Importing Framemaker files
Mar 6, 2012 3:11 PM
Tags: #framemaker_conversion
I've had success importing smaller files (100 - 200 K), but they are the exception. Now I have to do the large dudes. 700+K. I set up the Paragraph tag conversions and click Finish. Robo sends a blue progress bar halfway across the screen and stops processing. Any ideas?
    Mar 7, 2012 1:02 AM   in reply to Thomas Barclay 1
    I have moved this to FrameMaker Integration as the question is to do with getting FM files into RoboHelp rather than the output that will be created.
    @petergrainge
    Mar 7, 2012 5:32 AM   in reply to Thomas Barclay 1
    Specific versions of RH & FM, o/s details would be helpful. Kind of sounds like a memory issue.
    Mar 7, 2012 6:11 AM   in reply to Thomas Barclay 1
    I have a project in TCS 3 with files over 1Mb that import fine on XP SP3
    Mar 7, 2012 7:23 AM   in reply to Thomas Barclay 1
    You've been placing your RH project on the network??? Definitely an issue - RH projects on network drives will inevitably get corrupted. Best practices dictates placing them in c:\projects\[project_name]\ to keep it as short as possible.
    Mar 7, 2012 7:33 AM   in reply to Thomas Barclay 1
    How much RAM? I think from your post you must be running TCS2 or 2.5 - make sure that you've got all patches installed - do them sequentially.
    Mar 7, 2012 7:46 AM   in reply to Thomas Barclay 1
    296GB of RAM? I think you're looking at drive space - I'm talking memory. Did you purchase FM & RH individually, or as part of the Tech. Comm. Suite? Use the Help > Updates area to run the patcher.
    Mar 7, 2012 8:10 AM   in reply to Thomas Barclay 1
    Are you getting any error messages? Tried closing all other apps except FM and RH to free up memory? Anything about the file you're trying to import - lots of graphics, fonts, formats?
    Mar 7, 2012 8:54 AM   in reply to Thomas Barclay 1
    So it just stalls? What about waiting it out? I know that when I imported some of my books, I had to wait 10-15 minutes for them to all be pulled into RH.
    Couple of alternatives - add more RAM or download the trial of TCS3.5 on another (non-production) machine and play with it with a copy of your FM files. There's been a lot of improvements since your version of TCS.
    Mar 7, 2012 9:04 AM   in reply to Thomas Barclay 1
    No, it would appear as if it were frozen - every once in a while it would jerk to life and the little "pages flying" graphic would advance.
    Mar 8, 2012 12:22 AM   in reply to Thomas Barclay 1
    I was wondering whether you import or reference the graphics in FrameMaker?
    Mar 8, 2012 6:01 AM   in reply to Mark Southee
    Always reference - keeps the file size down & if anything changes, I can just sub in a new image with the same name.
    Mar 8, 2012 7:04 AM   in reply to Thomas Barclay 1
    You never said if you're running the standalone versions or the TCS. If TCS, I would really suggest that you upgrade because there's a lot more fixes done in TCS 3 & 3.5 concerning the stability of the FM/RH integration.
    Mar 8, 2012 7:18 AM   in reply to Thomas Barclay 1
    It's actually cheaper - you get Photoshop, Captivate and Acrobat Pro all in the suite. I think even if you have just RH & FM, the price is cheaper in the suite; definitely cheaper if you have PS or Acrobat also.
    Mar 9, 2012 8:38 AM   in reply to Thomas Barclay 1
    Well, I know that the standalone versions of FM include a "headless" version of Acrobat for creating PDFs - when you get the suite, the headless version isn't installed but the full version is. With standalone installs, you have to uninstall the headless version, so that the full version can be installed in its place (they don't get along with each other). I don't even know if you can get older versions of Acrobat now.
    Mar 9, 2012 9:24 AM   in reply to Jeff_Coatsworth
    With the standalone version of FM, you'll get a version of Acro Distiller, which will only work with FM.
    IIRC, FM 9 shipped with Distiller 8, and then upgraded to Distiller 9 when Acro 9 came out.
    -Matt
    @mattrsullivan
