cs3 straighten and crop , is there a way like cs5?
Mar 9, 2012 10:16 AM
Tags: #and #crop #straighten
Hi
on my laptop i run xp adn photoshop cs3 normal (not extended)
what i miss is a good straighten and crop like cs5
in cs3 i use the ruler tool ->rotate canvas -> arbitrary
and i my photo is straight but with big borders around the photo
now cs5 does a great job
but photoshop cs3 no
there is the scipt straighten and crop photos but in this case doesn't do a great job
because delete the borders and my photo returns to be awry
ok i can crop manually , but it's exhausting if i have to work on some photos , one by one
is there a script/action/tips or plugin  that can do the same great cs5 job?
thanks
cheers
  • Noel Carboni
    Dec 23, 2006
    Mar 9, 2012 11:33 AM   in reply to mantralightroom
    Before Adobe added that feature, I always had to do the crop manually.  I agree, it's a nice feature in the newest Photoshop.
    There's a possibility someone made a script for it I suppose, but I don't recall hearing of one.
    Do you have a Photoshop CS5 license?  Did you know you're allowed to install it on two computers (e.g., your desktop and your laptop)?
    -Noel
    Mar 10, 2012 12:40 AM   in reply to mantralightroom
    This script has been around for a long time and might fit your needs?
    // Script Name: autocrop.js
    // Version 2.0 9 December 2003
    // Description: crops the active document after image rotation
    // This version is compatible with Photoshop CS and will not run on Photoshop 7
    // This script is product of Paul Jaruszewski and Roger Cavanagh
    // Contact Paul at www.melor.com
    // Contact Roger at www.rogercavanagh.com
    // This script is provided free for personal use.
    // No liability will be accepted for any consequences arising from the use of this script.
    // This script may be copied IN ITS ENTIRETY to others provided and no charge is made other
    // than for media. Credit to Paul and Roger must be made if this script is posted for download
    // or distribution.
    // Installation: copy the file autocrop.js to the ..\Presets\Scripts folder
    // Globals
    var chosenMethod = 0;
    var ui_NoOpenDocuement = "No open document";
    var hlpMsg = new Array();
    var msg = "";
    var hid_BinChop = 1;
    msg = "Binary Search will usually be the fastest method to find edges, but may be slower than the ";
    msg = msg + "Slice method with smaller amounts (1-2 degrees) of rotation. May produce an over";
    msg = msg + "-crop, if the search inadvertently matches the background colour inside the picture.";
    hlpMsg[hid_BinChop] = msg;
    var hid_Slice = 2;
    msg = "Almost as fast as binary search method, but will sometimes produce slight over-crop. This ";
    msg = msg + "can be avoided by ensuring the background colour is different from the edges (10 px) ";
    msg = msg + "colour in the picture";
    hlpMsg[hid_Slice] = msg;
    var hid_UniPixel = 3;
    msg = "This is much the slowest search method, but will only produce an error, ";
    msg = msg + "if edges pixels are the same colour as the background.";
    hlpMsg[hid_UniPixel] = msg;
    var hid_BestResults = 4;
    msg = "For best results, you should make sure the background colour does not occur near the top ";
    msg = msg + "left corner of your picture. If the picture contains predominantly dark colours, ";
    msg = msg + "set a white background before image rotation, and vice versa.";
    hlpMsg[hid_BestResults] = msg;
    function settingDialog() { // Creates dialog window and gets user input         ===settingDialog===
    // These are functions in scope for settingDialog ()
    // ------------------------------------------------------------------------------aboutBtnOnClick---
    function aboutBtnOnClick() {
     var msg = "Autocrop V2\n\n\Copyright \u00A9 2003 Paul Jaruszewski and Roger Cavanagh\n";
     msg = msg + "www.melor.com - www.rogercavanagh.com\n";
     msg = msg + "Information: http://www.rogercavanagh.com/actions/15_autocrop.htm";
