My app tested fine on a DROID ii but when I had a friend download the app on his DROID x the app showed an error when run. It did not prompt the user to download the runtime. Once we did download the runtime, the app worked fine.
I went through much agony renaming my package name to remove the "air." prefix for reasons that are not important here. Could this cause a phone not to recognize that the air runtime is needed? I cannot find any documents that say that the prefix does more than help adobe keep track of air apps.
Here is my app in case it helps:
Thanks.
Have you heard of the expression, "Tampering with this product will void the warranty"? :-)
There's no guarantee that the process you went through to remove the air. prefix didn't break the part of the app that automatically triggers the AIR runtime request. You're basically doing things that aren't supported, so I doubt you'd find an answer to that question from Adobe.
Personally, I would look at using the captive runtime feature of AIR 3.1+ and then you won't have to worry about the user needing to download the runtime separately. If it's really that important for you to remove the air. prefix, captive runtime should fix this problem.
iBrent
thanks for the reply!
adobe actually does tell you that you can optionally remove the prefix (and they even give instructions) on how to do it in their "Building Adobe Air Applications" pdf.
you would think they might mention the slight hiccup that it can cause (if this is causing the issue).
i enjoy your tutorials by the way. keep em coming please!
hi. i never did try that but i didn't think it would be a problem. i would create the apk with captive runtime. then rename it. sounds like this is what you did already though. just in case this helps, here is my method for renaming an apk package name:
http://stackoverflow.com/questions/9218641/renaming-the-package-name-i nside-an-apk
let us know if you ever end up getting something to work.
North America
Asia Pacific
