I'm using CS5.5 - Flash Builder 4.5 and Flash Professional 11.5.1.349. If I import a fresh Strobe Media Player 1.6.328 project into Flash Builder and compile, it works as expected and the StrobeMediaPlayback.html page loads in my browser and behaves normally.
Next, I load assets.fla in Flash Professional and do not make any changes and publish a new assets.swc. Then I go back to Flash Builder and refresh the StrobeMediaPlayback project and compile again. This time when StrobeMediaPlayback.html loads in the browser, the Strobe SWF is instantiated on the page but is not executing, i.e. no play button and no scrub bar at the bottom, just a black box. Right button on the black box does bring up the Flash menu so the SWF did load but execution stopped somewhere.
I'm trying to get the debugger working in Flash Builder, but no luck so far.
Hopefully someone has seen this before and has some ideas.
Regards,
Tim
The problem seems to be when I load assets.fla into Flash Professional, the PlaybackSans-* fonts are not found and are mapped to system fonts. Those fonts are sitting in the fonts directory right next to assets.fla, but I need to figure out how to make them visible to Flash Profressional.
Hi Tim,
We use Flash Builder to build SMP. Regarding how to build in Flash Professional, have you checked http://osmf.org/dev/osmf/specpdfs/building-osmf.pdf ? I don't know if it solves your problem. We'll try to update the document if there are some missing steps.
Silviu,
Thanks for the quick response. I had not seen the building-osmf.pdf file before. Upon quick inspection it seems to be based on CS5 and not CS5.5 and the font issue that I am running into does not seem to be mentioned in the document. Once I figure out the font issue I'm having, I'll update this thread.
Regards,
Tim
North America
Asia Pacific