     dlg.msgPnl.helpMsgSt.text = msg;
    } // end about BtnOnClick
    function cancelBtnOnClick() { // -----------------------------------------------cancelBtnOnClick---
     dlg.close();
    } // end cancelBtnOnClick
    function evalMethod() { //------------------------------------------------------------evalMethod---
     var result = 0;
     if (dlg.methodPnl.binChop.value) { result = 1; };
     if (dlg.methodPnl.slice.value) { result = 2; };
     if (dlg.methodPnl.uniPixel.value) { result = 3; };
     return result;
    } // end function evalMethod
    function runBtnOnClick() { // -----------------------------------------------------runBtnOnClick---
     chosenMethod = evalMethod();
     dlg.close();
    } // end runBtnOnClick
    function displayHelp(hlpMsgId) { // -------------------------------------------------displayHelp---
     dlg.msgPnl.helpMsgSt.text = hlpMsg[hlpMsgId];
    } // end function
    // Standard Values
    var mgn = 10;
    var mgnTop = 20;
    var rowH = 20;
    var rBtnW = 120;
    var btnW = 100;
    // Method Panel Parameters                                           ---Method Panel Parameters---
    var ul_MethodPnlTitle= "Method:";
    var methodPnlRows = 3;
    var methodPnlCols = 1;
    var methodPnlH = methodPnlRows*(mgn + rowH) + mgnTop;
    var methodPnlW = 350; // (methodPnlRows + 1)*mgn + rBtnW; // max number of items
    var methodPnlX = mgn;
    var methodPnlY = mgn;
    // Control Panel Parameters                                          ---Control Panel Parameters---
    var ul_ControlPnlTitle = "Control Panel:";
    var ul_Run = "Run";
    var ul_Cancel = "Cancel";
    var ul_About = "About";
    var controlPnlRows = 3;
    var controlPnlCols = 1;
    var controlPnlH = methodPnlH;
    var controlPnlW = btnW + (controlPnlCols + 1)*mgn
    var controlPnlX = methodPnlX + methodPnlW + mgn;
    var controlPnlY = mgn;
    // Message Panel Parameters                                          ---Message Panel Parameters---
    var ul_MsgPnlTitle = "";
    var msgPnlH = 140;
    var msgPnlW = methodPnlW + controlPnlW + mgn;
    var msgPnlX = mgn;
    var msgPnlY = methodPnlY + methodPnlH + mgn;
    var ul_BinarySearch = "Binary Search";
    var ul_PixelSlice = "Pixel Slice";
    var ul_SinglePixel = "Single Pixel";
    // Dialog Window Parameters                                          ---Dialog Window Parameters---
    var uiTitle = "Autocrop";
    var numPnlsAcross = 2;
    var numPnlsDown = 2;
    var dlgX = 100;
    var dlgY = 100;
    var dlgH = methodPnlH + msgPnlH + (numPnlsDown + 1)*mgn;
    var dlgW = methodPnlW + controlPnlW + (numPnlsAcross + 1)*mgn;
    var bounds = new Array(4);
    var x1 = 0, x2 = 0, y1 = 0;
    // Create window and panels                                          ---Create window and panels---
    bounds = {x:dlgX, y:dlgY, width:dlgW, height:dlgH};
    var dlg = new Window("dialog", uiTitle, bounds);
    bounds = {x:methodPnlX, y:methodPnlY, width:methodPnlW, height:methodPnlH};
    dlg.methodPnl = dlg.add("panel", bounds, ul_MethodPnlTitle);
    bounds = {x:controlPnlX, y:controlPnlY, width:controlPnlW, height:controlPnlH};
    dlg.controlPnl = dlg.add("panel", bounds, "Control Panel:");
    // Method Panel Elements                                                ---Method Panel Elements---
    x1 = mgn;
    y1 = mgnTop;
    bounds = {x:x1, y:y1, width:rBtnW, height:rowH};
    dlg.methodPnl.binChop = dlg.methodPnl.add("radiobutton", bounds, ul_BinarySearch);
    dlg.methodPnl.binChop.value =  true;
    dlg.methodPnl.binChop.onClick = function() { displayHelp(hid_BinChop); };
    y1 = y1 + rowH +mgn;
    dlg.methodPnl.slice = dlg.methodPnl.add("radiobutton", bounds, ul_PixelSlice);
    dlg.methodPnl.slice.onClick = function() { displayHelp(hid_Slice); };
    dlg.methodPnl.uniPixel = dlg.methodPnl.add("radiobutton", bounds, ul_SinglePixel);
    dlg.methodPnl.uniPixel.onClick = function() { displayHelp(hid_UniPixel); };
