change to the RAW settings gives me a beachball. I turned off the second one and it feels much more responsive. I'm working on a Mac Pro, Mac OS X 10.7. Of course, disabling the second screen is not the solution. I still want to use both ![]()
I have a medium-big catalog (about 60,000 photos) and it's impossible for me to reimport it: I use constantly virtual copies, and those will be lost (as far as I know) if I just reimport the original DNG/RAW. So that is not an option for me (and I'm sure for lot's of people)
Regards
Hi All. Count me as grumpy for how slow LR4 is. I have spent about 10 hours fiddling including doing a complete system restore. I will report fidnings but here are system specs:
i7 950 Quad core OC'd to 3.9Ghz - rock solid.
24Gb RAM using Mushkin Black OCd to 1800Mhz - rock solid
C: is RAID 0 on Intel Sata2 Controller, running two OCZ Vertex3 120Gb SSD
Scratch drive is mushkin Max Iops 240Gb SATA3 SSD on SATA3 controller
Photo directory is on 4Tb partition (two WD Caviar Black drives in RAID 0 on intel SATA2)
Three displays but LR running on two - powered by two MSI GTX 570 cards OCd by about 20% - rock solid - have SLI disabled
Both Lr3 and Lr4 repond much quicker when second display is turned off. Lr3 us easily usable with second display running - Lr4 is very sluggish.
I have uninstalled. Reinstalled. Backup recovery. Lr3 only. Lr4 only. Side by side. Sharing catalog. Seperate catalog. Virgin import to LR4 to make brand new catalog. Does not matter - almost identical performance problem with LR4 (compared to LR3) under all conditions. Here is where I left it:
I now have LR3.6 and LR4 in side-by-side installs with completely seperate libraries and referencing duplicate data on the same partition. Without a doubt, LR4 is much, much more slugish than Lr3. Here is the kicker: I created a 12Gb ram disk and copied one of my folders with RAW images in it. When reading these images, LR4 does move more quickly than when reading identical files off the RAID 0 photos drive. However, the improvement is nominal and remails, very obvioudly slugish. In comparision, LR3 reading the same files from the Ram disk is much faster - tiny bit of lag.
The problems cannot have anything to do with hardware limitations or file sizes. There is something about LR4 that is grinding down its responsiveness.
How could they not have noticed this?
Kirk
PS. Once an image is cached, LR4 much more responsive - still slower than Lr3, but usable.
As an update to my previous post (#46), I tried terry275's suggestion of removing the lightroom folder and allowing LR4 to regenerate a virgin setup. I then created a new catalog with freshly imported images. Performance was the same - usable but not perfect with one display but very jerky with the second display enabled. The second display is lagging far behind the main display - they don't change simultaneously like in LR3. CPU spikes to 100% when the second display is trying to refresh. With 2 displays enabled, LR4 is practically unusable.
And, as someone else mentioned, recreating catalogs from scratch isn't a realistic solution for those of us who have spent hours editing, sorting, rating, and keywording images in our LR3 catalogs. They need to convert properly.
Out of curiosity, I installed L4 on a computer at work: Core i5, 4GB, Radeon 5450, Win7 Pro 64bit. This machine is lesser spec'd than my home machine (i7, 12gb, Radeon 5750, Win7 Ult). I created a new catalog and imported some raws. LR4 is much more responsive on this lesser machine than on my home machine, for some reason. It is smooth and snappy, like LR3. With a second display enabled (as a window on the main display because this comp doesn't have two physical monitors), performance slows a tiny bit and the second display image lags about 1-2s, but this is much better than it is at home on my better computer. On my less capable work computer, LR4 would be totally usable even with two displays.
Differences: At work, LR4, Win, and the source images are all on the same drive wheras at home, the images are on a separate internal sata drive. Work has a slower CPU and less RAM. Work never had LR4 beta installed (did have LR3), home did.
Similarities: Same OS, both 64bit, both ATI video, both LR4 final, both new catalogs, same RAW files.
Message was edited by: aross4242
After using it a bit I have noticed that the initial switch from the library to develop is slow, but consequence switches are actually fairly normal. The develop module is still not as snappy as Lightroom 3.6 though. The brushes and sliders seem to work fairly fast for me. Would still like to see a speed improvement.
I tried the route of virgin install after uninstalling the original LR4-over-Beta install, deleting all files and cache and I restarted with a new, empty library. I imported a few Canon RAW files and gave it a go - I see very little, if any, performance change. I processed one of the same RAW files in 3.6 and it was very responsive with low latency. Using similar edits, the export of the finished JPEG took about 16 secs in LR4, 8 in 3.6.
I'm going back to 3.6 until Adobe comes up with a solution. I do this as a hobby for fun and LR4 is so irritating right now that it ain't fun at all.
Dave
I don't know if this is useful or not, but I thought that the 4Beta was a real dog, and I had uninstalled and reinstalled a couple of times.
