mayogalinwales
How to sharpen edges of image
Mar 11, 2012 6:56 AM
I've downloaded the below image from the internet and would like to harden the edges so there's no feathering. Is it possble to do this in Photoshop elements 10?
    Mar 11, 2012 7:18 AM   in reply to mayogalinwales
    Yes.
    1. Duplicate the background layer, shut off its visibility by clicking on its eye icon, and work on the background copy layer
    2. Access the magic wand tool, set the tolerance=20 in the tool's option bar, leave contiguous unchecked. Left click, then hit delete on keyboard. You should see the design in outline form, surrounded by a checkerboard pattern which denotes transparancy. The "marching ants" indicate that the selection is active
    3. Go to Select>refine edge, and adjust the feather and contract/expand sliders to suit
    4. Go to Select>deselect
    5. Open a blank layer between the background and background copiy layers and fill this layer for a replacement background, e.g. color, gradient, pattern, etc.
    Note that this image has a low resolution. For printing, it is recommended that the resolution be in the 240-300 px/in range.
    Please report back with your progress.
    Mar 11, 2012 2:28 PM   in reply to mayogalinwales
    1. Convert the image out of grayscale:  use Image...Mode...RGB Color.
    2. Use Image...Magic Extractor to get the symbol on a transparent background.
    You can then use Edit...Define Brush, which will let you use that symbol in at least 65 million different ways -- if you paint with that brush on a new layer on an image, you can vary the colour, fading, layer style, etc. of the symbol to your heart's content:
    Ken
    Mar 11, 2012 11:46 PM   in reply to photodrawken
    I did some experimenting and found a more precise way of getting a sharp edge (and creating a brush):
    2. Use Filter...Adjustments...Threshold with these settings:
      to get a two-colour image:
    3. Use the Magic Wand with these settings:
      to select the black part of the image.
    At this point, you can use Edit...Define Brush from Selection to define a hard-edged brush of the symbol.  This ensures that the symbol will be solidly filled with the Foreground colour when used, unlike my previous post which will create a filled symbol with shades of the Foreground colour:
    If you don't want to create a brush, simply use Select...Inverse (Ctrl+Shift+I) to select the white area and hit your Delete key to get the symbol on a transparent background.  You can fill the symbol as you wish -- gradient, etc.
    Ken