    // Control Panel Elements                                              ---Control Panel Elements---
    x1 = mgn;
    y1 = mgnTop;
    bounds = {x:x1, y:y1, width:btnW, height:rowH};
    dlg.controlPnl.runBtn = dlg.controlPnl.add("button", bounds, ul_Run);
    dlg.controlPnl.runBtn.onClick = function() {runBtnOnClick();};
    y1 = y1 + rowH + mgn;
    dlg.controlPnl.cancelBtn = dlg.controlPnl.add("button", bounds, ul_Cancel);
    dlg.controlPnl.cancelBtn.onClick = function() {cancelBtnOnClick();};
    dlg.controlPnl.aboutBtn = dlg.controlPnl.add("button", bounds, ul_About);
    dlg.controlPnl.aboutBtn.onClick = function() {aboutBtnOnClick();};
    // Message Panel Elements                                              ---Message Panel Elements---
    bounds = {x:msgPnlX, y:msgPnlY, width:msgPnlW, height:msgPnlH};
    dlg.msgPnl = dlg.add("panel", bounds, "");
    x1 = mgn;
    y1 = mgn;
    bounds = {x:x1, y:y1, width:msgPnlW - 2*mgn, height:msgPnlH - 2*mgn};
    dlg.msgPnl.helpMsgSt = dlg.msgPnl.add("statictext", bounds, "", {multiline: true});
    displayHelp(hid_BestResults);
    return dlg;
    } // end settingDialog ========================================================end settingDialog===
    function main() { //        ===main===
    // These are functions in scope for main()
    function doCropUniPixel() {   // Single Pixel Search Routine ---------------------doCropUniPixel---
    // Declare and Initialise
     var picrgb = new Array(3);
     var backrgb = new Array(3);
     var j = 0;
     backrgb=eyeDropper(0,0); //Find color of upper left pixel
     var maxi = docRef.width;
     if (maxi > docRef.height) {
        maxi = docRef.height;
     maxi = Math.floor(maxi/2);
    loopOne:
     for (j=1;j < maxi; j++) {
      picrgb=eyeDropper(j,j);
      if (backrgb[0] != picrgb[0] || backrgb[1] != picrgb[1] || backrgb[2] != picrgb[2]) { // edge!
       bounds = new Array(j, j, docRef.width - j, docRef.height - j);
       docRef.crop(bounds);
       bounds = null;
       break;  // Exit for loop
      purge(PurgeTarget.ALLCACHES);
     } // end for
    // prep for looptwo
    loopTwo:
      picrgb=eyeDropper(docRef.width - j,j);
       bounds = null;
     } // end for
    } // end function doCropUniPixel
    function doCropBinChop() {   // Binary Search Routine -----------------------------doCropBinChop---
     var j = 0;
     var ub= 0;
     var lb = 0;
     backrgb=eyeDropper(0,0); //Find colour of upper left pixel
     ub = Math.floor(maxi/2);
    loopOne:
     while (ub - lb > 1) {
      j = Math.floor((ub - lb)/2) + lb;
       ub = j;
      } else {
       lb = j;
      } // end if
     } // end while
     bounds = [ub , ub , docRef.width - ub , docRef.height - ub ];
      bounds = null;
    // prep for looptwo
     lb = 0;
    loopTwo:
       ub = j;
      } else {
        lb = j;
      } // end if
     } // end while
     bounds = [ub , ub , docRef.width - ub , docRef.height - ub];
      bounds = null;
    } // end function doCropBinChop
    function doCropSlice() { // +10 Pixel Routine ---------------------------------------doCropSlice---
     var j = 0;
     var jInc = 10;
     j = 1;
    loopOne:
     while (j < maxi) {
        if (jInc == 1) {
           bounds = [j, j, docRef.width - j, docRef.height - j];
           bounds = null;
           break loopOne;
          } else {
           j = j - jInc;
           if (j < 0) {
            j = 0;
           jInc = 1 ;
      j = j + jInc;
     } // end while
     jInc = 5;
     j = 1;
    loopTwo:
     while (j < maxi) {
        if (jInc == 1) {
          bounds = null;
           break loopTwo;
          } else {
           j = j - jInc;
           if (j < 0) {
            j = 0;
           jInc = 1;
      j = j + jInc;
     } // end while
    } // end function doCropSlice
    function eyeDropper(x,y) { // --------------------------------------------------------eyeDropper---
    // This function returns the three values for the RGB colours of any given pixel
     var x2 = x + 1;
     var y2 = y + 1;
     var out = new Array(3);
