btvbillb
How to cffileupload and store file paths in a database?
Mar 8, 2012 9:52 AM
I'm using CF 9 and have multi-file uploading working. What I need help with is a help desk type page that will display the filenames with links to the files that are uploaded with the form that a user submits. When I view an admin page, I need to see the email form results with a list of the files uploaded and links to where they are.
Any ideas on how I can get an admin page to display only the files associated with each form submission? I'm assuming that I need to find a method of stroring each uploaded file path to a database but I don't know how to do that. Any help would be appreciated. Thanks
    Mar 8, 2012 2:22 PM   in reply to btvbillb
    To store a file path in a database table treat the path as a string, normally a VARCHAR column in a database.  You can associate these database records with a tech support incident.  Just INSERT a record for each file to be stored.
    To download the file supply the file's path to CFCONTENT.
    References:
    CFCONTENT
    http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461 172e0811cbec22c24-7c82.html
    http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WSc3ff6d0ea77859 461172e0811cbec1553c-7feb.html
    Mar 10, 2012 3:48 AM   in reply to btvbillb
    You could proceed as follows:
    1) Create a database table named uploadedFile. The columns could be, for example,
    upload_id: INT, autoincrement, primary key
    datetimecreated: DATETIME
    serverfile: VARCHAR(50)
    serverdirectory: VARCHAR(30)
    2) Do your multi-upload, for example,
    myMultiUploader.cfm
    <cffileupload url="myUploadFiles.cfm" width="600" ... etc>
    myUploadFiles.cfm
    <cffile action = "uploadAll" destination = "c:\myUploads" nameConflict = "overwrite">
    <!--- This is where your question gets answered --->
    <!--- All the information about each uploaded file is stored in the cffile structure. ColdFusion creates one cffile struct for each and every file you upload in a single upload round --->
    <!--- Save the information about each file to the database. The back slash \ often serves the purpose of an escape character. So I've replaced it with the forward slash / in the file path. --->
    <cfquery name="saveUploadInfo" datasource="myDSN">
        insert into uploadedfile (datetimecreated, serverdirectory, serverfile)
        values (#cffile.timecreated#, '#replace(cffile.serverdirectory,"\","/","all")#', '#cffile.serverfile#')
    </cfquery>
    <!--- You could in fact log (and review) all the upload data by means of the following --->
    <!--- <cflog file="uploadData" text="#serializeJson(cffile)#"> --->
    Mar 13, 2012 1:55 AM   in reply to btvbillb
    btvbillb wrote:
    To display my uploaded files on a page where the files can appear as links or be deleted, how would I get only the uploaded files to display for each record in the database?
    For example, make sure the upload directory is under the web root, something like: c:\ColdFusion9\wwwroot\myUploads. then you've already solved half the problem. The rest can proceed as follows (using my query above as example)
    <cfquery name="getUploadFiles" datasource="myDSN">
        select serverfile
        from uploadedfile
        where datetimecreated > #some_datetime_value#
    </cfquery>
    List of links: <br>
    <cfif getUploadFiles.recordcount GT 0>
    <cfoutput query="getUploadFiles" >
    http://127.0.0.1:8500/myUploads/#serverfile#<br>
    </cfoutput>
    </cfif>
    Also, where would the log file "uploadData" log file be created/generated?
    c:\ColdFusion9\logs
