suren_tringer
Issue with find out the pageItem type
Mar 8, 2012 6:58 AM
Tags: #indesign #plugin #plug-in #indesign_cs5
Hi all,
i am trying to find out the all pageitem's type and its data on a document .i just use the following code to find out the pageitem's type .
InterfacePtr<ISpreadList> spreadList(document, UseDefaultIID());
        ASSERT(spreadList);
        if(!spreadList) {
            break;
        UIDList frameList(database);
        int32 spreadCount = spreadList->GetSpreadCount();
        for (int32 spreadIndex = 0; spreadIndex < spreadCount; spreadIndex++ )
            UIDRef spreadUIDRef(database, spreadList->GetNthSpreadUID(spreadIndex));
            InterfacePtr<ISpread> spread(spreadUIDRef, UseDefaultIID());
            ASSERT(spread);
            if(!spread) {
                break;
            int32 numberOfPages = spread->GetNumPages();
            for (int32 nPage = 0; nPage < numberOfPages; nPage++ )
                UIDList pageItemList(database);
                spread->GetItemsOnPage
                 nPage,
                 &pageItemList,
                 kFalse,
                 kFalse
                bool16 hasContent;
                int32 pageItemListLength = pageItemList.Length();
                for (int32 j = 0; j < pageItemListLength; j++ )
                    UIDRef pageItemRef = pageItemList.GetRef(j);
                    InterfacePtr<IGraphicFrameData> graphicFrameData(pageItemRef, UseDefaultIID());
                    hasContent =graphicFrameData->HasContent();
                    InterfacePtr<IPathGeometry> pathGeometry(pageItemRef,UseDefaultIID());
                    if (pathGeometry != nil)
                       PMPageItemType pathType = Utils<IPathUtils>()->WhichKindOfPageItem(pathGeometry); //issue is this statement simply break up the execution
                        switch (pathType)
please can any one help me?
    Mar 8, 2012 7:27 AM   in reply to suren_tringer
    did you try it with IPageItemTypeUtils instead of IPathUtils?
    Markus
    Mar 9, 2012 12:16 AM   in reply to suren_tringer
    You need to check the class of UIDRef.
    Is the class kGroupItemBoss, kSplineItemBoss or others?
    Mar 15, 2012 1:13 AM   in reply to suren_tringer
    This might help.
      InterfacePtr<IGraphicFrameData> graphicFrameData(content, UseDefaultIID());
    InterfacePtr<IGeometry> frameGeom(graphicFrameData, UseDefaultIID());
    PMMatrix inner2parent = ::InnerToPasteboardMatrix(frameGeom);
    PMRect r = frameGeom->GetStrokeBoundingBox(inner2parent);
    Mar 19, 2012 7:16 AM   in reply to suren_tringer
    Indeed.
                                            IDataBase* db = ::GetDataBase(doc);
                                            UIDRef content( db, uid2Test);
    Mar 19, 2012 7:40 AM   in reply to suren_tringer
    Have a look in  BscMEInvertFacade.cpp