     docRef.selection.select([[x,y], [x2,y], [x2,y2], [x, y2]], SelectionType.REPLACE, 0, false);
     for(ch in list = ["Red", "Green", "Blue"]) {
     histogram = docRef.channels[list[ch]].histogram;
      for (i = 0; i <= 255; i++) {
       if (histogram[i]) {
        out[ch] = i;
        break;
      } // end for
     } // end for
      return out;
    } // end function eyeDropper
    // Start of main() processing                                      ---Start of main() processing---
     if ( documents.length <= 0 ) {
       alert(ui_NoOpenDocument); // so we crash out
        return;
     try {
      var docRef = activeDocument;
      var settings = settingDialog(chosenMethod);
      settings.show();
      switch(chosenMethod) {
       case 1:
        doCropBinChop();
        break;
       case 2:
        doCropSlice();
        break;
       case 3:
        doCropUniPixel();
        break;
      } // End switch
     } catch (e) {
       alert("Something's bollixed. Error name: " + e.name + ". Error message: " + e.message);
      } // end try
    } // end function main
    // Dispatch
    main();
  • Pierre Courtejoie
    Jan 11, 2006
    Mar 10, 2012 12:44 AM   in reply to mantralightroom
    That's what the crop and straighten script does...
    You could try recording an action, where you select the surrounding area (with a stop in the action) and it would do select>inverse, and then edit>trim.
    h, I see that Paul has provided a script that might fit your needs.
  • Pierre Courtejoie
    Jan 11, 2006
    Mar 10, 2012 2:48 AM   in reply to mantralightroom
    You would need to crop the image, in this case, but would miss the relevant parts. CS5's content aware fill would help.
    You do use Photoshop in Italian?
  • Pierre Courtejoie
    Jan 11, 2006
    Mar 10, 2012 4:08 AM   in reply to mantralightroom
    Yes, in this case, trim is useless as it already fits the top and bottom and side of the image anyways.
    I don't know about the script issue, I was raising it in case it might help Paul troubleshoot the script.
    Just in case, How did you try to use the script?
    What I meant by missing the relevant parts, is that the passage would be severely cropped to fit the edges, given the strong rotation.
  • Noel Carboni
    Dec 23, 2006
    Mar 10, 2012 7:29 AM   in reply to mantralightroom
    mantralightroom wrote:
    i would like to keep cs3 on my laptop
    cs5 need a faster pc
    That's an interesting thought.  I haven't actually tried running Photoshop CS5 on an older PC, but I never noticed that it seemed any more sluggish than its predecessors.  Did you actually try it, or are you just assuming it would be too slow?
    I should think Photoshop CS5 would run just about the same as Photoshop CS3 if you disable OpenGL Drawing (assuming it can even try to enable itself on your laptop).
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Mar 10, 2012 8:47 AM   in reply to mantralightroom
    Photoshop CS6 is not yet available.
    It's possible, depending on your laptop, that OpenGL Drawing will be available and work well enough.  But if it doesn't the fallback is to manage the screen displays in the same manner as Photoshop CS3, using GDI functionality.
    From what I gather you haven't had much luck so far in adapting a script to bring Photoshop CS5 functionality into CS3.  That's the reason I suggested considering installing the software you already have a license for.
    -Noel
    Mar 10, 2012 2:21 PM   in reply to mantralightroom
    The script works here on cs3.
    Maybe you missed part of the script when you copied it.
    I saved it as AutoCrop.jsx.
  • Pierre Courtejoie
    Jan 11, 2006
    Mar 11, 2012 8:51 AM   in reply to mantralightroom
    I don't have CS3 here. But is your version up to date? is the scripting support correctly installed?
    Mar 13, 2012 2:38 AM   in reply to mantralightroom
    Both versions work good on most images, but i couldn't really get a good test on your screenshot.