Today I decided to try the Lightroom 4, so I unistalled the Beta again, downloaded and installed the full trial version and again it opened the few photos I had in the catalogue, and again it was really slow, and used 100% of the cpu for most of the time it was trying to do any adjustment.Quite disappointing really.
So I uninstalled, rebooted, reinstalled the trial version, found the Beta catalogue which was in Pictures as Lightroom 4 Beta.Ink, and all related files,Beta Ink2 and data, and I don't know which of the two things I did, rebooting after uninstalling, or removing the catalogue but now I have a Lightroom 4 which responds very well.
Like I thought it should in fact.
I'm also experiencing a sluggish interface. I'm using a 2010 6-core 3.33GHz Mac Pro with 24GB of ram and a 240GB SSD. LR4 is currently using about 3GB RAM. Slider movements take 1-2 seconds to show up on the 12MP Nikon D3s RAW preview in the Develope module. Even more curious, moving files within LR is extremely slow even when I'm not in the folder sending/receiving the files which would require a screen redraw for each move... but it acts that way... About one file per second moves between source and destination.
If you look at the last three messages you will see the first (of the three) removed all traces of the beta and now has a useable LR4.
The next two messagers do not tell us whether they have upgraded from the beta or from LR3.
I am sorry to labour this point but, to me anyway, it seems important.
It really would help if future posters not only tell us about their slow LR4 but also about whether they migrated from the beta and/or LR3.
Tony
Ok, to sum up my experience:
User of LR3, never installed a beta, installed LR4 as trial.
High-end MacPro (8-core 3GHz, 24GB RAM, OS 10.7.3) 3 displays
LR4 is sluggish and unresponsive to slider movements in develop module, activity monitor shows maximum CPU load on all cores.
Fix: Create new catalogue, re-import same pictures. This brings down CPU load to comfortable levels, UI-snappiness similar to LR3.
As others have pointed out, it will be difficult to compare user experiences such as sluggishness.
LR seems to be somewhat resource-hungry anyway, so users with less powerful machines may be used to a certain lag in response and not notice too much of a difference (which is in no way meant to blame them for having a "bad" computer!).
I suggest observing the activity monitor (on the Mac) as a gauge for system load caused by the program.
I use the "clarity"-slider as a reference point and find that LR3 and a "well-behaved" LR4 leaves some headroom on the CPUs while a a sluggish LR4 drives all cores to the max for 2-3 seconds making the interaction jumpy to the point where it is hardly usable.
Macbook pro, LR3, LR4 Beta (beta was super slow). For what its worth, I had a slow experience with LR4. Used a new catalog, tried some of the suggestions here, did an archive install of Lion. No success. Adobe customer support said I may have had an issue with a corrupt user profile (i was missing the adobe plist files). Created a new profile, and wow, just like that, night and day difference. Makes the program usable, even downright snappy. YMMV.
Ok
My feelings based on a Lapbook pro 15inch 2.2 Ghz Intel Core i7 with 8Gb 1333 MHz DDR3 750 ( 40 Gb free from 750 Gb internal hard drive) running OSX 10.7.3 with the high definition screen 1680 by1050.
Working on an 8 bit TIF from a Canon 5D11 (5340 by 3560)
I've just had a selection of images provided from a client for me to edit.
I've got several dust spots already removed
I've not got any profile adjustments applied as I'm using a tiff made from combining 3 DNG files that had the profiles applied.
This conflicts with many peoples experiences, I'm finding it very snappy, and the only reason I downloaded the LR4Beta2 er LR4.0 was because I wanted to import a catalog of a few images into LR4 and reference them from my main drive, rather than export the images and use LR4 Beta to read the images from a new location as I've been doing with other finishing edits.
I will comment on DNG edits below
I am finding that the DNG is a little slower, but its definitely no slower than LR3.5 was for me
I've tried to be as accurate as possible, but based on a catalog imported from LR3.5, with 3.5 installed, and develop settings from LR3.5 newly updated develop setting specific to LR4 beta, I'm very pleased with the speeds on my laptop.
hamish NIVEN Photography
Maybe the people who experience a slow Lightroom have the lens correction feature active for all of their pictures.
I really wondered about the slow speed in LR3 already. Yes, in LR3! The reason is, I use LR for my complete workflow, even retouching and the more you add spots and gradients to a picture, the slower it gets on my computer, but... ONLY if the lens correction is active.
I experienced, that the lens correction feature is slowing LR3 massively. You get a response time of some seconds for your clicks if lens correction is active. If you deselect it, everything works smooth.
In LR4 everything maybe a little bit slower, but I don't see the difference to LR3. Other bugs are more obvious (tone curves) and critical. But I really think (or hope) Adobe is on it.
I would appreciate it if Adobe would be more present even in this user forum to inform people about coming changes, hotfixes and bugfixes, because it seems to me, that everyone is complaining, but there are no solutions or hints that could help.
North America
Asia Pacific
