Expand my Community achievements bar.
Numeric field changes to 2147483647 automatically
Avatar
Former Community Member
Hi
I have a numeric field in the form which is not taking any value more than 9 digits. If we try to enter more than 9 digits, It automatically changes to
'2147483647' number.
Can anyone the reason pls and also the solution.
Thanks In advance
Abhiram
Avatar
Level 9
Hi Abhiram,
What validation pattern have you set for the field?
Bibhu.
Avatar
Level 10
Hi Abhiram,
This is the maximum for a numeric field, anything above this value will be truncated (this is 2^31 -1).  You may want the following JavaScript in the change event of the field.
var newValue = parseInt(xfa.event.newText, 10);
if (isNaN(newValue) || newValue < -2147483648 || newValue > 2147483647)
    xfa.event.change = "";
If you need larger values your will need use a text field.
Bruce