    You can try the scripts on this image as all the settings in the v2 work on this image as well as v1. (this is the only image i had that came close to yours in terms of colors)
    https://acrobat.com/#d=bLrN2-PPlmGJacISa1pu9A
    Added: I should also say that the v2 script doesn't work very well in cs5, but the v1 seems to work fine.
    Message was edited by: R_Kelly
    Mar 13, 2012 2:27 PM   in reply to mantralightroom
    Yes, in cs3 both scripts work on that photo, but the difference could be either because your language version is different or your on a mac.
    I'm using windows english and i don't have cs3 on a mac to test. Perhaps someone else that is using cs3 on a mac will verify whether the script v2 works for them.
    And yes the v2 script doesn't seem to work very well on windows cs5. (i get the same results in cs5 as you do in cs3 with the v2 script, but you don't need it in cs5)
    If the v1 script works for you, then i would just use that. And if you make an action for rotate and crop, then you wouldn't have to deal with the dialog, which is a plus.
    Mar 13, 2012 2:38 PM   in reply to R_Kelly
    With the v2 script there is an omission in the program, it expects you to have the ruler units set to Pixels, if you haven't the script does not work as it should.
    you could add this line at the begining of the script...
    app.preferences.rulerUnits = Units.PIXELS;
    Mar 13, 2012 5:54 PM   in reply to Paul Riggott
    Thanks for the info and that would make sense why it might not be working for mantralightroom and why it didn't work in cs5 (i had the ruler units set to inches).
    I really need to learn more about scripting.
    Mar 13, 2012 8:41 PM   in reply to mantralightroom
    I made the change to the scriptv2 as Paul suggested, so hopefully it should work for you.
    https://acrobat.com/#d=B3TH8GEmaGU7oZKYBQh3rA
    Mar 14, 2012 1:49 AM   in reply to mantralightroom
    This sets the rulerunits to Pixels then when finished resets them back to what they were....
    // or distribution.
    // Globals
    var msg = "";
    var hid_Slice = 2;
     dlg.close();
     var result = 0;
     return result;
     dlg.close();
    } // end function
    // Standard Values
    var mgn = 10;
    var mgnTop = 20;
    var rowH = 20;
    var rBtnW = 120;
    var btnW = 100;
    var ul_Run = "Run";
    var msgPnlH = 140;
    var msgPnlX = mgn;
    var dlgX = 100;
    var dlgY = 100;
    x1 = mgn;
    y1 = mgnTop;
    x1 = mgn;
    y1 = mgnTop;
    x1 = mgn;
    y1 = mgn;
    return dlg;
     var j = 0;
    loopOne:
       bounds = null;
     } // end for
    // prep for looptwo
    loopTwo:
       bounds = null;
     } // end for
     var j = 0;
     var ub= 0;
     var lb = 0;
    loopOne:
       ub = j;
      } else {
       lb = j;
      } // end if
     } // end while
      bounds = null;
    // prep for looptwo
     lb = 0;
    loopTwo:
       ub = j;
      } else {
        lb = j;
      } // end if
     } // end while
      bounds = null;
     var j = 0;
     var jInc = 10;
     j = 1;
    loopOne:
     while (j < maxi) {
        if (jInc == 1) {
           bounds = null;
           break loopOne;
          } else {
           j = j - jInc;
           if (j < 0) {
            j = 0;
           jInc = 1 ;
      j = j + jInc;
     } // end while
     jInc = 5;
     j = 1;
    loopTwo:
     while (j < maxi) {
        if (jInc == 1) {
          bounds = null;
           break loopTwo;
          } else {
           j = j - jInc;
           if (j < 0) {
            j = 0;
           jInc = 1;
      j = j + jInc;
     } // end while
     var x2 = x + 1;
     var y2 = y + 1;
       if (histogram[i]) {
        out[ch] = i;
        break;
      } // end for
     } // end for
      return out;
        return;
     try {
            var startRulerUnits = app.preferences.rulerUnits;
      settings.show();
       case 1:
        doCropBinChop();
        break;
       case 2:
        doCropSlice();
        break;
       case 3:
        doCropUniPixel();
        break;
      } // End switch
        app.preferences.rulerUnits = startRulerUnits;
     } catch (e) {
       alert("Something's bollixed. Error name: " + e.name + ". Error message: " + e.message + " Line number = " +e.line);
      } // end try
    // Dispatch
    main();
Bookmarked By (1)
