Cannot create digital ID in Acrobat X
Mar 7, 2012 11:22 AM
When attempting to create a new digital ID with Adobe Acrobat X, I am not prompted for a key algorithm or to confirm password.  When I click finsih, with no prompt to confirm password, I get a message that the passwords do not match.
    Mar 8, 2012 3:14 PM   in reply to Shotobahn
    I am having exactly the same problem.
    Mar 22, 2012 4:31 AM   in reply to Shotobahn
    I have the same problem and this issue seems to have been reported for Acrobat 9, and Acrobat X elsewhere in the forum for as far back as 2008.  When will this issue be addressed?
    http://forums.adobe.com/message/4035974#4035974
    http://forums.adobe.com/thread/855438
    May 8, 2012 2:48 PM   in reply to InDorseTech
    We had adjusted the text to 125%, thus pushing the text and box out of view.  The dialog box didn't resize to accommodate.  Resizing the font to 100% solved the problem for us.
    May 8, 2012 3:20 PM   in reply to RandallSnyderJr
    That did it. Thanks.
    May 17, 2012 5:01 AM   in reply to Shotobahn
    As a workaround to this issue thry the below mentioned
    It would not show the confirm password field to you, hence what you need to do is after you input your password press tab once and input the password again to confirm it. Click finish
    Workflow would be like:
    1. Enter password
    2. press tab once
    3. retype your password
    4. click finish
    Let me know if that helps.
    May 17, 2012 12:26 PM   in reply to pranavj
    That does it as does a previous suggestion to set the display size on the control panel to 100% vs where it was at 125%. With the former method, you cannot see the box for confirming password; with the latter, you can.
    Thanks for the help.
    jd
