Acrobat 7.0.7 does not install/update Acrobat 9 Pro Extended
Mar 12, 2012 8:16 AM
RE: http://forums.adobe.com/thread/911307
The original question was never answered. I have the same problem being an owner of Acrobat 9 Pro Extended. The solution presented only addresses Acrobat X and the E Learning suites.
I cannot use Adobe Presenter due to the Internet Explorer 9 incompatability issue.
JP
  • Jorma Jennings
    Jul 5, 2007
    Mar 12, 2012 4:05 PM   in reply to jpleong
    After installing 7.0.7 as a trial, you should be able to run the Presenter intsaller on your Acrobat 9 extended disk and it should apply your serial key.
    Mar 12, 2012 9:30 PM   in reply to jpleong
    I want to mention that Adobe Presenter 7.0.7 work fine with IE9.
    Acrobat 9 might behave bit differently. Please try following steps:-
    • Uninstall Presenter 7.0.6.
    • Download the installer of Presenter 7.0.7 from Adobe website and install in trial mode
    • Go to  (<drive>\Program Files\Adobe\Presenter 7) and go inside AMT folder  Rename AdobeConfig.xml and application.sif files
    • Relaunch Presenter
    Presenter installer will sniff the system for a valid Acrobat 9 Pro Extended license and will automatically get activated
    ~Shubhi
